路由器有6个三层网口GE0-GE5,GE3连接光猫lan(光猫为桥接模式),GE0连接交换机,配置如下。连接在GE0下交换机的电脑无法获取ipv6地址。但是如果使用其他家用傻瓜路由器,同样的连接方式,开启ipv6 native/passthrough 都可以正确获得一个60位前缀,因此光猫无问题。
version 7.1.064, Release 0821P11
sysname SlyRouter
clock timezone Beijing add 08:00:00
clock protocol ntp
wlan global-configuration
security-zone intra-zone default permit
dialer-group 4 rule ip permit
nat alg h323
nat alg ils
nat alg mgcp
nat alg nbt
nat alg rsh
nat alg sccp
nat alg sip
nat alg sqlnet
nat alg tftp
nat alg xdmcp
dhcp enable
dhcp server always-broadcast
dns proxy enable
system-working-mode standard
password-recovery enable
vlan 1
dhcp server ip-pool GigabitEthernet0/0
gateway-list 10.28.0.1
network 10.28.0.0 mask 255.255.255.0
address range 10.28.0.101 10.28.0.200
dns-list 10.28.0.1
dhcp server ip-pool gigabitethernet0/1
gateway-list 10.28.1.1
network 10.28.1.0 mask 255.255.255.0
address range 10.28.1.101 10.28.1.200
dns-list 10.28.1.1
ipv6 dhcp pool slypool
option-group 1
controller Cellular0/0
interface Dialer3
mtu 1492
ppp chap password cipher $c$3$vGSdC5n8D1UDzqQNjCfKsdO3pSAgQ/48Aw==
ppp chap user SL10012046@E
ppp ipcp dns admit-any
ppp ipcp dns request
ppp pap local-user SL10012046@E password cipher $c$3$Rz99HEepvjJX4eNVVbYVTGAa/ZEkzzBBfg==
dialer bundle enable
dialer-group 4
dialer timer idle 0
dialer timer autodial 5
ip address ppp-negotiate
tcp mss 1280
nat outbound
ipv6 address auto link-local
ipv6 dhcp client stateful prefix 1 rapid-commit option-group 1
interface NULL0
interface GigabitEthernet0/0
port link-mode route
description LAN-interface
ip address 10.28.0.1 255.255.255.0
tcp mss 1280
ipv6 dhcp select server
ipv6 dhcp server apply pool slypool
ipv6 address 1 1::1/64
ipv6 nd autoconfig other-flag
undo ipv6 nd ra halt
interface GigabitEthernet0/1
ip address 10.28.1.1 255.255.255.0
tcp mss 1280
interface GigabitEthernet0/2
combo enable copper
interface GigabitEthernet0/3
description Single_Line1
combo enable copper
pppoe-client dial-bundle-number 3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
scheduler logfile size 16
line class console
user-role network-admin
line class tty
user-role network-operator
line class vty
line con 0
line vty 0 63
authentication-mode scheme
ip route-static 0.0.0.0 0 Dialer3
ipv6 route-static :: 0 Dialer3
info-center loghost 127.0.0.1 port 3301
info-center source CFGLOG loghost level informational
performance-management
ntp-service enable
password-control enable
undo password-control aging enable
undo password-control history enable
password-control length 6
password-control login-attempt 3 exceed lock-time 10
password-control update-interval 0
password-control login idle-time 0
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
service-type telnet http
ip http enable
web new-style
wlan ap-group default-group
vlan 1
return
sysname SlyRouter
clock protocol ntp
nat alg h323
nat alg ils
nat alg mgcp
nat alg nbt
nat alg rsh
nat alg sccp
nat alg sip
nat alg sqlnet
nat alg tftp
nat alg xdmcp
dhcp enable
dns proxy enable
vlan 1
dns-list 10.28.0.1
dns-list 10.28.1.1
option-group 1
interface Dialer3
mtu 1492
dialer-group 4
dialer timer idle 0
tcp mss 1280
nat outbound
interface NULL0
tcp mss 1280
tcp mss 1280
combo enable copper
combo enable copper
line class console
line class tty
line class vty
line con 0
line vty 0 63
ntp-service enable
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
ip http enable
web new-style
vlan 1
return
(0)
如果要作为PPPOE服务器,以下是参考命令:
<H3C>sys
[H3C]sysname R1
[R1]local-user weijianing class network
New local user added.
[R1-luser-network-weijianing]password simple weijianing
[R1-luser-network-weijianing]service-type ppp
[R1-luser-network-weijianing]quit
[R1]domain name system
[R1-isp-system]authentication ppp local
[R1-isp-system]quit
[R1]int LoopBack 0
[R1-LoopBack0]ipv6 address 2::1 64
[R1-LoopBack0]quit
[R1]ipv6 prefix 1 1::/64
[R1]int Virtual-Template 1
[R1-Virtual-Template1]ipv6 address 1::1/64
[R1-Virtual-Template1]ppp authentication-mode pap domain system
[R1-Virtual-Template1]remote address pool 1
[R1-Virtual-Template1]quit
[R1]int GigabitEthernet 0/0
[R1-GigabitEthernet0/0]pppoe-server bind virtual-template 1
[R1-GigabitEthernet0/0]quit
如果是要作为客户端进行IPV6拨号,以下是参考命令:
<H3C>sys
[H3C]sysname R1
[R1]dialer-group 1 rule ip permit
[R1]int Dialer 1
[R1-Dialer1]ipv6 address auto
[R1-Dialer1]dialer bundle enable
[R1-Dialer1]dialer-group 1
[R1-Dialer1]ppp pap local-user ninglihua password simple ninglihua
[R1-Dialer1]dialer timer idle 0
[R1-Dialer1]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]ipv6 address 1::1 64
[R1]int gi 0/1
[R1-GigabitEthernet0/1]pppoe-client dial-bundle-number 1
[R1-GigabitEthernet0/1]quit
[R1]ipv6 route-static :: 0 Dialer 1
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
您好,我的帖子中就是这么配置的,您可以具体看一下
