version 7.1.064, ESS 5568P01
sysname h3cAC
wlan global-configuration
telnet server enable
dhcp enable
lldp global enable
sysid H3
password-recovery enable
vlan 1
dhcp server ip-pool wifi
gateway-list 172.17.100.1
network 172.17.100.0 mask 255.255.254.0
dns-list 114.114.114.114
option 43 hex 800b000002ac116401
wlan service-template ymxy
ssid YMXY
client forwarding-location ap vlan 1
akm mode psk
preshared-key pass-phrase cipher $c$3$XY5DOv/X2Dxa4sZFEaOqdR7RkxHdID3ASSzwElA=
cipher-suite ccmp
security-ie rsn
service-template enable
interface NULL0
interface Vlan-interface1
ip address 172.17.100.1 255.255.254.0
port link-mode bridge
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface Ten-GigabitEthernet1/0/9
interface Ten-GigabitEthernet1/0/10
interface Smartrate-Ethernet1/0/11
port link-mode route
ip address 10.76.2.254 255.255.240.0
nat outbound
interface Smartrate-Ethernet1/0/12
scheduler logfile size 16
line class console
user-role network-admin
line class vty
user-role network-operator
line con 0
line vty 0 31
authentication-mode scheme
ip route-static 0.0.0.0 0 Smartrate-Ethernet1/0/11 10.76.0.1
不行
你终端获取的地址正常吗,包括dns ,后者手动配置地址
客户端地址就是vlan 1 网段,网关为vlan1,dns 手动设置114.114.114.114
我看你是本地转发,还使用的默认vlan,把业务地址换个地址段试试,本地转发,vlan1可能会有问题
