WA4320瘦AP转胖AP后无法进入
2020-09-19提问
  • 1收藏,1032浏览
使用瘦AP转成胖AP后 无法进入
安安静静 知了小白
现在是这个状态了
<WA4320i-ACN>reboot
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:n
#Apr 26 12:30:42:197 2000 WA4320i-ACN DEVM/1/REBOOT:
 Reboot device by command.
%Apr 26 12:30:42:197 2000 WA4320i-ACN DEVM/5/AC_REBOOT: System is rebooting now.
 Now rebooting, please wait... 这里1s之后自动跳转到提示符
<WA4320i-ACN>
<WA4320i-ACN>
ap注册不上ac
由于命令不能重启ap,只能掉电重启ap
查看ap完整的启动信息
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing................................
Done!
*                 H3C WA4320i-ACN BootWare, Version 1.09                   *
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Mar 23 2015
CPU Type            : ATHEROS AR9550
CPU L1 Cache        : 32KB
CPU Clock Speed     : 720MHz
Memory Type         : SDRAM
Memory Size         : 256MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 000 发现此处读取不到信息,判断应该是ap硬件信息丢失
PCB Version         : Ver.C
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--flash:/wa4300_fit.bin!...........
粉丝:111人 关注:0人
转成功后AP的ip地址默认为192.168.0.50,如果登不上,可以通过console进入命令行看下设备是否转胖AP成功
