MIB库
2022-01-01提问
  • 1收藏,1370浏览
设置列表
  • 有序列表
  • 无序列表
想问一下,
1: sysDescr.0 H3C Comware Platform Software, Software Version 7.1.059, Release 0305P04 H3C MSR56-60 Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
2: sysObjectID.0 enterprises.25506.1.771
3: sysUpTime.0 114 days, 7:47:48.79
4: sysContact.0 temp
5: sysName.0 TS_DX_MSR5660
6: sysLocation.0 Hangzhou, China
7: sysServices.0 78
这个设备的nqa的MIB库在哪儿寻找,MIB-BROWSER软件有下载的地方吗
粉丝:20人 关注:3人
mib库都是通用的,
MIB-新华三集团-H3C
MIB-BROWSER收费的只能百度了
可以百度net-snmp小软件读取测试
HH3C-NQA-MIB
This MIB should be supported by device which implements disman ping function. This MIB cannot mix using with CLI.
Scalar objects
Object (OID)
Access
PDS
Comments
hh3cNqaMIBVersion (1.3.6.1.4.1.25506.8.3.1.1)
read-only
No
As per MIB
hh3cNqaAgentEnable (1.3.6.1.4.1.25506.8.3.1.5)
read-write
Current
Default value is enable(1).
hh3cNqaServerEnable (1.3.6.1.4.1.25506.8.3.1.8)
read-write
Current
As per MIB
hh3cNqaStatsMaxGroupNumber (1.3.6.1.4.1.25506.8.3.1.9)
read-only
Current
As per MIB
hh3cNqaCtlTable
OID: 1.3.6.1.4.1.25506.8.3.1.2
·          The parameter which is not supported by the corresponding pingCtlType cannot be configured.
·          Once the configuration is modified, the result, histories, and statistics of the corresponding entry will be cleared.
·          The results, histories and statistics must be the factual reflection of the test results of current configurations.
·          Users will be puzzled when they get the results which caused by the previous configurations.
·          If the parameter which is not supported by the corresponding pingCtlType is read, the result is invalid.
·          The following table shows the relationship between pingCtlType and parameters.
Value of pingCtlType
Support parameters
pingIcmpEcho
hh3cNqaCtlTTL
hh3cNqaCtlHistoryKeptTime
hh3cNqaCtlHistoryEnable
hh3cNqaCtlVPNInstance
pingUdpEcho
hh3cNqaUdpEcho
hh3cNqaCtlTargetPort
hh3cNqaCtlSourcePort
hh3cNqaCtlTTL
pingSnmpQuery
hh3cNqaCtlTTL
pingTcpConnectionAttempt
hh3cNqaTcpconnect
hh3cNqaCtlTTL
hh3cNqajitter ( for UDP-jitter test )
hh3cNqaCtlCodecType is defined as notDefined(1)
hh3cNqaCtlTTL
hh3cNqaCtlJitterAdminInterval
hh3cNqaCtlJitterAdminNumPackets
hh3cNqaCtlCodecType
hh3cNqajitter ( for voice test )
hh3cNqaCtlCodecType is defined as g711Alaw(2)g711Ulaw(3) or g729A(4)
hh3cNqaCtlTTL
hh3cNqaCtlICPIFAdvFactor
hh3cNqaCtlCodecType
hh3cNqajitter ( for ICMP-jitter test )
hh3cNqaCtlCodecType is defined as icmpTimestamp(5)
hh3cNqaCtlTTL
hh3cNqaCtlCodecType
hh3cNqaHttp
hh3cNqaCtlTTL
hh3cNqaCtlHttpOperationType
hh3cNqaCtlHttpOperationString
hh3cNqadlsw
hh3cNqaCtlTTL
hh3cNqadhcp
hh3cNqaftp
hh3cNqaCtlTTL
hh3cNqaCtlFtpOperationType
hh3cNqaCtlFtpUsername
hh3cNqaCtlFtpPassword
hh3cNqaCtlFtpOperationString
Object (OID)
Access
PDS
Comments
hh3cNqaCtlTargetPort (1.3.6.1.4.1.25506.8.3.1.2.1.1)
read-create
Current
Range from 0 to 65535
If the value of pingCtlType is “pingUdpEcho” or “pingTcpConnectionAttempt”, the value of this object must be 7.
If the value of pingCtlType is  "hh3cNqaUdpEcho" or "hh3cNqaTcpconnect", the value of this object cannot be 7.
hh3cNqaCtlSourcePort (1.3.6.1.4.1.25506.8.3.1.2.1.2)
read-create
Current
hh3cNqaCtlTTL (1.3.6.1.4.1.25506.8.3.1.2.1.3)
read-create
Current
Range from 1 to 255
hh3cNqaCtlJitterAdminInterval (1.3.6.1.4.1.25506.8.3.1.2.1.4)
read-create
Current
Range from 10 to 60000
hh3cNqaCtlJitterAdminNumPackets (1.3.6.1.4.1.25506.8.3.1.2.1.5)
read-create
Current
For ICMP-jitter and UDP-jitter tests, the value range is 10 to 1000,and the default value is 10.
For the voice test, the value range is 10 to 60000, and the default value is 1000.
The object is available only forICMP-jitter,  voice and UDP-jitter tests.
hh3cNqaCtlHttpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.6)
read-create
Current
As per MIB
hh3cNqaCtlHttpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.7)
read-create
Current
When config the raw type of hh3cNqaCtlHttpOperationType, the length of url is from 0 to 1023.
The following details are for the get and post type of hh3cNqaCtlHttpOperationType. This object include two
 parts, the first part is resource and the second is http version. The resource is a part of URL. The common format of URL is http://host/resource.
The length of resource is from 0 to 246 .
The resource is case-sensitive.
The version  supports “HTTP/1.0” and “HTTP/1.1”(case- insensitive).
The default value of this object is v1.0.
The value of this object must have one space and only one space. The space is the separator of resource and version.
If the value of this object is zero-length string, the resource and version are set to default value.
hh3cNqaCtlFtpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.8)
read-create
Current
As per MIB
hh3cNqaCtlFtpUsername (1.3.6.1.4.1.25506.8.3.1.2.1.9)
read-create
Current
As per MIB
hh3cNqaCtlFtpPassword (1.3.6.1.4.1.25506.8.3.1.2.1.10)
read-create
Current
As per MIB
hh3cNqaCtlFtpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.11)
read-create
Current
For put operation of hh3cNqaCtlFtpOperationType, the length of this object is from 1 to 200;
For get operation of hh3cNqaCtlFtpOperationType, the length of this object is from 1 to 247.
hh3cNqaCtlVPNInstance (1.3.6.1.4.1.25506.8.3.1.2.1.12)
read-create
Current
The length of this object is from 0 to 31.
If the product does not support VPN feature, this object cannot be set.
hh3cNqaCtlHistoryKeptTime (1.3.6.1.4.1.25506.8.3.1.2.1.13)
read-create
Current
As per MIB
hh3cNqaCtlHistoryEnable (1.3.6.1.4.1.25506.8.3.1.2.1.14)
read-create
Current
As per MIB
hh3cNqaCtlICPIFAdvFactor (1.3.6.1.4.1.25506.8.3.1.2.1.15)
read-create
Current
Range from 0 to 20
hh3cNqaCtlCodecType (1.3.6.1.4.1.25506.8.3.1.2.1.16)
read-create
Current
If the corresponding pingCtlType is not hh3cNqajitter, this object is invalid.
For the UDP-jitter test,  the corresponding pingCtlType is hh3cNqajitter and this object is set to notDefined.
For the voice test, the corresponding pingCtlType is hh3cNqajitter and this object is set to g711Alaw, g711Ulaw or g729A.
For the ICMP-jitter test, the corresponding pingCtlType is hh3cNqajitter and this object is set to icmpTimestamp.
 If the object value is changed to represent a new test type, the system performs the following operations:
·         Deletes the entry of the old test type.
Creates the entry of the new test type with default settings. The currently supported values are notDefined, g711Alaw, g711Ulaw, g729A and icmpTimestamp.
hh3cNqaResultsTable
OID: 1.3.6.1.4.1.25506.8.3.1.3
Object (OID)
Access
PDS
Comments
hh3cNqaResultsRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.3.1.1)
read-only
No
As per MIB
hh3cNqaResultsRttTimeouts (1.3.6.1.4.1.25506.8.3.1.3.1.2)
read-only
No
As per MIB
hh3cNqaResultsRttBusies (1.3.6.1.4.1.25506.8.3.1.3.1.3)
read-only
No
Not supported
hh3cNqaResultsRttNoConnections (1.3.6.1.4.1.25506.8.3.1.3.1.4)
read-only
No
As per MIB
hh3cNqaResultsRttDrops (1.3.6.1.4.1.25506.8.3.1.3.1.5)
read-only
No
As per MIB
hh3cNqaResultsRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.3.1.6)
read-only
No
As per MIB
hh3cNqaResultsRttStatsErrors (1.3.6.1.4.1.25506.8.3.1.3.1.7)
read-only
No
As per MIB
hh3cNqaResultsMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.8)
read-only
No
As per MIB
hh3cNqaResultsMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.9)
read-only
No
As per MIB
hh3cNqaResultsLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.3.1.10)
read-only
No
The value of this object reflects the drop rate of all kinds of tests included in DISMAN-PING-MIB MIB and HH3C-NQA-MIB MIB.
hh3cNqaResultsPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.3.1.11)
read-only
No
As per MIB
hh3cNqaResultsRttSum (1.3.6.1.4.1.25506.8.3.1.3.1.12)
read-only
No
As per MIB
hh3cNqaResultsNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.13)
read-only
No
As per MIB
hh3cNqaResultsMinDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.14)
read-only
No
As per MIB
hh3cNqaResultsSumDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.15)
read-only
No
As per MIB
hh3cNqaResultsSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.16)
read-only
No
As per MIB
hh3cNqaResultsNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.17)
read-only
No
As per MIB
hh3cNqaResultsMinDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.18)
read-only
No
As per MIB
hh3cNqaResultsSumDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.19)
read-only
No
As per MIB
hh3cNqaResultsSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.20)
read-only
No
As per MIB
hh3cNqaJitterStatsTable
OID: 1.3.6.1.4.1.25506.8.3.1.4
Object (OID)
Access
PDS
Comments
hh3cNqaJitterStatsNumOfRTT (1.3.6.1.4.1.25506.8.3.1.4.1.1)
read-only
No
As per MIB
hh3cNqaJitterStatsMinOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.2)
read-only
No
As per MIB
hh3cNqaJitterStatsMaxOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.3)
read-only
No
As per MIB
hh3cNqaJitterStatsNumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.4)
read-only
No
As per MIB
hh3cNqaJitterStatsSumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.5)
read-only
No
As per MIB
hh3cNqaJitterStatsSum2PositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.6)
read-only
No
As per MIB
hh3cNqaJitterStatsMinOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.7)
read-only
No
As per MIB
hh3cNqaJitterStatsMaxOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.8)
read-only
No
As per MIB
hh3cNqaJitterStatsNumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.9)
read-only
No
As per MIB
hh3cNqaJitterStatsSumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.10)
read-only
No
As per MIB
hh3cNqaJitterStatsSum2NegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.11)
read-only
No
As per MIB
hh3cNqaJitterStatsMinOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.12)
read-only
No
As per MIB
hh3cNqaJitterStatsMaxOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.13)
read-only
No
As per MIB
hh3cNqaJitterStatsNumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.14)
read-only
No
As per MIB
hh3cNqaJitterStatsSumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.15)
read-only
No
As per MIB
hh3cNqaJitterStatsSum2PositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.16)
read-only
No
As per MIB
hh3cNqaJitterStatsMinOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.17)
read-only
No
As per MIB
hh3cNqaJitterStatsMaxOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.18)
read-only
No
As per MIB
hh3cNqaJitterStatsNumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.19)
read-only
No
As per MIB
hh3cNqaJitterStatsSumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.20)
read-only
No
As per MIB
hh3cNqaJitterStatsSum2NegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.21)
read-only
No
As per MIB
hh3cNqaJitterStatsPacketLossSD (1.3.6.1.4.1.25506.8.3.1.4.1.22)
read-only
No
As per MIB
hh3cNqaJitterStatsPacketLossDS (1.3.6.1.4.1.25506.8.3.1.4.1.23)
read-only
No
As per MIB
hh3cNqaJitterStatsAvePositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.24)
read-only
No
If the difference between intervals from source to destination of two sequential packets within a group of packets is positive, statistical times should add 1, and statistical summation should add the difference. The value of this object is the result of following expression: (statistical summation)/ (statistical times).
hh3cNqaJitterStatsAveNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.25)
read-only
No
If the difference between intervals from source to destination of two sequential packets within a group of packets is negative, statistical times should add 1, and statistical summation should add the absolute value of the difference. The value of this object is the result of following expression: (statistical summation)/ (statistical times).
hh3cNqaJitterStatsAvePositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.26)
read-only
No
If the difference between intervals from destination to source of two sequential packets within a group of packets is positive, statistical times should add 1, and statistical summation should add the difference. The value of this object is the result of following expression: (statistical summation)/ (statistical times).
hh3cNqaJitterStatsAveNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.27)
read-only
No
If the difference between intervals from destination to source of two sequential packets within a group of packets is negative, statistical times should add 1, and statistical summation should add the absolute value of the difference. The value of this object is the result of following expression: (statistical summation)/( statistical times).
hh3cNqaJitterStatsPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.4.1.28)
read-only
No
The number of packets which lost but not knowing result
hh3cNqaJitterStatsOperOfICPIF (1.3.6.1.4.1.25506.8.3.1.4.1.29)
read-only
No
Only voice test is supported.
hh3cNqaJitterStatsOperOfMOS (1.3.6.1.4.1.25506.8.3.1.4.1.30)
read-only
No
Only voice test is supported the value of this object is 100 times of the actual value.
hh3cNqaJitterStatsAveSD (1.3.6.1.4.1.25506.8.3.1.4.1.31)
read-only
No
As per MIB
hh3cNqaJitterStatsAveDS (1.3.6.1.4.1.25506.8.3.1.4.1.32)
read-only
No
As per MIB
hh3cNqaTcpServerTable
OID: 1.3.6.1.4.1.25506.8.3.1.6
Object (OID)
Access
PDS
Comments
hh3cNqaTcpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.6.1.1)
not-accessible
Current
Only support ipv4 address.
hh3cNqaTcpServerPort (1.3.6.1.4.1.25506.8.3.1.6.1.2)
not-accessible
Current
Range from 1 to 65535
hh3cNqaTcpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.6.1.3)
read-create
Current
Only support active(1), createAndgo(4) and destroy(6)
hh3cNqaUdpServerTable
OID: 1.3.6.1.4.1.25506.8.3.1.7
Object (OID)
Access
PDS
Comments
hh3cNqaUdpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.7.1.1)
not-accessible
Current
hh3cNqaUdpServerPort (1.3.6.1.4.1.25506.8.3.1.7.1.2)
not-accessible
Current
hh3cNqaUdpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.7.1.3)
read-create
Current
Only support active(1) ,createAndgo(4) and destroy(6)
hh3cNqaStatisticsCtlTable
OID: 1.3.6.1.4.1.25506.8.3.1.10
Object (OID)
Access
PDS
Comments
hh3cNqaCtlStatisticsInterval (1.3.6.1.4.1.25506.8.3.1.10.1.1)
read-create
Current
Range from 1 to 35791394(in minutes), default value is 60.
hh3cNqaCtlStatisticsGroupNumber (1.3.6.1.4.1.25506.8.3.1.10.1.2)
read-create
Current
Range from 0 to hh3cNqaStatsMaxGroupNumber,
default value is 2.
If the value of this object is 0, statistics will not be created.
hh3cNqaCtlStatisticsKeptTime (1.3.6.1.4.1.25506.8.3.1.10.1.3)
read-create
Current
Range from 1 to 1440(in minutes), default value is 120.
hh3cNqaCtlBeginTime (1.3.6.1.4.1.25506.8.3.1.10.1.4)
read-create
Current
Time format must be abided. The year is range from 2000 to 2035.
hh3cNqaCtlLifeTime (1.3.6.1.4.1.25506.8.3.1.10.1.5)
read-create
Current
Range from 1 to 2147483647 (in seconds), The value of 4294967295 means the test will never stop.
hh3cNqaStatisticsResultsTable
OID: 1.3.6.1.4.1.25506.8.3.1.11
Object (OID)
Access
PDS
Comments
hh3cNqaStatResIndex (1.3.6.1.4.1.25506.8.3.1.11.1.1)
not-accessible
No
As per MIB
hh3cNqaStatResIpTargetAddressType (1.3.6.1.4.1.25506.8.3.1.11.1.2)
read-only
No
As per MIB
hh3cNqaStatResIpTargetAddress (1.3.6.1.4.1.25506.8.3.1.11.1.3)
read-only
No
As per MIB
hh3cNqaStatResMinRtt (1.3.6.1.4.1.25506.8.3.1.11.1.4)
read-only
No
As per MIB
hh3cNqaStatResMaxRtt (1.3.6.1.4.1.25506.8.3.1.11.1.5)
read-only
No
As per MIB
hh3cNqaStatResAverageRtt (1.3.6.1.4.1.25506.8.3.1.11.1.6)
read-only
No
As per MIB
hh3cNqaStatResProbeResponses (1.3.6.1.4.1.25506.8.3.1.11.1.7)
read-only
No
As per MIB
hh3cNqaStatResSentProbes (1.3.6.1.4.1.25506.8.3.1.11.1.8)
read-only
No
As per MIB
hh3cNqaStatResRttSumOfSquares (1.3.6.1.4.1.25506.8.3.1.11.1.9)
read-only
No
As per MIB
hh3cNqaStatResStartTime (1.3.6.1.4.1.25506.8.3.1.11.1.10)
read-only
No
As per MIB
hh3cNqaStatResInterval (1.3.6.1.4.1.25506.8.3.1.11.1.11)
read-only
No
As per MIB
hh3cNqaStatResRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.11.1.12)
read-only
No
As per MIB
hh3cNqaStatResRttTimeouts (1.3.6.1.4.1.25506.8.3.1.11.1.13)
read-only
No
As per MIB
hh3cNqaStatResRttBusies (1.3.6.1.4.1.25506.8.3.1.11.1.14)
read-only
No
As per MIB
hh3cNqaStatResRttNoConnections (1.3.6.1.4.1.25506.8.3.1.11.1.15)
read-only
No
As per MIB
hh3cNqaStatResRttDrops (1.3.6.1.4.1.25506.8.3.1.11.1.16)
read-only
No
As per MIB
hh3cNqaStatResRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.11.1.17)
read-only
No
As per MIB
hh3cNqaStatResRttErrors (1.3.6.1.4.1.25506.8.3.1.11.1.18)
read-only
No
As per MIB
hh3cNqaStatResLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.11.1.19)
read-only
No
As per MIB
hh3cNqaStatResPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.11.1.20)
read-only
No
As per MIB
hh3cNqaStatResRttSum (1.3.6.1.4.1.25506.8.3.1.11.1.21)
read-only
No
As per MIB
hh3cNqaStatResNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.22)
read-only
No
As per MIB
hh3cNqaStatResMinDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.23)
read-only
No
As per MIB
hh3cNqaStatResMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.24)
read-only
No
As per MIB
hh3cNqaStatResSumDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.25)
read-only
No
As per MIB
hh3cNqaStatResSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.26)
read-only
No
As per MIB
hh3cNqaStatResNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.27)
read-only
No
As per MIB
hh3cNqaStatResMinDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.28)
read-only
No
As per MIB
hh3cNqaStatResMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.29)
read-only
No
As per MIB
hh3cNqaStatResSumDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.30)
read-only
No
As per MIB
hh3cNqaStatResSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.31)
read-only
No
As per MIB
hh3cNqaGroupStatsJitterTable
OID: 1.3.6.1.4.1.25506.8.3.1.12
Object (OID)
Access
PDS
Comments
hh3cNqaStatJitterIndex (1.3.6.1.4.1.25506.8.3.1.12.1.1)
not-accessible
No
As per MIB
hh3cNqaStatJitterMinOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.2)
read-only
No
As per MIB
hh3cNqaStatJitterMaxOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.3)
read-only
No
As per MIB
hh3cNqaStatJitterNumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.4)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.5)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfSquarePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.6)
read-only
No
As per MIB
hh3cNqaStatJitterMinOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.7)
read-only
No
As per MIB
hh3cNqaStatJitterMaxOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.8)
read-only
No
As per MIB
hh3cNqaStatJitterNumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.9)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.10)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfSquareNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.11)
read-only
No
As per MIB
hh3cNqaStatJitterMinOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.12)
read-only
No
As per MIB
hh3cNqaStatJitterMaxOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.13)
read-only
No
As per MIB
hh3cNqaStatJitterNumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.14)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.15)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfSquarePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.16)
read-only
No
As per MIB
hh3cNqaStatJitterMinOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.17)
read-only
No
As per MIB
hh3cNqaStatJitterMaxOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.18)
read-only
No
As per MIB
hh3cNqaStatJitterNumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.19)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.20)
read-only
No
As per MIB
hh3cNqaStatJitterSumOfSquareNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.21)
read-only
No
As per MIB
hh3cNqaStatJitterPacketLossSD (1.3.6.1.4.1.25506.8.3.1.12.1.22)
read-only
No
As per MIB
hh3cNqaStatJitterPacketLossDS (1.3.6.1.4.1.25506.8.3.1.12.1.23)
read-only
No
As per MIB
hh3cNqaStatJitterAvePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.24)
read-only
No
As per MIB
hh3cNqaStatJitterAveNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.25)
read-only
No
As per MIB
hh3cNqaStatJitterAvePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.26)
read-only
No
As per MIB
hh3cNqaStatJitterAveNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.27)
read-only
No
As per MIB
hh3cNqaStatJitterPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.12.1.28)
read-only
No
As per MIB
hh3cNqaStatJitterMaxOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.29)
read-only
No
hh3cNqaStatJitterMinOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.30)
read-only
No
hh3cNqaStatJitterMaxOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.31)
read-only
No
Only voice test is supported ,the value of this object is 100 times of the actual value
hh3cNqaStatJitterMinOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.32)
read-only
No
hh3cNqaStatJitterAveSD (1.3.6.1.4.1.25506.8.3.1.12.1.33)
read-only
No
As per MIB
hh3cNqaStatJitterAveDS (1.3.6.1.4.1.25506.8.3.1.12.1.34)
read-only
No
As per MIB
hh3cNqaReactionTable
OID: 1.3.6.1.4.1.25506.8.3.1.13
Object (OID)
Access
PDS
Comments
hh3cNqaReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.13.1.1)
accessible-for-notify
No
As per MIB
hh3cNqaReactTestName (1.3.6.1.4.1.25506.8.3.1.13.1.2)
No
As per MIB
hh3cNqaReactItemIndex (1.3.6.1.4.1.25506.8.3.1.13.1.3)
No
As per MIB
hh3cNqaReactCheckedElement (1.3.6.1.4.1.25506.8.3.1.13.1.4)
read-create
No
As per MIB
hh3cNqaReactThresholdUpperLimit (1.3.6.1.4.1.25506.8.3.1.13.1.5)
read-create
No
Ranges from 1 to 100 when the value of hh3cNqaReactCheckedElement is "icpif".
Ranges from 1 to 500 when the value of hh3cNqaReactCheckedElement is "mos".
Ranges from 0 to 3600000 (in milliseconds) when the value of hh3cNqaReactCheckedElement is "jittersd", "jitterds", "jitterOwdSD", "jitterOwdDS", "jitterrtt" or "probetime".
The value of this object shouldn't be set in other cases.
hh3cNqaReactThresholdLowerLimit (1.3.6.1.4.1.25506.8.3.1.13.1.6)
read-create
No
hh3cNqaReactThresholdType (1.3.6.1.4.1.25506.8.3.1.13.1.7)
read-create
No
The value of this object can be set to "average" or "accumulative" when the value of hh3cNqaReactCheckedElement is "jittersd" or "jitterds".
The value of this object can be set to "accumulative" when the value of hh3cNqaReactCheckedElement is "jitterpacketloss".
The value of this object can be set to "average", "consecutive" or "accumulative" when the value of hh3cNqaReactCheckedElement is "probetime".
The value of this object can be set to "consecutive" or "accumulative" when the value of hh3cNqaReactCheckedElement is "probefailure".
The value of this object can be set to "average" or "accumulative" when the value of hh3cNqaReactCheckedElement is "jitterrtt".
hh3cNqaReactThresholdConsecNum (1.3.6.1.4.1.25506.8.3.1.13.1.8)
read-create
No
Ranges from 1 to 16 when the value of hh3cNqaReactCheckedElement is "probetime" or "probefailure".
hh3cNqaReactThresholdAccumNum (1.3.6.1.4.1.25506.8.3.1.13.1.9)
read-create
No
The object value range is 1 to 14999 if the value of hh3cNqaReactCheckedElement is "jittersd" or "jitterds" and the test type is ICMP-jitter or UDP-jitter.
The object value range is 1 to 59999 if the value of hh3cNqaReactCheckedElement is "jittersd" or "jitterds" and the test type is voice.
The object value range is 1 to 15000 if the value of hh3cNqaReactCheckedElement is "jitterpacketloss" or "jitterrtt" and the test type is ICMP-jitter or UDP-jitter.
The object value range is 1 to 60000 if the value of hh3cNqaReactCheckedElement is "jitterpacketloss" or "jitterrtt" and the test type is voice.
Ranges from 1 to 15 when the value of hh3cNqaReactCheckedElement is "probetime" or "probefailure".
hh3cNqaReactActionType (1.3.6.1.4.1.25506.8.3.1.13.1.10)
read-create
No
The value of this object can be set to "none" or "trapOnly" when the value of hh3cNqaReactCheckedElement is "icpif", "mos", "jittersd", "jitterds", "jitterpacketloss", "probetime" or "jitterrtt".
The value of this object can be set to "none", "trapOnly" or "triggerOnly" when the value of hh3cNqaReactCheckedElement is "probefailure".
hh3cNqaReactCurrentStatus (1.3.6.1.4.1.25506.8.3.1.13.1.11)
read-only
No
As per MIB
hh3cNqaReactRowStatus (1.3.6.1.4.1.25506.8.3.1.13.1.12)
read-create
No
As per MIB
hh3cNqaReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.13.1.13)
read-only
No
As per MIB
hh3cNqaReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.13.1.14)
read-only
No
As per MIB
hh3cNqaStatisticsReactionTable
OID: 1.3.6.1.4.1.25506.8.3.1.14
Object (OID)
Access
PDS
Comments
hh3cNqaStatReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.14.1.1)
not-accessible
No
As per MIB
hh3cNqaStatReactTestName (1.3.6.1.4.1.25506.8.3.1.14.1.2)
not-accessible
No
As per MIB
hh3cNqaStatReactIndex (1.3.6.1.4.1.25506.8.3.1.14.1.3)
not-accessible
No
As per MIB
hh3cNqaStatReactItemIndex (1.3.6.1.4.1.25506.8.3.1.14.1.4)
not-accessible
No
As per MIB
hh3cNqaStatReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.14.1.5)
read-only
No
As per MIB
hh3cNqaStatReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.14.1.6)
read-only
No
As per MIB
hh3cNqaTcpExtendServerTable
OID of this table is: 1.3.6.1.4.1.25506.8.3.1.15
Name
Access
PDS
hh3cNqaTcpServerExtIpAddress (1.3.6.1.4.1.25506.8.3.1.15.1.1)
not-accessible
Current
As per MIB
hh3cNqaTcpServerExtPort (1.3.6.1.4.1.25506.8.3.1.15.1.2)
not-accessible
Current
hh3cNqaTcpServerExtVPNType (1.3.6.1.4.1.25506.8.3.1.15.1.3)
not-accessible
Current
Only support public(1) and vpn(2).
hh3cNqaTcpServerExtVPNInstance
(1.3.6.1.4.1.25506.8.3.1.15.1.4)
not-accessible
Current
For set operation:
If the NQA server listens on the public network, the value of hh3cNqaTcpServerExtVPNType must be public(1) and the value of this object can be set to any non-printable character string.
If the NQA server listens on the private network, the value of hh3cNqaTcpServerExtVPNType must be vpn(2) and the value of this object can be set to any non-printable character string.
For get operation:
If the NQA server listens on the public network, the value of the objecet can be public
hh3cNqaTcpServerExtDSField (1.3.6.1.4.1.25506.8.3.1.15.1.5)
read-create
Current
As per MIB
hh3cNqaTcpServerExtRowStatus (1.3.6.1.4.1.25506.8.3.1.15.1.6)
read-create
Current
hh3cNqaUdpExtendServerTable
OID of this table is: 1.3.6.1.4.1.25506.8.3.1.16
Name
Access
PDS
hh3cNqaUdpServerExtIpAddress (1.3.6.1.4.1.25506.8.3.1.16.1.1)
not-accessible
Current
As per MIB
hh3cNqaUdpServerExtPort (1.3.6.1.4.1.25506.8.3.1.16.1.2)
not-accessible
Current
hh3cNqaUdpServerExtVPNType (1.3.6.1.4.1.25506.8.3.1.16.1.3)
not-accessible
Current
hh3cNqaUdpServerExtVPNInstance
 (1.3.6.1.4.1.25506.8.3.1.16.1.4)
not-accessible
Current
For set operation:
If the NQA server listens on the public network, the value of hh3cNqaUdpServerExtVPNType must be public(1) and the value of this object can be set to any non-printable character string.
If the NQA server listens on the private network, the value of hh3cNqaUdpServerExtVPNType must be vpn(2) and the value of this object can be set to any non-printable character string.
For get operation:
If the NQA server listens on the public network, the value of the objecet must be public.
hh3cNqaUdpServerExtDSField (1.3.6.1.4.1.25506.8.3.1.16.1.5)
read-create
Current
As per MIB
hh3cNqaUdpServerExtRowStatus (1.3.6.1.4.1.25506.8.3.1.16.1.6)
read-create
Current
收到
zhiliao_pSTYi 发表时间:2022-01-01
我用的SnmpB软件,读出的nqa的MIB值始终看不懂意思
粉丝:226人 关注:0人
您好,参考链接
常用mib清单-新华三集团-H3C
用户名:yx800
密码:01230123
好的,谢谢
