关于SR8800主控板掉电重启后可能无法启动问题的处理公告
2021-05-06提问
  • 1收藏,821浏览
公告中给出了解决方法是一篇叫《H3C SR8800 产品主控板掉电重启后可能无法正常启动时的处理措施. doc》,就这篇文档
求《H3C SR8800 产品主控板掉电重启后可能无法正常启动时的处理措施. doc》,就这篇文档。
粉丝:23人 关注:1人
1       问题确认方法
主控板插拔或者掉电后不能启动,通过consle口查看会打印如下信息,并反复重启
Boot from primary boot file
Flash file system init........................done.
Can not open flash file: flash:/device.app
FlashToSdram failed!
Boot from backup boot file
Can not open device.app
Rebooting...
Please make sure the baudrate of the terminal is 9600bps!
2       版本启动文件路径丢失的规避方法
通过bootware/bootroom菜单重新指定版本启动文件的方式,让主控板启动:
2.1   示例:Bootware203版本
Bootware203版本操作如下:
SDRAM init successful.
System is starting...
*                    H3C SR8800 BootWare, Version 203                      *
Copyright (c) 2004-2010 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Apr 27 2010
CPU Type            : MPC7447A
CPU L1 Cache        : 32KB
CPU L2 Cache        : 512KB
CPU Clock Speed     : 998MHz
Memory Type         : SDRAM
Memory Size         : 1024MB
Memory Speed        : 133MHz
BootWare Size       : 1MB
Flash Size          : 64MB
cfa0 Size           : 247MB
NVRAM Size          : 512KB
CPLD Version        : 003
PCB Version         : Ver.A
Board self testing...........................
Board steady testing...                           [ PASS ]
Board SlotNo...                                   [   0  ]
CPLD1 testing...                                  [ PASS ]
CPLD2 testing...                                  [ PASS ]
The switch's Mac address...                       [00:0F:E2:3E:B0:B6]
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Please input BootWare password:
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Modify BootWare Password                                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Enter your choice(0-9): 9     进入存储器操作菜单
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s)                   |
|<2> Set The Operating Device                                              |
|<3> Set The Default Boot Device                                           |
|<0> Exit To Main Menu                                                     |
Enter your choice(0-3): 2    设定操作的存储器
Please set the operating device:
|Note:the operating device is cfa0                                         |
|NO.  Device Name  File System  Total Size  Available Space                |
|1    flash        VFS          66324480    30284800                       |
|2    cfa0         FAT          128704512   30226432                       |
|0    Exit        |
Enter your choice(0-2):2      设置操作CFa0
Set the operation device successful!
Enter your choice(0-3): 0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 4     进入文件操作菜单
===============================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Application File type                                             |
|<3> Delete File                                                           |
Enter your choice(0-3): 2     设置文件属性
 'M' = MAIN      'B' = BACKUP      'S' = SECURE      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   98470232  Dec/10/2010 10:50:10 M      cfa0:/ SR8800-CMW520-R3328-SI.bin       |
|0   Exit        |
Enter file No:1     选择要指定的文件
Modify the file attribute:
|<1> +Main        |
|<2> -Main        |
|<3> +Backup                                                               |
|<4> -Backup                                                               |
|<0> Exit        |
Enter your choice(0-4):1            指定是主启动文件还是备启动文件
Set the file attribute success!
|<3> Delete File                                                           |
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 1          启动设备
Starting to get the main application file--cfa0:/ SR8800-CMW520-R3328-SI.bin!..
2.2   示例:Bootrom109版本
ZBB_TEST
Starting...
            *       H3C SR8800 Bootrom, Version 109           *
      Copyright (c) 2004-2008 Hangzhou H3C Technologies Co., Ltd.
      CPU    Type     : MPC7447A
The board is steady.
SlotNo of this board is 1.
EPLD1 testing is OK.
EPLD2 testing is OK.
16c2552 register testing is OK.
Please check LEDs...Done.
The device's Mac address is 0023.89ca.a200.
Press Ctrl+B to enter Boot Menu... 5
password:
          MAIN  MENU
    1. Boot with default mode
    2. Boot from primary boot file
    3. Boot from backup boot file
    4. Enter serial submenu
    5. Enter ethernet submenu
    6. Modify boot description area
    7. Modify bootrom password
    0. Reboot
Enter your choice(0-7): 6        进入菜单指定启动文件
注意请指定CF卡中启动文件为主启动文件
Please input primary boot file name:
Primary Boot File Name = cf:/ SR8800-CMW520-R3238-SI.APP
Please input backup boot file name:
Backup Boot File Name = flash:/ SR8800-CMW520-R3238-SI.APP
          MAIN  MENU
    0. Reboot
Enter your choice(0-7): 1        启动设备
感谢大神回复,可是我这个版本并没有您答案中的菜单,我还有什么办法吗? ZBB_TEST Starting... Warning: Rtc has not been enabled yet, please set the correct time after boot. Failed to init system time! *************************************************** * * * H3C SR8800 Bootrom, Version 109 * * * *************************************************** Copyright (c) 2004-2008 Hangzhou H3C Technologies Co., Ltd. CPU Type : MPC7447A Memory Size : 1024MB Board self testing... The board is steady. SlotNo of this board is 0. EPLD1 testing is OK. EPLD2 testing is OK. 16c2552 register testing is OK. Please check LEDs...Done. The device's Mac address is 000f.e278.2fc9. Data error in boot description area! Save default Boot Description to Boot Description Area... Press Ctrl+B to enter Boot Menu... 4 password: MAIN MENU 1. Boot with default mode 2. Boot from primary boot file 3. Boot from backup boot file 4. Enter serial submenu 5. Enter ethernet submenu 6. Modify boot description area 7. Modify bootrom password 0. Reboot Enter your choice(0-7): 0 Rebooting... Please make sure the baudrate of the terminal is 9600bps! ZBB_TEST Starting... Warning: Rtc has not been enabled yet, please set the correct time after boot. Failed to init system time!
Mister Qu 发表时间:2021-05-07
