MSR3640
2020-09-11提问
  • 1收藏,856浏览
apn-profile GSQXJBW.GS apn static GSQXJBW.GS
 authentication-mode chap user card password cipher $c$3$d4z9Nz5FY+5ZJu7Hjrh8tonBUMEQ35s= #
controller Cellular4/0
 eth-channel 0
 interface Tunnel1 mode ipv4-ipv4
 description to_SHENGJU-3G
 mtu 1452 ip address 192.168.6.93 255.255.255.252
 ospf cost 2200
 source 10.170.255.58
 destination 192.192.193.110
 interface Eth-channel4/0:0
 dialer circular enable dialer-group 4
 dialer timer idle 300
 dialer number *99#
 ip address 10.170.255.58 255.255.255.0
 apn-profile apply test
 ip route-static 0.0.0.0 0.0.0.0 Eth-channel4/0:0 preference 70
以太网子接口端口无法起来
是4G模块插入路由器需要做什么措施吗
display cellular 4/0
display interface eth-channel 4/0:0
发一下这两个信息
[GCZ_MSR3640]dis cellular 4/0 Cellular4/0: Modem State: Hardware Information: Model: U8300C Manufacturer: LONGSUNG Modem Firmware Version: QA30002.1.6_MV11(4534_1.2.3_L0801) International Mobile Equipment Identity (IMEI): 869751028263729 International Mobile Subscriber Identity (IMSI): 460013169610081 Mobile Equipment Identifier (MEID): A100005B1C5093 Hardware Version: 30000 Modem Status: Online Modem Status: IPv4 Unkown. Modem Status: IPv6 Unkown. Profile Information: Profile index: 1 PDP Type: IPv4v6 Header Compression: Off Data Compression: Off Access Point Name (APN): GSQXJBW.GS Authentication: CHAP Username: card * - Default profile Network Information: Current Service Status: Service Available Registration Status: Registered Current Service: Combined Current Roaming Status: Home Current Data Bearer Technology: Unknown Network Selection Mode: Automatic Current IP address Mode: IPv4 Cellular-alloc Mobile Country Code (MCC): 460 Mobile Network Code (MNC): 01 Location Area Code (LAC): 48518 Cell ID: 209614359 Radio Information: Technology Preference: UMTS only Technology Selected: UMTS Configured LTE Band = 1,3,38,39,40,41 WCDMA related info: Current RSSI: -84 dBm Current ECIO: -3 dBm Modem Security Information: PIN Verification: Disabled PIN Status: PIN Requirement Disabled Number of PIN Retries Remaining: 3 Number of PUK Retries Remaining: 10 SIM Status: OK ICCID: 89860113887005270959 MSISDN: +8618693162824 Error Information: IPv4 dialing failed: N/A IPv6 dialing failed: N/A GPS Information: GPS Info: GPS State: Enabled GPS Mode Configured: Standalone Latitude: 29 Deg 59 Min 59 Sec North Longitude: 103 Deg 59 Min 236 Sec East Timestamp (UTC): 00/00/0000 00:00:00 Local time: 00/00/0000 00:00:00 Heading: 0.00, Velocity Horiz: 0.00, Velocity Vert: 0.00 Height (MSL): 31.00 m Satellite Info:
zhiliao_pSTYi 发表时间:2020-09-11
看不出来问题,运行中故障吗,之前有没有做过什么操作。建议收集一份诊断信息,400报障吧
我是一只没有感情的柚子 发表时间:2020-09-11
[GCZ_MSR3640]dis interface Eth-channel 4/0:0 Eth-channel4/0:0 Current state: DOWN Line protocol state: UP(spoofing) Description: Eth-channel4/0:0 Interface Bandwidth: 384 kbps Maximum transmission unit: 1452 Internet address: 10.170.255.58/24 (primary) IP packet frame type: Ethernet II, hardware address: 00a0-d5ff-ff04 IPv6 packet frame type: Ethernet II, hardware address: 00a0-d5ff-ff04 Output queue - Urgent queuing: Size/Length/Discards 0/100/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 Last clearing of counters: Never Transfer time: 00:00:00 Last 300 seconds input rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec Last 300 seconds output rate: 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec Input: 0 packets, 0 bytes 0 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 runts, 0 giants 0 CRC, 0 overruns 0 drops, 0 no buffers Output: 0 packets, 0 bytes 0 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 underruns, 0 collisions 0 deferred, 0 lost carriers
400保障是什么意思
打电话 400-800-0504 ,到华三工程师解决。
好的
粉丝:124人 关注:6人
检查下是否有logbuffer的错误日志反馈。
可以考虑升级MSR3640的软件版本到最新。
如果还是不行,可收集产品型号、序列号、诊断信息文件反馈到400
以下是MSR3600系列的用户手册连接,请参考:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_3600/
