S5560-54C-EI
2021-09-06提问
  • 1收藏,682浏览
对齐方式
  • 靠左
  • 居中
  • 靠右
系统不启动
 ******************************************************************************** * * * H3C S5560-54C-EI BOOTROM, Version 123 * * * ******************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Creation Date : Jan 15 2016, 17:26:20 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/s5560ei-cmw710-system-r1121.bin............................. .................................Done. Loading file flash:/s5560ei-cmw710-boot-r1121.bin.............Done. Image file flash:/s5560ei-cmw710-boot-r1121.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ...................................................................
.Done. System is starting...
Cryptographic algorithms tests passed.
到这步后不再启动,请问什么问题
粉丝:39人 关注:6人
重新导入一个新的软件版本文件看下:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S5560/H3C_S5560EI/?CHID=192380&v=612
用户名:yx800
密码:01230123
注意查看软件版本说明书,有适配和导入的说明!
重新装过后还是到这一步就不走了
zhiliao_h19Pp 发表时间:2021-09-06
aUtiSm 九段
粉丝:48人 关注:1人
通过bootroom界面刷个新版本进入试试
重新安装还是到这个介面就不走了
系统版本没错吧,https://www.h3c.com/cn/d_202107/1423966_30005_40.htm试一下这个
aUtiSm 发表时间:2021-09-06
