没有跳过密码的话就选跳过当前配置文件启动,然后把配置文件导出来。注意在文件导出前不要save保存,不然会被覆盖掉。
Skip current system configuration跳过当前配置文件启动。
Press Ctrl+B to access EXTENDED BOOT MENU...0
Password recovery capability is enabled.
EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
9. Set The Operating Device
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Ctrl+C: Display Copyright
<H3C>more startup.cfg
version 7.1.075, Alpha 7571
sysname H3C
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
(1)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
