想咨询一下 H3C ICG3000F-DP 网关的 PPPOE IPV6 如何配置呢?
2021-05-14提问
  • 1收藏,1578浏览
路由器有6个三层网口GE0-GE5,GE3连接光猫lan(光猫为桥接模式),GE0连接交换机,配置如下。连接在GE0下交换机的电脑无法获取ipv6地址。但是如果使用其他家用傻瓜路由器,同样的连接方式,开启ipv6 native/passthrough 都可以正确获得一个60位前缀,因此光猫无问题。
 version 7.1.064, Release 0821P11
 sysname SlyRouter
 clock timezone Beijing add 08:00:00
 clock protocol ntp
wlan global-configuration
 security-zone intra-zone default permit
 dialer-group 4 rule ip permit
 nat alg h323
 nat alg ils
 nat alg mgcp
 nat alg nbt
 nat alg rsh
 nat alg sccp
 nat alg sip
 nat alg sqlnet
 nat alg tftp
 nat alg xdmcp
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
 system-working-mode standard
 password-recovery enable
vlan 1
dhcp server ip-pool GigabitEthernet0/0
 gateway-list 10.28.0.1
 network 10.28.0.0 mask 255.255.255.0
 address range 10.28.0.101 10.28.0.200
 dns-list 10.28.0.1
dhcp server ip-pool gigabitethernet0/1
 gateway-list 10.28.1.1
 network 10.28.1.0 mask 255.255.255.0
 address range 10.28.1.101 10.28.1.200
 dns-list 10.28.1.1
ipv6 dhcp pool slypool
 option-group 1
controller Cellular0/0
interface Dialer3
 mtu 1492
 ppp chap password cipher $c$3$vGSdC5n8D1UDzqQNjCfKsdO3pSAgQ/48Aw==
 ppp chap user SL10012046@E
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user SL10012046@E password cipher $c$3$Rz99HEepvjJX4eNVVbYVTGAa/ZEkzzBBfg==
 dialer bundle enable
 dialer-group 4
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 tcp mss 1280
 nat outbound
 ipv6 address auto link-local
 ipv6 dhcp client stateful prefix 1 rapid-commit option-group 1
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 description LAN-interface
 ip address 10.28.0.1 255.255.255.0
 tcp mss 1280
 ipv6 dhcp select server
 ipv6 dhcp server apply pool slypool
 ipv6 address 1 1::1/64
 ipv6 nd autoconfig other-flag
 undo ipv6 nd ra halt
interface GigabitEthernet0/1
 ip address 10.28.1.1 255.255.255.0
 tcp mss 1280
interface GigabitEthernet0/2
 combo enable copper
interface GigabitEthernet0/3
 description Single_Line1
 combo enable copper
 pppoe-client dial-bundle-number 3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
 scheduler logfile size 16
line class console
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line con 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Dialer3
 ipv6 route-static :: 0 Dialer3
 info-center loghost 127.0.0.1 port 3301
 info-center source CFGLOG loghost level informational
performance-management
 ntp-service enable
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type telnet http
 ip http enable
 web new-style
wlan ap-group default-group
 vlan 1
return
 sysname SlyRouter
 clock protocol ntp
 nat alg h323
 nat alg ils
 nat alg mgcp
 nat alg nbt
 nat alg rsh
 nat alg sccp
 nat alg sip
 nat alg sqlnet
 nat alg tftp
 nat alg xdmcp
 dhcp enable
 dns proxy enable
vlan 1
 dns-list 10.28.0.1
 dns-list 10.28.1.1
 option-group 1
interface Dialer3
 mtu 1492
 dialer-group 4
 dialer timer idle 0
 tcp mss 1280
 nat outbound
interface NULL0
 tcp mss 1280
 tcp mss 1280
 combo enable copper
 combo enable copper
line class console
line class tty
line class vty
line con 0
line vty 0 63
 ntp-service enable
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
 ip http enable
 web new-style
 vlan 1
return
粉丝:124人 关注:6人
如果要作为PPPOE服务器,以下是参考命令:
<H3C>sys
[H3C]sysname R1
[R1]local-user weijianing class network
New local user added.
[R1-luser-network-weijianing]password simple weijianing
[R1-luser-network-weijianing]service-type ppp
[R1-luser-network-weijianing]quit
[R1]domain name system
[R1-isp-system]authentication ppp local
[R1-isp-system]quit
[R1]int LoopBack 0
[R1-LoopBack0]ipv6 address 2::1 64
[R1-LoopBack0]quit
[R1]ipv6 prefix 1 1::/64
[R1]int Virtual-Template 1
[R1-Virtual-Template1]ipv6 address 1::1/64
[R1-Virtual-Template1]ppp authentication-mode pap domain system
[R1-Virtual-Template1]remote address pool 1
[R1-Virtual-Template1]quit
[R1]int GigabitEthernet 0/0
[R1-GigabitEthernet0/0]pppoe-server bind virtual-template 1
[R1-GigabitEthernet0/0]quit
如果是要作为客户端进行IPV6拨号,以下是参考命令:
<H3C>sys
[H3C]sysname R1
[R1]dialer-group 1 rule ip permit
[R1]int Dialer 1
[R1-Dialer1]ipv6 address auto
[R1-Dialer1]dialer bundle enable
[R1-Dialer1]dialer-group 1
[R1-Dialer1]ppp pap local-user ninglihua password simple ninglihua
[R1-Dialer1]dialer timer idle 0
[R1-Dialer1]quit
[R1]int gi 0/0
[R1-GigabitEthernet0/0]ipv6 address 1::1 64
[R1]int gi 0/1
[R1-GigabitEthernet0/1]pppoe-client dial-bundle-number 1
[R1-GigabitEthernet0/1]quit
[R1]ipv6 route-static :: 0 Dialer 1
您好,我的帖子中就是这么配置的,您可以具体看一下
Slymitec 发表时间:2021-05-14
粉丝:2人 关注:0人
不太理解要问什么
就是这个配置究竟哪里写错了,造成GE0上的电脑无法获取正确的ipv6地址
GE3连接的光猫是工作在桥接模式下,因此路由器负责PPPOE拨号,ipv4都正常,就是ipv6死活分配不了,导致计算机无法获得ipv6地址
粉丝:226人 关注:0人
您好,参考ICG3000的ipv6配置
您好,参考了,上面已经按照参考的写的,但是就是不工作
