S5560-54C-EI 系统不启动
Press Ctrl+D to access BASIC BOOT MENU Press Ctrl+T to start heavy memory test ******************************************************************************** * * * H3C S5560-54C-EI BOOTROM, Version 123 * * * ******************************************************************************** Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd. Creation Date : Jan 15 2016, 17:26:20 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files...
Loading file flash:/s5560ei-cmw710-system-r1121.bin............................. .................................Done. Loading file flash:/s5560ei-cmw710-boot-r1121.bin.............Done.
Image file flash:/s5560ei-cmw710-boot-r1121.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ....................................................................Done.
System is starting...
Cryptographic algorithms tests passed.
启动到这里不再启动了,
重新升级系统还是一样:
* * * H3C S5560-54C-EI BOOTROM, Version 128 * * * ******************************************************************************** Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. Creation Date : Nov 7 2019, 17:51:37 CPU Clock Speed : 1000MHz Memory Size : 2048MB Flash Size : 512MB CPLD Version : 003 PCB Version : Ver.A Mac Address : 74eacb66f5eb
Loading file flash:/s5560ei-cmw710-system-r3507.bin............................. .......................................................Done.
Loading file flash:/s5560ei-cmw710-freeradius-r3507.bin....Done.
Loading file flash:/s5560ei-cmw710-boot-r3507.bin..........Done.
Image file flash:/s5560ei-cmw710-boot-r3507.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ............................................................................. Done.
还是启动到这里不再启动了
(0)
过程是没问题的 没再等等嘛 这个过程以后应该还得等3-4分钟才能到正常的界面里
(0)
等了大约10分种不是不启动,最长等了30分钟
回车 敲了没 他应该有个提示 按回车 然后出现回显
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
