一台主机 8台AP 上网速度很慢
<AC>dis cur
version 5.20, ESS 3120
sysname AC
domain default enable system
telnet server enable
port-security enable
portal server local_for_Vlan-interface1 ip 192.168.20.240 server-type imc
portal local-server http
oap management-ip 192.168.0.101 slot 0
wlan auto-ap enable
vlan 1
vlan 10 to 11
vlan 15
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool 15
network 192.168.15.0 mask 255.255.255.240
gateway-list 192.168.15.1
dns-list 202.101.172.35 202.101.172.46
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$UWtFI3ITDQ+MWCceHGrRXlftnHuTzI8V
authorization-attribute level 3
service-type telnet
service-type web
wlan mesh-profile 1
mesh-id 1
bind WLAN-MESH 1
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
load-balance traffic 40
wlan radio-policy 1025
wlan radio-policy 1281
wlan radio-policy 1537
wlan radio-policy 1793
wlan radio-policy 2049
wlan radio-policy 257
wlan radio-policy 513
wlan radio-policy 769
wlan service-template 1 clear
ssid WNTEST
bind WLAN-ESS 0
wlan service-template 2 crypto
ssid ZJwinning-guest
bind WLAN-ESS 1
cipher-suite wep40
wep default-key 1 wep40 raw-key cipher $c$3$MikDIHOHTeGLC57sR++vTc47awhta62DHkCiaDY=
service-template enable
wlan ap-group default_group
ap ap1
ap ap2
ap ap3
ap ap4
ap ap5
ap ap6
ap ap7
ap ap8
dot11a service-template 1
dot11a service-template 2
dot11bg service-template 1
dot11bg service-template 2
dot11a radio enable
dot11bg radio enable
interface NULL0
interface Vlan-interface1
ip address 12.12.12.10 255.255.255.0
interface Vlan-interface15
ip address 192.168.15.1 255.255.255.0
port link-type trunk
port trunk permit vlan all
interface WLAN-ESS0
port access vlan 10
interface WLAN-ESS1
port link-type hybrid
port hybrid vlan 1 untagged
interface WLAN-MESH1
wlan ap ap1 model WA2612-AGN id 6
serial-id 210235A35WC11B000075
radio 1
channel 10
radio-policy 1537
service-template 1 vlan-id 11
service-template 2 vlan-id 10
bandwidth-guarantee enable
radio enable
wlan ap ap2 model WA2612-AGN id 4
serial-id 210235A35WC11B000071
radio 1
channel 10
radio-policy 1025
bandwidth-guarantee service-template 2 percent 100
radio enable
wlan ap ap3 model WA2612-AGN id 5
serial-id 210235A35WC11B000174
radio 1
channel 10
radio-policy 1281
radio enable
wlan ap ap4 model WA2612-AGN id 2
serial-id 210235A35WC11B000146
country-code CN
radio 1
channel 10
radio-policy 513
radio enable
wlan ap ap5 model WA2612-AGN id 1
serial-id 210235A35WC11B000106
radio 1
channel 10
radio-policy 257
radio enable
wlan ap ap6 model WA2612-AGN id 3
serial-id 210235A35WC11B000175
radio 1
channel 10
radio-policy 769
radio enable
wlan ap ap7 model WA2612-AGN id 8
serial-id 210235A35WC11B000067
radio 1
channel 10
radio-policy 2049
radio enable
wlan ap ap8 model WA2612-AGN id 7
serial-id 210235A35WC11B000077
radio 1
channel 10
radio-policy 1793
radio enable
wlan mobility-group 1
wlan load-balance-group 1
description 1
ap ap7 radio 1
ap ap8 radio 1
ap ap1 radio 1
ap ap3 radio 1
ap ap2 radio 1
ap ap6 radio 1
ap ap5 radio 1
ap ap4 radio 1
ip route-static 0.0.0.0 0.0.0.0 12.12.12.1
dhcp enable
mkd-service enable mesh-profile 1
wlan ap-authentication method serial-id
load xml-configuration
user-interface con 0
user-interface vty 0 4
user privilege level 3
set authentication password cipher $c$3$OZwqz1sYiahUwtwHOHZQIhGny37zVUZZz9KS
return
(0)
所有ap射频都工作在同一个信道10,能正常就怪了,先优化信道1/6/11进行部署吧
radio 1
channel 10
(0)
感谢大大 信道改了 1 6 11 请问大大其他是否能优化
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
过保的机器 400不给支持 机器过保 400让我来这里发帖,wlan小白一枚 只会RS
大大 比如要做哪些优化
http://kms.h3c.com/View.aspx?id=45058 可以查看此链接的通用优化指南,按照上述做优化。
