WAC361
2018-06-30提问
  • 1收藏,1495浏览
wac361 强制断电了。在来电启动,web管理界面进不去,xshell也进不去。ap发射不了无线,按reset 后,通过超级终端进去。提示 主应用程序文件不存在-flash
备份应该程序不存在
安全应用程序不存在
启动应用程序失败!
请问怎么解决?我下载了WAC360-CMW520-E3703P48.bin 固件,求刷固件教程?哪位大神告知下
粉丝:20人 关注:3人
按提示  ctrl+b进入boot menu 菜单
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                       |
|<3> Enter Ethernet SubMenu                                                    |
|<4> File Control        |
|<5> Restore to Factory Default Configuration                                         |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 3    //进入以太网子菜单
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                           |
|<1> Download Application Program To SDRAM And Run                      |
|<2> Update Main Application File                                          |
|<3> Update Backup Application File                                        |
|<4> Update Secure Application File                                         |
|<5> Modify Ethernet Parameter                                           |
|<0> Exit To Main Menu                                                   |
|<Ensure The Parameter Be Modified Before Downloading!>                      |
Enter your choice(0-5): 5   //修改以太口参数
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                           |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                             |
Protocol (FTP or TFTP)  :tftp
Load File Name         :WAC360-CMW520-E3703P48.bin
                      :WAC360-CMW520-E3703P48.bin   //输入您wac的版本名字
Target File Name       :WAC360-CMW520-E3703P48.bin
Server IP Address      :192.168.1.1      电脑的IP地址,网上下载一个3CDaemon做TFTP server
Local IP Address       :192.168.1.2
Gateway IP Address     :0.0.0.0
Enter your choice(0-5): 2  //选择2下载到flash中设置为主文件
Loading.....................................................................
...................................Done!
9076736 bytes downloaded!
Updating File flash:/WAC360-CMW520-E3703P48.bin.......................................
zhiliao_C6tVU 知了小白
这种错误,刷固件刷不成功。。。
