对根叔知了社区有害的内容 >
对根叔知了社区有害的内容
话
WA4320-ACN-E如何刷成胖AP
2022-01-22发布
亮仔 一段
由于没有AC主机,现有5个WA4320-ACN-E AP如何把FIT转换成FAT?是否有详细的教程,谢谢
2个回复
1
zhiliao_O4IWSj 知了小白
兄弟,你的问题解决了吗,我现在遇到了和你一样的问题,我也是5台A4320-ACN-E刷胖AP,看了一些其他教程,还没上手。
已经解决了,格式化以前的系统重新刷一下就可以了
亮仔 发表时间:2022-02-16
2
zhl188 七段
粉丝:2人 关注:3人
3.AP上电后,在crt中按ctrl+B进入到bootrom菜单
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Ctrl+F: Format File System
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-3): 3       //修改以太网参数,有可能选5,请根据实际情况选择
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp tftp    //不管看到什么输入tftp
Load File Name         :wa4300s_fat.bin
                      : wa4300_fat.bin    //输入更改过后的文件名字
Target File Name       :wa4300s_fat.bin
                      : wa4300_fat.bin
Server IP Address      :192.168.0.1 192.168.0.1     //PC的ip地址,这个ip只是举例
Local IP Address       :192.168.0.50 192.168.0.50   //指定AP的ip和PC同一网段
Gateway IP Address     :0.0.0.0
Enter your choice(0-3): 1
Loading.....................................................................
..Done!
11293696 bytes downloaded!
Updating File flash:/wa4300s_fat.bin........................................
...........................................................Done!      //上传完成
上传完成后设备会再次重启
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
为防止AP空间不够,选择Ctrl+F再格式化一次。格式化之后:
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
|          Ctrl+D = Quit.                                                  |
                      : wa4300_fat.bin
Enter your choice(0-3): 2
..Done!
Enter your choice(0-3): 0      //回到主菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 4       //输入4查看文件
===============================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Application File type                                             |
|<3> Delete File                                                           |
Enter your choice(0-3): 1       //输入1查看所有文件
Display all file(s) in flash:
 'M' = MAIN      'B' = BACKUP      'S' = SECURE      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   388       Jan/01/2009 00:09:07 N/A    private-data.txt                |
|2   1418      Jan/01/2009 00:09:10 N/A    startup.cfg                     |
|3   294       Jan/01/2009 00:09:08 N/A    system.xml                      |
|4   11293696  Aug/08/2008 20:00:00 M      wa4300s_fat.bin  //ap的版本
|<3> Delete File                                                           |
Enter your choice(0-3): 0    //按0返回主菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 1       //输入1引导系统文件
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.............................Done!
<WAP712C>dir         //查看所有文件,切为胖版本完成
Directory of flash:/
   0     -rw-      1418  Jan 01 2009 00:09:10   startup.cfg
   1     -rw-       294  Jan 01 2009 00:09:08   system.xml
   2     -rw-  11293696  Aug 08 2008 20:00:00   wa4300_fat.bin
15057 KB total (4021 KB free)
回复
