ac上开新开个SSID 拿不到DHCP
DHCP 池是做再核心上的
VLAN 10那个可以拿到DHCP
VLAN 11拿不到
AC配置
wlan service-template 1 crypto
ssid ZJwinning
bind WLAN-ESS 0
cipher-suite wep40
wep default-key 2 wep40 raw-key cipher $c$3$bBcuT4PguJ/YDQ9tElyS+S9HTPgSpz3RG2idZ2Y=
wep key-id 2
client-rate-limit direction inbound mode static cir 512
client-rate-limit direction outbound mode static cir 2048
service-template enable
wlan service-template 2 crypto
ssid ZJwinning-guest
bind WLAN-ESS 1
cipher-suite wep40
wep default-key 1 wep40 raw-key cipher $c$3$MikDIHOHTeGLC57sR++vTc47awhta62DHkCiaDY=
wlan ap-group default_group
ap ap1
ap ap2
ap ap3
ap ap4
ap ap5
ap ap6
ap ap7
ap ap8
dot11a service-template 1
dot11a service-template 2
dot11bg service-template 1
dot11bg service-template 2
dot11a radio enable
dot11bg radio enable
interface NULL0
interface Vlan-interface1
ip address 12.12.12.10 255.255.255.0
interface Vlan-interface15
ip address 192.168.15.1 255.255.255.0
port link-type trunk
port trunk permit vlan all
interface WLAN-ESS0
port link-type hybrid
port hybrid vlan 1 untagged
interface WLAN-ESS1
interface WLAN-MESH1
wlan ap ap1 model WA2612-AGN id 6
serial-id 210235A35WC11B000075
undo broadcast-probe reply
radio 1
channel 1
radio-policy 1537
service-template 1 vlan-id 11
service-template 2 vlan-id 10
mesh-profile 1
bandwidth-guarantee enable
radio enable
wlan ap ap2 model WA2612-AGN id 4
serial-id 210235A35WC11B000071
radio 1
channel 6
radio-policy 1025
mesh-profile 1
bandwidth-guarantee service-template 2 percent 100
radio enable
wlan ap ap3 model WA2612-AGN id 5
serial-id 210235A35WC11B000174
radio 1
channel 11
radio-policy 1281
mesh-profile 1
radio enable
wlan ap ap4 model WA2612-AGN id 2
serial-id 210235A35WC11B000146
country-code CN
radio 1
channel 1
radio-policy 513
mesh-profile 1
radio enable
wlan ap ap5 model WA2612-AGN id 1
serial-id 210235A35WC11B000106
radio 1
channel 6
radio-policy 257
mesh-profile 1
radio enable
wlan ap ap6 model WA2612-AGN id 3
serial-id 210235A35WC11B000175
radio 1
channel 11
radio-policy 769
mesh-profile 1
radio enable
——————————————————————核心————————————
这里VLAN
Interface Link Protocol Main IP Description
M-E0/0/0 DOWN DOWN --
NULL0 UP UP(s) --
Vlan1 UP UP 12.12.12.1
Vlan4 UP UP 192.168.4.1
Vlan5 UP UP 192.168.5.1
Vlan6 UP UP 192.168.6.1
Vlan10 UP UP 192.168.10.1
Vlan11 UP UP 192.168.11.1
Vlan20 UP UP 192.168.20.1
Vlan30 UP UP 192.168.30.1
下面是DHCP池
Pool name: vlan40
network 192.168.40.0 mask 255.255.255.0
PrevSibling node:vlan4
Sibling node:vlan5
gateway-list 192.168.40.1
dns-list 202.101.172.35 192.168.200.1
expired 1 0 0
Pool name: vlan5
network 192.168.5.0 mask 255.255.255.0
PrevSibling node:vlan40
Sibling node:vlan6
gateway-list 192.168.5.1
expired 1 0 0
Pool name: vlan6
network 192.168.6.0 mask 255.255.255.0
PrevSibling node:vlan5
Sibling node:vlan10
gateway-list 192.168.6.1
expired 1 0 0
Pool name: vlan10
network 192.168.10.0 mask 255.255.255.0
PrevSibling node:vlan6
Sibling node:vlan11
gateway-list 192.168.10.1
expired 1 0 0
Pool name: vlan11
network 192.168.11.0 mask 255.255.255.0
PrevSibling node:vlan10
gateway-list 192.168.11.1
expired 1 0 0
<CRsw>dis ip int b
*down: administratively down
————————————————-AC上的二层——————
这个二层应该没关系吧
<SH6D-SW-WX3024>dis vlan
Total 4 VLAN exist(s).
The following VLANs exist:
1(default), 10-11, 15
(0)
wlan service-template 2 添加 wep key-id 1 试试呢
(0)
意思就是SSID 1 用 default-key 1 ssid2 用 default-key 2 是这样理解吗?
可以这样尝试下 看看效果,WEP加密方式因为不安全性使用场景逐渐降低,换用wpa2方式的加密更加安全可靠
AC上没WPA2 这个选项
(1) 配置AC # 启用端口安全。 <AC> system-view [AC] port-security enable # 配置无线端口安全,使用PSK认证方式,预共享密钥为12345678。 [AC] interface wlan-ess 10 [AC-WLAN-ESS10] port-security port-mode psk [AC-WLAN-ESS10] port-security preshared-key pass-phrase 12345678 [AC-WLAN-ESS10] port-security tx-key-type 11key # 创建服务模板10(加密类型服务模板),配置SSID为psktest,将WLAN-ESS10接口绑定到服务模板10。 [AC] wlan service-template 10 crypto [AC-wlan-st-10] ssid psktest [AC-wlan-st-10] bind WLAN-ESS 10 [AC-wlan-st-10] security-ie rsn [AC-wlan-st-10] cipher-suite ccmp [AC-wlan-st-10] authentication-method open-system [AC-wlan-st-10] service-template enable [AC-wlan-st-10] quit
http://www.h3c.com/cn/Service/Document_Center/Wlan/WX/H3C_WX3000/Configure/Operation_Manual/H3C_CG(E3703P61_R2509P61_R3709P61)-6W108/02/201707/1012201_30005_0.htm 1.4 WLAN安全典型配置举例 1.4.1 PSK认证典型配置举例
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
[AC-wlan-st-1]service-template enable Error: Wireless Service: ZJwinning-guest in [AP - ap7, Radio - 1] uses the same key-id 大大何解
