你好,核心是华三7506 rstp,底下二层tunk接入一台思科设备6509 mst,目前思科65跟内网通的,vlan也都是有的,但是思科设备上access口拿不到地址。是生成树对不上的问题吗?其他接入层的H3C就可以拿到,地址池没满,dhcp server 路由可达。 华三都是RSTP,因为华三设备太多了,如果不改变华三的生成树,思科该怎么对接。我这个版本好像 查看不了dhcp snooping的配置。display DHCP ?后面只有 client ,relay,server。互联是forwarding
(0)
只要是标准协议的,STP是可以对接的。
以下是对接PVST的案例及链接,请参考:
https://zhiliao.h3c.com/Theme/details/107876
本案例使用S6800与思科2960对接PVST的典型组网配置案例,其中S6800为主根,同时也部署了IRF、与思科2960部署了链路聚合,为了进一步防止物理环路,因此在S6800与华为思科2960部署PVST。
S6800版本信息如下:
<6800>dis version
H3C Comware Software, Version 7.1.045, Release 2418P05
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S6800-4C uptime is 234 weeks, 1 day, 5 hours, 28 minutes
Last reboot reason : USER reboot
Boot image: flash:/s6800-cmw710-boot-r2418p05.bin
Boot image version: 7.1.045, Release 2418P05
Compiled Jun 09 2015 12:06:42
System image: flash:/s6800-cmw710-system-r2418p05.bin
System image version: 7.1.045, Release 2418P05
Slot 1:
Uptime is 26 weeks,0 days,8 hours,29 minutes
S6800-4C with 2 Processors
BOARD TYPE: S6800-4C
DRAM: 4096M bytes
FLASH: 1024M bytes
PCB 1 Version: VER.A
PCB 2 Version: VER.A
Bootrom Version: 214
CPLD 1 Version: 002
CPLD 2 Version: 003
Release Version: H3C S6800-4C-2418P05
Patch Version : None
Reboot Cause : UserReboot
[SubSlot 0] Main Board
[SubSlot 1] 24*SFP Plus(MacSec) + 2*QSFP Plus
[SubSlot 2] 24*SFP Plus(MacSec) + 2*QSFP Plus
Slot 2:
Uptime is 26 weeks,0 days,8 hours,15 minutes
DRAM: 4096M bytes
FLASH: 1024M bytes
CPLD 1 Version: 002
CPLD 2 Version: 003
<6800>
思科2960版本如下:
sh version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 13:44 by prod_rel_team
Image text-base: 0x00003000,>
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
anquanpingtai-ha-v4-1 uptime is 2 years, 38 weeks, 5 days, 11 hours, 11 minutes
System returned to ROM by power-on
System restarted at 23:25:04 UTC Wed Jul 19 2017
System image file is "flash:c2960-lanbasek9-mz.122-50.SE5/c2960-lanbasek9-mz.122-50.SE5.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C2960G-48TC-L (PowerPC405) processor (revision H0) with 65536K bytes of memory.
Processor board ID FOC1520W692
Last reset from power-on
6 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 20:37:06:04:0C:00
Motherboard assembly number : 73-10300-12
Power supply part number : 341-0098-02
Motherboard serial number : FOC15200C86
Power supply serial number : DCA151090Q4
Model revision number : H0
Motherboard revision number : A0
Model number : WS-C2960G-48TC-L
System serial number : FOC1520W692
Top Assembly Part Number : 800-27071-06
Top Assembly Revision Number : D0
Version ID : V06
CLEI Code Number : COMB800BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 48 WS-C2960G-48TC-L 12.2(50)SE5 C2960-LANBASEK9-M
Configuration register is 0xF
S6800的MAC如下(使用lldp查看):
<6800>dis lldp local-information
Chassis ID : 741f-4a92-a2e7
System name : 6800
System description : H3C Comware Platform Software, Software Version 7.1.045,
Release 2418P05
H3C S6800-4C
rights reserved.
System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
System capabilities enabled : Bridge, Router, Customer Bridge
S6800配置如下:
stp instance 0 root primary
stp vlan 4 to 5 7 12 400 root primary
stp mode pvst
stp global enable
思科2960配置如下:
spanning-tree mode pvst
spanning-tree uplinkfast
查看S6800的STP根信息:
<6800>dis stp root
VLAN ID Root Bridge ID ExtPathCost IntPathCost Root Port
1 32768.741f-4a92-a2e7 0 0
4 0.741f-4a92-a2e7 0 0
5 0.741f-4a92-a2e7 0 0
7 0.741f-4a92-a2e7 0 0
12 0.741f-4a92-a2e7 0 0
196 32768.741f-4a92-a2e7 0 0
400 0.741f-4a92-a2e7 0 0
555 32768.741f-4a92-a2e7 0 0
查看思科2960的根STP信息:
show spanning-tree root
Root Hello Max Fwd
Vlan Root ID Cost Time Age Dly Root Port
VLAN0004 4 741f.4a92.a2e7 3003 2 20 15 Po1
VLAN0005 5 741f.4a92.a2e7 3003 2 20 15 Po1
VLAN0400 400 741f.4a92.a2e7 3003 2 20 15 Po1
查看S6800 STP端口的状态:
<6800>dis stp brief
VLAN ID Port Role STP State Protection
4 Bridge-Aggregation7 DESI FORWARDING NONE
4 Bridge-Aggregation8 DESI FORWARDING NONE
4 Bridge-Aggregation9 DESI FORWARDING NONE
4 Bridge-Aggregation10 DESI FORWARDING NONE
4 Bridge-Aggregation11 DESI FORWARDING NONE
4 Bridge-Aggregation12 DESI FORWARDING NONE
4 Bridge-Aggregation13 DESI FORWARDING NONE
4 Bridge-Aggregation14 DESI FORWARDING NONE
4 Bridge-Aggregation15 DESI FORWARDING NONE
4 Bridge-Aggregation16 DESI FORWARDING NONE
4 Bridge-Aggregation18 DESI FORWARDING NONE
5 Bridge-Aggregation7 DESI FORWARDING NONE
5 Bridge-Aggregation8 DESI FORWARDING NONE
5 Bridge-Aggregation9 DESI FORWARDING NONE
5 Bridge-Aggregation10 DESI FORWARDING NONE
5 Bridge-Aggregation11 DESI FORWARDING NONE
5 Bridge-Aggregation12 DESI FORWARDING NONE
5 Bridge-Aggregation13 DESI FORWARDING NONE
5 Bridge-Aggregation14 DESI FORWARDING NONE
5 Bridge-Aggregation15 DESI FORWARDING NONE
5 Bridge-Aggregation16 DESI FORWARDING NONE
5 Bridge-Aggregation18 DESI FORWARDING NONE
7 Bridge-Aggregation7 DESI FORWARDING NONE
7 Bridge-Aggregation8 DESI FORWARDING NONE
7 Bridge-Aggregation9 DESI FORWARDING NONE
7 Bridge-Aggregation14 DESI FORWARDING NONE
7 Bridge-Aggregation15 DESI FORWARDING NONE
7 Bridge-Aggregation18 DESI FORWARDING NONE
12 Bridge-Aggregation7 DESI FORWARDING NONE
12 Bridge-Aggregation8 DESI FORWARDING NONE
12 Bridge-Aggregation9 DESI FORWARDING NONE
12 Bridge-Aggregation10 DESI FORWARDING NONE
12 Bridge-Aggregation11 DESI FORWARDING NONE
12 Bridge-Aggregation12 DESI FORWARDING NONE
12 Bridge-Aggregation13 DESI FORWARDING NONE
12 Bridge-Aggregation14 DESI FORWARDING NONE
12 Bridge-Aggregation15 DESI FORWARDING NONE
12 Bridge-Aggregation16 DESI FORWARDING NONE
12 Bridge-Aggregation18 DESI FORWARDING NONE
12 Ten-GigabitEthernet1/1/12 DESI FORWARDING NONE
196 Bridge-Aggregation7 DESI FORWARDING NONE
196 Bridge-Aggregation8 DESI FORWARDING NONE
196 Bridge-Aggregation9 DESI FORWARDING NONE
196 Bridge-Aggregation18 DESI FORWARDING NONE
400 Bridge-Aggregation7 DESI FORWARDING NONE
400 Bridge-Aggregation8 DESI FORWARDING NONE
400 Bridge-Aggregation9 DESI FORWARDING NONE
400 Bridge-Aggregation10 DESI FORWARDING NONE
400 Bridge-Aggregation11 DESI FORWARDING NONE
400 Bridge-Aggregation12 DESI FORWARDING NONE
400 Bridge-Aggregation13 DESI FORWARDING NONE
400 Bridge-Aggregation14 DESI FORWARDING NONE
400 Bridge-Aggregation15 DESI FORWARDING NONE
400 Bridge-Aggregation16 DESI FORWARDING NONE
400 Bridge-Aggregation18 DESI FORWARDING NONE
555 Bridge-Aggregation7 DESI FORWARDING NONE
555 Bridge-Aggregation8 DESI FORWARDING NONE
555 Bridge-Aggregation9 DESI FORWARDING NONE
555 Bridge-Aggregation18 DESI FORWARDING NONE
555 Ten-GigabitEthernet1/1/17 DESI FORWARDING NONE
555 Ten-GigabitEthernet1/1/18 DESI FORWARDING NONE
555 Ten-GigabitEthernet2/1/17 DESI FORWARDING NONE
555 Ten-GigabitEthernet2/1/18 DESI FORWARDING NONE
<6800>
查看思科2960的STP端口状态:
show spanning-tree detail active
VLAN0004 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 49152, sysid 4, address 2037.0604.0c00
Configured hello time 2, max age 20, forward delay 15
Current root has priority 4, address 741f.4a92.a2e7
Root port is 56 (Port-channel1), cost of root path is 3003
Topology change flag not set, detected flag not set
Number of topology changes 1607 last change occurred 1d10h ago
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0, aging 300
Uplinkfast enabled
Port 4 (GigabitEthernet0/4) of VLAN0004 is designated forwarding
Port path cost 3004, Port priority 128, Port Identifier 128.4.
Designated root has priority 4, address 741f.4a92.a2e7
Designated bridge has priority 49156, address 2037.0604.0c00
Designated port id is 128.4, designated path cost 3003
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
Link type is point-to-point by default
BPDU: sent 5103201, received 0
Port 56 (Port-channel1) of VLAN0004 is root forwarding
Port path cost 3003, Port priority 128, Port Identifier 128.56.
Designated bridge has priority 4, address 741f.4a92.a2e7
Designated port id is 128.524, designated path cost 0
Timers: message age 1, forward delay 0, hold 0
BPDU: sent 3179, received 14180965
VLAN0005 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 49152, sysid 5, address 2037.0604.0c00
Current root has priority 5, address 741f.4a92.a2e7
Number of topology changes 6 last change occurred 1d10h ago
Uplinkfast enabled
Port 56 (Port-channel1) of VLAN0005 is root forwarding
Designated root has priority 5, address 741f.4a92.a2e7
Designated bridge has priority 5, address 741f.4a92.a2e7
BPDU: sent 15, received 13553126
VLAN0400 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 49152, sysid 400, address 2037.0604.0c00
Current root has priority 400, address 741f.4a92.a2e7
Number of topology changes 17 last change occurred 1d10h ago
Uplinkfast enabled
Port 56 (Port-channel1) of VLAN0400 is root forwarding
Designated root has priority 400, address 741f.4a92.a2e7
Designated bridge has priority 400, address 741f.4a92.a2e7
Timers: message age 2, forward delay 0, hold 0
BPDU: sent 26, received 13457418
至此,S6800与思科2960对接PVST典型组网配置案例已完成!
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
