WX3508H,WA5530。无法自动漫游切换
2020-09-23提问
  • 1收藏,1196浏览
终端连接到AP后,移动位置后显示无法获取ip了,需要把无线断开重连才可以重新连接到附近的AP。
AC旁挂模式
附件为部分配置
粉丝:48人 关注:4人
V7的AC默认支持漫游的,如果是本地转发,需要在所有的AP上行口以及交换机设备上放通所有的业务vlan。
AP接的POE交换机,POE与核心是trunk all,接AP口为Access vlan 60
zhiliao_bDy1H 发表时间:2020-09-23
zhiliao_bDy1H 知了小白
<WX3508H>dis current-configuration
version 7.1.064, Release 5430P04
sysname WX3508H
clock timezone Lisbon add 00:00:00
clock protocol none
wlan global-configuration
wlan load-balance mode session 40 gap 5
telnet server enable
irf mac-address persistent timer
irf auto-update enable
irf auto-merge enable
irf member 1 priority 1
password-recovery enable
vlan 1
vlan 60 to 79
irf-port 1
vlan-group vlanpool24g
vlan-list 76 to 79
vlan-group vlanpool5g
vlan-list 61 to 75
wlan service-template bole
ssid bole
vlan 61
quick-association enable
client vlan-alloc static
akm mode psk
preshared-key pass-phrase cipher $c$3$2w+vkRoxIV3vdplW/Je0+hbtuDSofGgW/vmw
cipher-suite ccmp
cipher-suite tkip
security-ie rsn
security-ie wpa
ft enable
service-template enable
wlan service-template bole24
ssid bole2.4.
vlan 61
akm mode psk
preshared-key pass-phrase cipher $c$3$/8omlYau0bRdOjqMuVuu7oLiaKwolIogLRSg
cipher-suite ccmp
cipher-suite tkip
security-ie rsn
security-ie wpa
interface NULL0
interface Vlan-interface1
interface Vlan-interface60
ip address 192.168.60.254 255.255.255.0
port link-mode bridge
description link-coreswitch
port link-type trunk
port trunk permit vlan all
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
line vty 0 31
authentication-mode scheme
ip route-static 0.0.0.0 0 192.168.60.1
undo info-center logfile enable
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$YNi6qFO0LadoraT6$mJLRuy6jBSpvkcYBgw7PE37A4s4/AdA7FiTlXYiacZx7jJ9OaqMKpCHSPag5D+Ix85P2mSIaQfpu/cr1AIk2RQ==
service-type telnet http https
wlan load-balance group 1
ap name ap01 radio 1
ap name ap01 radio 2
ap name ap02 radio 1
ap name ap02 radio 2
ap name ap03 radio 1
ap name ap03 radio 2
ap name ap04 radio 1
ap name ap04 radio 2
ap name ap05 radio 1
ap name ap05 radio 2
ap name ap06 radio 1
ap name ap06 radio 2
ap name ap07 radio 1
ap name ap07 radio 2
ap name ap08 radio 1
ap name ap08 radio 2
ap name ap09 radio 1
ap name ap09 radio 2
ap name ap10 radio 1
ap name ap10 radio 2
ap name ap11 radio 1
ap name ap11 radio 2
ap name ap12 radio 1
ap name ap12 radio 2
ap name ap13 radio 1
ap name ap13 radio 2
ap name ap14 radio 1
ap name ap14 radio 2
ap name ap16 radio 1
ap name ap16 radio 2
ap name ap17 radio 1
ap name ap17 radio 2
ap name ap18 radio 1
ap name ap18 radio 2
ap name ap19 radio 1
ap name ap19 radio 2
ap name ap20 radio 1
ap name ap20 radio 2
ap name ap21 radio 1
ap name ap21 radio 2
ap name ap22 radio 1
ap name ap22 radio 2
ap name ap23 radio 1
ap name ap23 radio 2
ap name ap26 radio 1
ap name ap26 radio 2
wlan load-balance group 2
ap name ap01 radio 3
ap name ap02 radio 3
ap name ap03 radio 3
ap name ap04 radio 3
ap name ap05 radio 3
ap name ap06 radio 3
ap name ap07 radio 3
ap name ap08 radio 3
ap name ap09 radio 3
ap name ap10 radio 3
ip http enable
ip https enable
wlan auto-ap enable
wlan auto-persistent enable
wlan ap-group 1
vlan 1
band-navigation disable
wlan ap-group default-group
vlan 1
broadcast-probe reply disable
ap-model WA5530
radio 1
max-power 18
power-lock enable
channel band-width 20
radio 2
max-power 18
power-lock enable
radio 3
max-power 20
power-lock enable
rate supported 12 18 24 36 48 54
rate disabled 6 9
radio enable
service-template bole24 vlan-group vlanpool24g
client-rate-limit disable
client-rate-limit inbound mode static cir 9000
client-rate-limit outbound mode static cir 9000
client-proximity-sensor enable
gigabitethernet 1
gigabitethernet 2
wlan ap ap01 model WA5530
serial-id 219801A0YF919CG001LB
vlan 1
radio 1
channel 36
max-power 18
power-lock enable
rate mandatory 12 24
rate multicast auto
rate supported 18 36 48 54
rate disabled 6 9
radio enable
dot11ac support maximum-nss 8
option roam-navigation enable rssi 20 beacon-power 10
service-template bole vlan-group vlanpool5g
client-rate-limit inbound mode static cir 35000
client-rate-limit outbound mode static cir 35000
spectrum-analysis enable
rrm
calibrate-channel self-decisive disable
calibrate-power self-decisive disable
scan-only disable
radio 2
channel 149
max-power 18
power-lock enable
radio disable
rrm
scan-only disable
radio 3
type dot11gac
max-power 20
power-lock enable
radio enable
option client reject enable rssi 20
gigabitethernet 1
gigabitethernet 2
wlan ap ap02 model WA5530
serial-id 219801A0YF919CG001H5
vlan 1
radio 1
channel 40
max-power 18
power-lock enable
radio disable
rrm
scan-only disable
radio 2
channel 157
max-power 18
power-lock enable
rate multicast auto
rate disabled 6 9
radio enable
rrm
scan-only disable
radio 3
type dot11gac
max-power 20
power-lock enable
radio disable
gigabitethernet 1
gigabitethernet 2
