S3100V2-26TP-EI 通过CRT连接自动显示 boot menu
2018-05-03提问
  • 1收藏,1622浏览
Password recovery capability is enabled.
BOOT MENU
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Reserved
9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run Ctrl+Z: Access EXTEND-ASSISTANT MENU Ctrl+C: Display Copyright
 Enter your choice(0-9):
bootrom已经升级为 129
粉丝:4人 关注:0人
Password recovery capability is enabled. 之前对设备做了什么操作吗?
这个我也不清楚,设备在我手里时初次通电就有这个提示。然后我升级了一下boot rom
zhiliao_u1HIA 发表时间:2018-05-03
我本以为升级boot rom可以解决这个问题,但还是没能解决
