Password recovery capability is enabled.
BOOT MENU
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Reserved
9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run Ctrl+Z: Access EXTEND-ASSISTANT MENU Ctrl+C: Display Copyright
Enter your choice(0-9):
bootrom已经升级为 129
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
这个我也不清楚,设备在我手里时初次通电就有这个提示。然后我升级了一下boot rom
我本以为升级boot rom可以解决这个问题,但还是没能解决
