防火墙WEB管理不能登陆
2017-07-20提问
  • 1收藏,5748浏览
H3C F100-A-SI防火墙如下配置:不能从外网web管理15.26.3.3,内网可以web管理10.100.37.1,不知什么原因
sysname XXX
 super password level 3 cipher xxx
 ike local-name zhejiang
 firewall packet-filter enable
 firewall packet-filter default permit
 undo insulate
 nat address-group 2 15.26.3.3 15.26.3.3
 firewall statistic system enable
radius scheme system
 server-type extended
domain system
local-user admin
 password simple XXXX
 service-type telnet
 level 3
ike peer zhejiang
 exchange-mode aggressive
 pre-shared-key zhejiang
 id-type name
 remote-name center
 remote-address 2.2.9.1
 nat traversal
ipsec proposal zhejiang
 esp authentication-algorithm sha1
 esp encryption-algorithm 3des
ipsec policy zhejiang 10 isakmp
 security acl 3000
 ike-peer zhejiang
 proposal zhejiang
acl number 2000
 rule 2000 permit source 10.100.37.0 0.0.0.255
acl number 3000
 rule 0 permit ip source 10.100.37.0 0.0.0.63 destination 10.100.0.0 0.0.0.255
 rule 255 deny ip
acl number 3002
 rule 0 deny ip source 10.100.37.0 0.0.0.63 destination 10.100.0.0 0.0.0.255
 rule 10 permit icmp
 rule 20 permit tcp
 rule 30 permit udp
nat server-group protocol
interface Aux0
 async mode flow
interface Ethernet0/0
 description WCN_INTERFACE_LAN
 ip address 10.100.37.1 255.255.255.0
interface Ethernet1/0
 description WCN_INTERFACE_WAN
 ip address 15.26.3.3 255.255.255.128
 nat outbound 3002 address-group 2
interface Ethernet1/1
interface Bridge-template1
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 add interface Ethernet0/0
 set priority 85
firewall zone untrust
 add interface Ethernet1/0
 set priority 5
firewall zone DMZ
 set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
 ip route-static 0.0.0.0 0.0.0.0 15.26.3.1 preference 60
 ip route-static 10.100.0.0 255.255.255.0 15.26.3.1 preference 60
 ip rpf-longest-match
user-interface con 0
user-interface aux 0
user-interface vty 0 4
return
防火墙H3C F100-A-SI一端接内网一端接外网
外网口E1/0 地址15.26.3.3
内网口E0/0 地址10.100.37.1
-4811 九段
粉丝:28人 关注:1人
上面说的都是不正确的,从配置看设备是V3平台的,根本没有域间策略之说
内网能管理,外网不能管理,说明外网将80端口给封掉了(V3平台不能更改http端口)
那我应该怎么配置,才能实现可以从外网web管理
zhiliao_77994 发表时间:2017-07-20
回复zhiliao_77994:
试试有没有ip http port xxx,然后登录时使用类似http://x.x.x.x:xxx登录,或者找运营商打开80端口
战五渣 发表时间:2017-07-20
联系运营商放通80端口即可
-4811 发表时间:2017-07-20
不是吧,运营商还会关了这个地址的80端口?我说以前都正常使用的,最近怎么不能访问了,也没更改过配置啊!
不会跟运营商有关系,我直接笔记本接外网口也是不能访问的
粉丝:19人 关注:2人
域间策略没有放通,要放通从untrust到local的域间策略。
iLeasy 三段
粉丝:3人 关注:3人
楼上正解,我发现你全局没有开启telnet功能啊
telnet server enable
zhiliao_77994 知了小白
怎么放通,我才能从外网管理它,能帮我写几句命令吗?我自己不太懂,谢谢!
