M9016
2021-09-03提问
  • 1收藏,1040浏览
M9016的日志一直显示snmp的信息,snmp的配置中配置了一条snmp-agent log all,这个是不是网管对设备进行操作时,操作会记录在设备的日志中,这个关闭后(undo snmp-agent log),会有影响吗?
单看这些日志的话,这些snmp的信息是些什么意思?
%Sep 2 19:30:15:641 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241672-srcIP=10.213.54.78-op=GET-node=sysObjectID(1.3.6.1.2.1.1.2.0)-value=; The agent received a message.
 %Sep 2 19:30:15:653 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241673-srcIP=10.213.54.78-op=GET-node=enterprises(1.3.6.1.4.1.2011.2.2.4.13.0)-value=-node=enterprises(1.3.6.1.4.1.2011.2.2.5.1.0)-value=-node=enterprises(1.3.6.1.4.1.2011.2.2.5.2.0)-value=; The agent received a message.
 %Sep 2 19:30:15:798 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241674-srcIP=10.213.54.78-op=GET-node=sysObjectID(1.3.6.1.2.1.1.2.0)-value=; The agent received a message.
 %Sep 2 19:30:15:810 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241675-srcIP=10.213.54.78-op=GET-node=enterprises(1.3.6.1.4.1.2011.2.23.1.18.1.3.0)-value=; The agent received a message.
%Sep 2 19:35:00:093 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241676-srcIP=10.213.54.78-op=GET-node=sysObjectID(1.3.6.1.2.1.1.2.0)-value=; The agent received a message.
%Sep 2 19:35:00:111 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241677-srcIP=10.213.54.78-op=GET-node=ifHCInOctets(1.3.6.1.2.1.31.1.1.1.6.25)-value=-node=ifHCOutOctets(1.3.6.1.2.1.31.1.1.1.10.25)-value=-node=ifHCInUcastPkts(1.3.6.1.2.1.31.1.1.1.7.25)-value=-node=ifHCOutUcastPkts(1.3.6.1.2.1.31.1.1.1.11.25)-value=-node=ifInNUcastPkts(1.3.6.1.2.1.2.2.1.12.25)-value=-node=ifOutNUcastPkts(1.3.6.1.2.1.2.2.1.18.25)-value=-node=ifInDiscards(1.3.6.1.2.1.2.2.1.13.25)-value=-node=ifOutDiscards(1.3.6.1.2.1.2.2.1.19.25)-value=-node=ifInErrors(1.3.6.1.2.1.2.2.1.14.25)-value=-node=ifOutErrors(1.3.6.1.2.1.2.2.1.20.25)-value=-node=ifInUnknownProtos(1.3.6.1.2.1.2.2.1.15.25)-value=; The agent received a message.
 %Sep 2 19:35:17:264 2021 BZHFW04BHS-SCL6-M9016-V SNMP/6/SNMP_GET: -seqNO=241678-srcIP=10.213.54.78-op=GET-node=sysObjectID(1.3.6.1.2.1.1.2.0)-value=; The agent received a message.
粉丝:39人 关注:6人
看下10.213.54.78这个IP是否是网管服务器,如果是,说明网管服务器正在使用snmp协议采集设备的信息。
粉丝:119人 关注:1人
# 打开Agent的SNMP日志开关,对NMS的GET和SET操作进行记录。
[Agent] snmp-agent log all
这个是打开记录网管系统对设备操作的日志记录功能
