对齐方式
系统不启动
******************************************************************************** * * * H3C S5560-54C-EI BOOTROM, Version 123 * * * ******************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Creation Date : Jan 15 2016, 17:26:20 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/s5560ei-cmw710-system-r1121.bin............................. .................................Done. Loading file flash:/s5560ei-cmw710-boot-r1121.bin.............Done. Image file flash:/s5560ei-cmw710-boot-r1121.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ...................................................................
.Done. System is starting...
Cryptographic algorithms tests passed.
到这步后不再启动,请问什么问题
(0)
重新导入一个新的软件版本文件看下:
用户名:yx800
密码:01230123
注意查看软件版本说明书,有适配和导入的说明!
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
重新装过后还是到这一步就不走了
