用户正常接入可以获取IP地址,三层漫游后终端获取不到IP地址,要等很久能可以获取到。本地转发,AC、DHCP 配置均无问题,是什么原因导致的 ?
AC:WX3510H AP:4320-ACN AC旁挂在思科核心上,DHCP在思科核心上。
(0)
这很难讲诶 有配置贴出来看看嘛
(0)
配置就是正常配置做的本地转发,DHCP在思科核心上。正常接入都没问题,三层漫游就获取不到IP地址
[XYKG-AC]dis c
[XYKG-AC]dis client-proximity-sensor
% Incomplete command found at '^' position.
[XYKG-AC] dis cu
[XYKG-AC]dis current-configuration
version 7.1.064, Release 5208P03
sysname XYKG-AC
telnet server enable
irf mac-address persistent timer
irf auto-update enable
irf auto-merge enable
irf member 1 priority 1
lldp global enable
password-recovery enable
vlan 1
vlan 50 to 51
irf-port 1
stp global enable
wlan service-template 1
ssid Sunriver-new
client forwarding-location ap
akm mode psk
preshared-key pass-phrase cipher $c$3$8gMBBtVn02hyhZ1wBaCMPFvUb+/67Ezu9oNL
cipher-suite ccmp
security-ie rsn
service-template enable
interface NULL0
interface Vlan-interface50
ip address 192.168.50.2 255.255.255.0
interface Vlan-interface51
ip address 192.168.51.1 255.255.255.0
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 50 to 51
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
line vty 0 31
authentication-mode scheme
ip route-static 0.0.0.0 0 192.168.51.254
undo info-center logfile enable
snmp-agent
snmp-agent local-engineid 800063A28074EACB7E4B3000000001
snmp-agent community read read
snmp-agent community write write
snmp-agent sys-info version all
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$64NmF3CkX/LDBK8W$1NB9k7LpNuG4xGRcQrYEEjW3GVxEjVNJMvc1JfX2r/ry8/W62hNlyFCOfzZfiNbQKqJTxhK89Uz1HRYFmCLyJg==
service-type telnet http https
authorization-attribute user-role level-15
ip https enable
wlan auto-ap enable
wlan auto-persistent enable
wlan global-configuration
wlan ap-group default-group
vlan 1
wlan ap a1701nw12 model WA5320
serial-id 219801A0YD8176E03958
map-configuration cfa0:/vlan23.txt
vlan 1
radio 1
radio enable
service-template 1 vlan 23
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1702wc13 model WA5320
serial-id 219801A0YD8176E03943
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1703sw14 model WA5320
serial-id 219801A0YD8176E03933
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1704sm15 model WA5320
serial-id 219801A0YD8176E05340
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1705se16 model WA5320
serial-id 219801A0YD8176E05330
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1706ne17 model WA5320
serial-id 219801A0YD8176E04973
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1707nm18 model WA5320
serial-id 219801A0YD8176E05283
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1801nw20 model WA5320
serial-id 219801A0YD8176E05357
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1803sw22 model WA5320
serial-id 219801A0YD8176E03884
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1804se23 model WA5320
serial-id 219801A0YD8176E04012
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1805ne24 model WA5320
serial-id 219801A0YD8176E03960
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1806nm25 model WA5320
serial-id 219801A0YD8176E03885
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1901nw27 model WA5320
serial-id 219801A0YD8176E03952
map-configuration cfa0:/vlan31.txt
vlan 1
radio 1
radio enable
service-template 1 vlan 31
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1902wc28 model WA5320
serial-id 219801A0YD8176E03972
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1903sw29 model WA5320
serial-id 219801A0YD8176E03999
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1904sm30 model WA5320
serial-id 219801A0YD8176E04002
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1905se31 model WA5320
serial-id 219801A0YD8176E03970
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1906ne32 model WA5320
serial-id 219801A0YD8176E05448
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a1907nm33 model WA5320
serial-id 219801A0YD8176E03982
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2001nw34 model WA5320
serial-id 219801A0YD8176E03986
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2002sw35 model WA5320
serial-id 219801A0YD8176E05399
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2003se36 model WA5320
serial-id 219801A0YD8176E05412
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2004ne37 model WA5320
serial-id 219801A0YD8176E03995
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2005nm38 model WA5320
serial-id 219801A0YD8176E05470
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2101nw39 model WA5320
serial-id 219801A0YD8176E05156
map-configuration cfa0:/vlan39.txt
vlan 1
radio 1
radio enable
service-template 1 vlan 39
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2102sw40 model WA5320
serial-id 219801A0YD8176E03964
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2103wc41 model WA5320
serial-id 219801A0YD8176E05416
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2301nw55 model WA5320
serial-id 219801A0YD8176E05405
map-configuration cfa0:/vlan47.txt
vlan 1
radio 1
radio enable
service-template 1 vlan 47
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2302sw56 model WA5320
serial-id 219801A0YD8176E05378
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2303sm57 model WA5320
serial-id 219801A0YD8176E05414
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2304se58 model WA5320
serial-id 219801A0YD8176E05424
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2305ne59 model WA5320
serial-id 219801A0YD8176E05359
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2306nm60 model WA5320
serial-id 219801A0YD8176E05312
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
wlan ap a2308er62 model WA5320
serial-id 219801A0YD8176E05270
vlan 1
radio 1
radio enable
radio 2
radio enable
gigabitethernet 1
gigabitethernet 2
return
[XYKG-AC]
[XYKG-AC]
(0)
我也遇到这个问题,只要开启快速漫游,三层漫游过去会获取不到ip,苹果变169开头的ip上不了网,关闭快速漫游后就正常,会带vlan和ip漫游到新ap,开启快速漫游关闭vlan保持,同样正常,只不过会连接新ap就获取一次地址。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
本地转发三层漫游时,从A区域漫游到B区域后发现AP上会自动创建A区域的vlan,在AC上查看client 发现vlan信息还是A区域的,那么我的接入交换机需要创建A区域的vlan信息?
漫游对于AC而言就是保证vlan不变,对于上线过的用户,AC会默认保持vlan信息180s,所以本地转发就必须要保证交换机将业务vlan放过去(集中只要管理vlan就行)。如果sta跑到其他区域需要vlan改变,那种就不是纯粹的漫游,最多叫重新接入
但是我遇到sta跑到其他区域后AP上会自动生成之前区域的vlan信息,这个是什么机制呢 ?sta跑到其他区域后仍然使用之前区域的vlan信息导致用户获取不到IP地址。
这个就是漫游的机制啊(各个厂家不太一样),保持原来的地址信息不变。有一条命令client cache aging-time 可以控制,配置成0就是不继承原先的vlan信息
