请教stp问题
2021-01-09提问
  • 1收藏,2394浏览
s7506和下级s3110均为级连口报拓扑改变,请教这个是配置有问题吗 %Dec 30 14:34:41:497 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/1 was notified of a topology change. %Dec 30 14:34:42:059 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/23 was notified of a topology change. %Dec 30 14:34:42:060 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/16 was notified of a topology change. %Dec 30 14:34:42:060 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/1 was notified of a topology change. %Dec 30 14:34:42:720 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/23 was notified of a topology change. %Dec 30 14:57:14:399 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/11 was notified of a topology change. %Dec 30 14:57:15:335 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/16 was notified of a topology change. %Dec 30 14:57:15:773 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=4; Instance 0's port GigabitEthernet4/0/23 was notified of a topology change. %Dec 30 14:57:15:791 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/1 was notified of a topology change. %Dec 30 14:57:16:309 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/16 was notified of a topology change. %Dec 30 14:57:16:309 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/1 was notified of a topology change. %Dec 30 14:57:16:709 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/23 was notified of a topology change. %Dec 30 14:57:16:709 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/13 was notified of a topology change. %Dec 30 14:57:16:960 2020 hexin STP/6/STP_NOTIFIED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/23 was notified of a topology change.
s7506e stp instance 0 priority 0 stp enabled dis stp -------[CIST Global Info][Mode MSTP]------- CIST Bridge :0.0023-8957-a4f3 Bridge Times :Hello 2s MaxAge 20s FwDly 15s MaxHop 20 CIST Root/ERPC :0.0023-8957-a4f3 / 0 CIST RegRoot/IRPC :0.0023-8957-a4f3 / 0 CIST RootPortId :0.0 BPDU-Protection :disabled Bridge Config- Digest-Snooping :disabled TC or TCN received :3182 Time since last TC :0 days 0h:48m:5s ----[Port109(GigabitEthernet2/0/13)][FORWARDING]---- Port Protocol :enabled Port Role :CIST Designated Port Port Priority :128 Port Cost(Legacy) :COnfig=auto / Active=20 Desg. Bridge/Port :0.0023-8957-a4f3 / 128.109 Port Edged :COnfig=disabled / Active=disabled Point-to-point :COnfig=auto / Active=true Transmit Limit :10 packets/hello-time Protection Type :None MST BPDU Format :COnfig=auto / Active=legacy Port Config- Digest-Snooping :disabled Rapid transition :true Num of Vlans Mapped :8 PortTimes :Hello 2s MaxAge 20s FwDly 15s MsgAge 0s RemHop 20 BPDU Sent :408124 TCN: 0, Config: 0, RST: 0, MST: 408124 BPDU Received :930 TCN: 0, Config: 0, RST: 0, MST: 930 s3110 stp enabled S3110日志报25口和26口收到拓扑改变通知,其中25接S7506e,26接到另外一个S3110 MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/25 was notified of a topology change. MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/25 was notified of a topology change. MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/26 was notified of a topology change. MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/25 was notified of a topology change. dis stp -------[CIST Global Info][Mode MSTP]------- CIST Bridge :32768.74ea-cbe5-f83e Bridge Times :Hello 2s MaxAge 20s FwDly 15s MaxHop 20 CIST Root/ERPC :0.0023-8957-a4f3 / 20 CIST RegRoot/IRPC :32768.74ea-cbe5-f83e / 0 CIST RootPortId :128.25 BPDU-Protection :disabled Bridge Config- Digest-Snooping :disabled TC or TCN received :44908 Time since last TC :0 days 0h:3m:13s ----[Port25(GigabitEthernet1/0/25)][FORWARDING]---- Port Protocol :enabled Port Role :CIST Root Port Port Priority :128 Port Cost(Legacy) :COnfig=auto / Active=20 Desg. Bridge/Port :0.0023-8957-a4f3 / 128.109 Port Edged :COnfig=disabled / Active=disabled Point-to-point :COnfig=auto / Active=true Transmit Limit :10 packets/hello-time Protection Type :None MST BPDU Format :COnfig=auto / Active=legacy Port Config- Digest-Snooping :disabled Num of Vlans Mapped :3 PortTimes :Hello 2s MaxAge 20s FwDly 15s MsgAge 0s RemHop 20 BPDU Sent :951 TCN: 0, Config: 0, RST: 0, MST: 951 BPDU Received :415647 TCN: 0, Config: 0, RST: 0, MST: 415647 ----[Port26(GigabitEthernet1/0/26)][FORWARDING]---- Port Protocol :enabled Port Role :CIST Designated Port Port Priority :128 Port Cost(Legacy) :COnfig=auto / Active=20 Desg. Bridge/Port :32768.74ea-cbe5-f83e / 128.26 Port Edged :COnfig=disabled / Active=disabled Point-to-point :COnfig=auto / Active=true Transmit Limit :10 packets/hello-time Protection Type :None MST BPDU Format :COnfig=auto / Active=legacy Port Config- Digest-Snooping :disabled Rapid transition :true Num of Vlans Mapped :3 PortTimes :Hello 2s MaxAge 20s FwDly 15s MsgAge 1s RemHop 20 BPDU Sent :12548624 TCN: 0, Config: 0, RST: 0, MST: 12548624 BPDU Received :8701 TCN: 0, Config: 0, RST: 0, MST: 8701
bei 九段
粉丝:23人 关注:7人
优化一下组网,接终端端口开启边缘端口,75可以指定为根桥
粉丝:15人 关注:0人
这些事stp的提示,一般不是配置问题,建议看一下对端设备是否有拓扑变化,传递过来的,以及这些接口下面是什么什么,终端的话,开一下边缘端口
zhiliao_IzCz8e 知了小白
我的疑问是 为什么都是提示对端有拓扑变化 7506报s3110那边有拓扑改变,而3110又报7506那边有拓扑改变 请教这个stp enble以后 只要一个端口有变化 网内所有交换机的所有端口都会收到拓扑改变的报文吗
粉丝:124人 关注:6人
关于频繁收到TC报文,以下是排查要点,请参考:
1、使用dis stp tc查看哪些端口频繁收到或发送TC报文。
2、终端接入的端口可开启STP边缘端口,从而减少端口UP时也发送TC报文参与计算。
3、为了进一步稳定根桥,可在根桥的下联端口开启STP根保护。
4、如果有无法管辖到的设备,可考虑在相应的端口开启STP TC保护。
