以下是DHCP配置的参考命令:
开启DHCP功能:
[SW1]dhcp enable
创建DHCP地址池,命名为VLAN10,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan10]quit
[SW1]
(0)
(1)
dhcp enable
dhcp server ip-pool vlan3
gateway-list 192.168.10.254
dns-list 114.114.114.114 123.125.81.6
(0)
您好
[H3C] dhcp enable
2)配置端口所属VLAN和对应VLAN接口的IP地址,IP地址即是对应VLAN的网关地址
[H3C]vlan 5
[H3C-vlan5]port GigabitEthernet 1/0/5
[H3C-vlan5]quit
[H3C]interface vlan 5
[H3C-Vlan-interface5]ip address 192.168.5.254 255.255.255.0
[H3C-Vlan-interface5]quit
3)配置不参与自动分配的IP地址(DNS服务器等,此步为选配)
[H3C] dhcp server forbidden-ip 192.168.5.100
4)配置DHCP地址池5,用来为192.168.5.0/24网段内的客户端分配IP地址。
[H3C-dhcp-pool-5] network 192.168.5.0 mask 255.255.255.0
[H3C-dhcp-pool-5] dns-list 8.8.8.8
[H3C-dhcp-pool-5] gateway-list 192.168.5.254
[H3C-dhcp-pool-5] quit
说明:如果有多个公网的DNS地址,命令可以如下方式输入
[H3C-dhcp-pool-5] dns-list 8.8.8.8 114.114.114.114
7)保存配置
[H3C]save force
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
DNS是自己拟定啊,还是配当地区域的DNS啊?
如果有内部的dns,就用内部的
