生成树对接问题
2021-05-20提问
  • 1收藏,813浏览
你好,核心是华三7506 rstp,底下二层tunk接入一台思科设备6509 mst,目前思科65跟内网通的,vlan也都是有的,但是思科设备上access口拿不到地址。是生成树对不上的问题吗?其他接入层的H3C就可以拿到,地址池没满,dhcp server 路由可达。 华三都是RSTP,因为华三设备太多了,如果不改变华三的生成树,思科该怎么对接。我这个版本好像 查看不了dhcp snooping的配置。display DHCP ?后面只有 client ,relay,server。互联是forwarding
粉丝:144人 关注:1人
互联是trunk吧,两边的VLAN号都对应上了把
是trunk,vlan对应的上。
zhiliao_n0gTvr 发表时间:2021-05-20
粉丝:124人 关注:6人
只要是标准协议的,STP是可以对接的。
以下是对接PVST的案例及链接,请参考:
https://zhiliao.h3c.com/Theme/details/107876
本案例使用S6800与思科2960对接PVST的典型组网配置案例,其中S6800为主根,同时也部署了IRF、与思科2960部署了链路聚合,为了进一步防止物理环路,因此在S6800与华为思科2960部署PVST
S6800版本信息如下:
<6800>dis version
H3C Comware Software, Version 7.1.045, Release 2418P05
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S6800-4C uptime is 234 weeks, 1 day, 5 hours, 28 minutes
Last reboot reason : USER reboot
Boot image: flash:/s6800-cmw710-boot-r2418p05.bin
Boot image version: 7.1.045, Release 2418P05
  Compiled Jun 09 2015 12:06:42
System image: flash:/s6800-cmw710-system-r2418p05.bin
System image version: 7.1.045, Release 2418P05
Slot 1:
Uptime is 26 weeks,0 days,8 hours,29 minutes
S6800-4C with 2 Processors
BOARD TYPE:         S6800-4C
DRAM:               4096M bytes
FLASH:              1024M bytes
PCB 1 Version:      VER.A
PCB 2 Version:      VER.A
Bootrom Version:    214
CPLD 1 Version:     002
CPLD 2 Version:     003
Release Version:    H3C S6800-4C-2418P05
Patch Version  :    None
Reboot Cause  :     UserReboot
[SubSlot 0] Main Board
[SubSlot 1] 24*SFP Plus(MacSec) + 2*QSFP Plus
[SubSlot 2] 24*SFP Plus(MacSec) + 2*QSFP Plus
Slot 2:
Uptime is 26 weeks,0 days,8 hours,15 minutes
DRAM:               4096M bytes
FLASH:              1024M bytes
CPLD 1 Version:     002
CPLD 2 Version:     003
<6800>
思科2960版本如下:
sh version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 13:44 by prod_rel_team
Image text-base: 0x00003000,>
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
anquanpingtai-ha-v4-1 uptime is 2 years, 38 weeks, 5 days, 11 hours, 11 minutes
System returned to ROM by power-on
System restarted at 23:25:04 UTC Wed Jul 19 2017
System image file is "flash:c2960-lanbasek9-mz.122-50.SE5/c2960-lanbasek9-mz.122-50.SE5.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C2960G-48TC-L (PowerPC405) processor (revision H0) with 65536K bytes of memory.
Processor board ID FOC1520W692
Last reset from power-on
6 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 20:37:06:04:0C:00
Motherboard assembly number     : 73-10300-12
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC15200C86
Power supply serial number      : DCA151090Q4
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : WS-C2960G-48TC-L
System serial number            : FOC1520W692
Top Assembly Part Number        : 800-27071-06
Top Assembly Revision Number    : D0
Version ID                      : V06
CLEI Code Number                : COMB800BRA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 48    WS-C2960G-48TC-L   12.2(50)SE5           C2960-LANBASEK9-M
Configuration register is 0xF
配置步骤
S6800MAC如下(使用lldp查看):
<6800>dis lldp local-information
 Chassis ID          : 741f-4a92-a2e7
 System name         : 6800
 System description  : H3C Comware Platform Software, Software Version 7.1.045,
                       Release 2418P05
                       H3C S6800-4C
                       rights reserved.
 System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
 System capabilities enabled   : Bridge, Router, Customer Bridge
S6800配置如下:
stp instance 0 root primary
 stp vlan 4 to 5 7 12 400 root primary
 stp mode pvst
 stp global enable
思科2960配置如下:
spanning-tree mode pvst
spanning-tree uplinkfast
查看S6800STP根信息:
<6800>dis stp root
 VLAN ID  Root Bridge ID        ExtPathCost IntPathCost Root Port
 1        32768.741f-4a92-a2e7  0           0
 4        0.741f-4a92-a2e7      0           0
 5        0.741f-4a92-a2e7      0           0
 7        0.741f-4a92-a2e7      0           0
 12       0.741f-4a92-a2e7      0           0
 196      32768.741f-4a92-a2e7  0           0
 400      0.741f-4a92-a2e7      0           0
 555      32768.741f-4a92-a2e7  0           0
查看思科2960的根STP信息:
show spanning-tree root
                                        Root    Hello Max Fwd
Vlan                   Root ID          Cost    Time  Age Dly  Root Port
VLAN0004             4 741f.4a92.a2e7      3003    2   20  15  Po1
VLAN0005             5 741f.4a92.a2e7      3003    2   20  15  Po1
VLAN0400           400 741f.4a92.a2e7      3003    2   20  15  Po1
查看S6800 STP端口的状态:
<6800>dis stp brief
 VLAN ID  Port                                Role  STP State   Protection
 4        Bridge-Aggregation7                 DESI  FORWARDING  NONE
 4        Bridge-Aggregation8                 DESI  FORWARDING  NONE
 4        Bridge-Aggregation9                 DESI  FORWARDING  NONE
 4        Bridge-Aggregation10                DESI  FORWARDING  NONE
 4        Bridge-Aggregation11                DESI  FORWARDING  NONE
 4        Bridge-Aggregation12                DESI  FORWARDING  NONE
 4        Bridge-Aggregation13                DESI  FORWARDING  NONE
 4        Bridge-Aggregation14                DESI  FORWARDING  NONE
 4        Bridge-Aggregation15                DESI  FORWARDING  NONE
 4        Bridge-Aggregation16                DESI  FORWARDING  NONE
 4        Bridge-Aggregation18                DESI  FORWARDING  NONE
 5        Bridge-Aggregation7                 DESI  FORWARDING  NONE
 5        Bridge-Aggregation8                 DESI  FORWARDING  NONE
 5        Bridge-Aggregation9                 DESI  FORWARDING  NONE
 5        Bridge-Aggregation10                DESI  FORWARDING  NONE
 5        Bridge-Aggregation11                DESI  FORWARDING  NONE
 5        Bridge-Aggregation12                DESI  FORWARDING  NONE
 5        Bridge-Aggregation13                DESI  FORWARDING  NONE
 5        Bridge-Aggregation14                DESI  FORWARDING  NONE
 5        Bridge-Aggregation15                DESI  FORWARDING  NONE
 5        Bridge-Aggregation16                DESI  FORWARDING  NONE
 5        Bridge-Aggregation18                DESI  FORWARDING  NONE
 7        Bridge-Aggregation7                 DESI  FORWARDING  NONE
 7        Bridge-Aggregation8                 DESI  FORWARDING  NONE
 7        Bridge-Aggregation9                 DESI  FORWARDING  NONE
 7        Bridge-Aggregation14                DESI  FORWARDING  NONE
 7        Bridge-Aggregation15                DESI  FORWARDING  NONE
 7        Bridge-Aggregation18                DESI  FORWARDING  NONE
 12       Bridge-Aggregation7                 DESI  FORWARDING  NONE
 12       Bridge-Aggregation8                 DESI  FORWARDING  NONE
 12       Bridge-Aggregation9                 DESI  FORWARDING  NONE
 12       Bridge-Aggregation10                DESI  FORWARDING  NONE
 12       Bridge-Aggregation11                DESI  FORWARDING  NONE
 12       Bridge-Aggregation12                DESI  FORWARDING  NONE
 12       Bridge-Aggregation13                DESI  FORWARDING  NONE
 12       Bridge-Aggregation14                DESI  FORWARDING  NONE
 12       Bridge-Aggregation15                DESI  FORWARDING  NONE
 12       Bridge-Aggregation16                DESI  FORWARDING  NONE
 12       Bridge-Aggregation18                DESI  FORWARDING  NONE
 12       Ten-GigabitEthernet1/1/12           DESI  FORWARDING  NONE
 196      Bridge-Aggregation7                 DESI  FORWARDING  NONE
 196      Bridge-Aggregation8                 DESI  FORWARDING  NONE
 196      Bridge-Aggregation9                 DESI  FORWARDING  NONE
 196      Bridge-Aggregation18                DESI  FORWARDING  NONE
 400      Bridge-Aggregation7                 DESI  FORWARDING  NONE
 400      Bridge-Aggregation8                 DESI  FORWARDING  NONE
 400      Bridge-Aggregation9                 DESI  FORWARDING  NONE
 400      Bridge-Aggregation10                DESI  FORWARDING  NONE
 400      Bridge-Aggregation11                DESI  FORWARDING  NONE
 400      Bridge-Aggregation12                DESI  FORWARDING  NONE
 400      Bridge-Aggregation13                DESI  FORWARDING  NONE
 400      Bridge-Aggregation14                DESI  FORWARDING  NONE
 400      Bridge-Aggregation15                DESI  FORWARDING  NONE
 400      Bridge-Aggregation16                DESI  FORWARDING  NONE
 400      Bridge-Aggregation18                DESI  FORWARDING  NONE
 555      Bridge-Aggregation7                 DESI  FORWARDING  NONE
 555      Bridge-Aggregation8                 DESI  FORWARDING  NONE
 555      Bridge-Aggregation9                 DESI  FORWARDING  NONE
 555      Bridge-Aggregation18                DESI  FORWARDING  NONE
 555      Ten-GigabitEthernet1/1/17           DESI  FORWARDING  NONE
 555      Ten-GigabitEthernet1/1/18           DESI  FORWARDING  NONE
 555      Ten-GigabitEthernet2/1/17           DESI  FORWARDING  NONE
 555      Ten-GigabitEthernet2/1/18           DESI  FORWARDING  NONE
<6800>
查看思科2960STP端口状态:
show spanning-tree detail active
 VLAN0004 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 49152, sysid 4, address 2037.0604.0c00
  Configured hello time 2, max age 20, forward delay 15
  Current root has priority 4, address 741f.4a92.a2e7
  Root port is 56 (Port-channel1), cost of root path is 3003
  Topology change flag not set, detected flag not set
  Number of topology changes 1607 last change occurred 1d10h ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
  Uplinkfast enabled
 Port 4 (GigabitEthernet0/4) of VLAN0004 is designated forwarding
   Port path cost 3004, Port priority 128, Port Identifier 128.4.
   Designated root has priority 4, address 741f.4a92.a2e7
   Designated bridge has priority 49156, address 2037.0604.0c00
   Designated port id is 128.4, designated path cost 3003
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   BPDU: sent 5103201, received 0
 Port 56 (Port-channel1) of VLAN0004 is root forwarding
   Port path cost 3003, Port priority 128, Port Identifier 128.56.
   Designated bridge has priority 4, address 741f.4a92.a2e7
   Designated port id is 128.524, designated path cost 0
   Timers: message age 1, forward delay 0, hold 0
   BPDU: sent 3179, received 14180965
 VLAN0005 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 49152, sysid 5, address 2037.0604.0c00
  Current root has priority 5, address 741f.4a92.a2e7
  Number of topology changes 6 last change occurred 1d10h ago
  Uplinkfast enabled
 Port 56 (Port-channel1) of VLAN0005 is root forwarding
   Designated root has priority 5, address 741f.4a92.a2e7
   Designated bridge has priority 5, address 741f.4a92.a2e7
   BPDU: sent 15, received 13553126
 VLAN0400 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 49152, sysid 400, address 2037.0604.0c00
  Current root has priority 400, address 741f.4a92.a2e7
  Number of topology changes 17 last change occurred 1d10h ago
  Uplinkfast enabled
 Port 56 (Port-channel1) of VLAN0400 is root forwarding
   Designated root has priority 400, address 741f.4a92.a2e7
   Designated bridge has priority 400, address 741f.4a92.a2e7
   Timers: message age 2, forward delay 0, hold 0
   BPDU: sent 26, received 13457418
至此,S6800与思科2960对接PVST典型组网配置案例已完成!
