5560-54C-Ei 启动一半不启动
2021-09-06提问
  • 1收藏,733浏览
S5560-54C-EI 系统不启动
Press Ctrl+D to access BASIC BOOT MENU Press Ctrl+T to start heavy memory test ******************************************************************************** * * * H3C S5560-54C-EI BOOTROM, Version 123 * * * ******************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Creation Date : Jan 15 2016, 17:26:20 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files...
Loading file flash:/s5560ei-cmw710-system-r1121.bin............................. .................................Done. Loading file flash:/s5560ei-cmw710-boot-r1121.bin.............Done.
 Image file flash:/s5560ei-cmw710-boot-r1121.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ....................................................................Done.
System is starting...
Cryptographic algorithms tests passed.
启动到这里不再启动了,
重新升级系统还是一样:
 * * * H3C S5560-54C-EI BOOTROM, Version 128 * * * ******************************************************************************** Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. Creation Date : Nov 7 2019, 17:51:37 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb
Loading file flash:/s5560ei-cmw710-system-r3507.bin............................. .......................................................Done.
Loading file flash:/s5560ei-cmw710-freeradius-r3507.bin....Done.
Loading file flash:/s5560ei-cmw710-boot-r3507.bin..........Done.
 Image file flash:/s5560ei-cmw710-boot-r3507.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ............................................................................. Done.
还是启动到这里不再启动了
多等几分钟看看,你所贴出来的启动过程都是正常的,在最末尾的那些内容显示之后,有几分钟时间是没有任何内容输出的,正常的设备启动过程就是如此
粉丝:119人 关注:1人
400返厂维修
你这种是哪坏了
zhiliao_h19Pp 发表时间:2021-09-06
回复zhiliao_h19Pp:
硬件故障,我上2个月也遇到过,1台防火墙,重启下就进不去了
叫我靓仔 发表时间:2021-09-06
粉丝:11人 关注:0人
看启动过程没报错,等几分钟还是这样?是否单风扇启动?
两个风扇都在工作
粉丝:8人 关注:1人
过程是没问题的 没再等等嘛 这个过程以后应该还得等3-4分钟才能到正常的界面里
等了大约10分种不是不启动,最长等了30分钟
回车 敲了没 他应该有个提示 按回车 然后出现回显
小小卖药郎 发表时间:2021-09-06
