看了手册里ip接入方式配置案例,似乎客户端这边需要固定IP,客户端无固定IP可以连接吗?
(0)
客户端这边不需要固定IP也可以,只要确保客户端的基础网络能到SSL VPN网关就可以进行IP接入了。
以下是SSL VPN IP接入的配置关键点:
[SSL_VPN]acl advanced 3000
[SSL_VPN-acl-ipv4-adv-3000]rule 0 permit ip source any
[SSL_VPN-acl-ipv4-adv-3000]quit
[SSL_VPN]sslvpn ip address-pool weijianing 172.16.1.2 172.16.1.254
[SSL_VPN]int SSLVPN-AC 1
[SSL_VPN-SSLVPN-AC1]ip address 172.16.1.1 24
[SSL_VPN-SSLVPN-AC1]quit
[SSL_VPN]security-zone name Untrust
[SSL_VPN-security-zone-Untrust]import interface SSLVPN-AC 1
[SSL_VPN-security-zone-Untrust]quit
[SSL_VPN]sslvpn gateway james
[SSL_VPN-sslvpn-gateway-james]ip address 10.1.1.1
[SSL_VPN-sslvpn-gateway-james]service enable
[SSL_VPN-sslvpn-gateway-james]quit
[SSL_VPN]sslvpn context james
[SSL_VPN-sslvpn-context-james]gateway james
[SSL_VPN-sslvpn-context-james]ip-tunnel address-pool weijianing mask 24
[SSL_VPN-sslvpn-context-james]ip-tunnel interface SSLVPN-AC 1
[SSL_VPN-sslvpn-context-james]ip-route-list james
[SSL_VPN-sslvpn-context-james-route-list-james]include 10.0.0.0 24
[SSL_VPN-sslvpn-context-james-route-list-james]quit
[SSL_VPN-sslvpn-context-james-policy-group-ip]ip
[SSL_VPN-sslvpn-context-james-policy-group-ip]ip-tunnel access-route ip-route-list james
[SSL_VPN-sslvpn-context-james-policy-group-ip]filter ip-tunnel acl 3000
[SSL_VPN-sslvpn-context-james-policy-group-ip]quit
[SSL_VPN-sslvpn-context-james]service enable
[SSL_VPN-sslvpn-context-james]quit
[SSL_VPN]local-user weijianing class network
New local user added.
[SSL_VPN-luser-network-weijianing]password simple weijianing
[SSL_VPN-luser-network-weijianing]service-type sslvpn
[SSL_VPN-luser-network-weijianing]authorization-attribute sslvpn-policy-group ip
[SSL_VPN-luser-network-weijianing]quit
(0)
ssl vpn 只能访问内网的资源吗,不能通过网关代理访问公网资源吗,我设置了两个web资源 一个内网 一个公网(有白名单限制IP访问)内网的web地址可以访问,公网的不行
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
