华三AC控制器NAT
2022-04-13提问
  • 1收藏,1030浏览
nat 设置后可以ping 通dns 但是无法上外网,访问外网的地址设置在tplink 路由器上可以正常上网
 version 7.1.064, ESS 5568P01
 sysname h3cAC
wlan global-configuration
 telnet server enable
 dhcp enable
 lldp global enable
 sysid H3
 password-recovery enable
vlan 1
dhcp server ip-pool wifi
 gateway-list 172.17.100.1
 network 172.17.100.0 mask 255.255.254.0
 dns-list 114.114.114.114
 option 43 hex 800b000002ac116401
wlan service-template ymxy
 ssid YMXY
 client forwarding-location ap vlan 1
 akm mode psk
 preshared-key pass-phrase cipher $c$3$XY5DOv/X2Dxa4sZFEaOqdR7RkxHdID3ASSzwElA=
 cipher-suite ccmp
 security-ie rsn
 service-template enable
interface NULL0
interface Vlan-interface1
 ip address 172.17.100.1 255.255.254.0
 port link-mode bridge
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface Ten-GigabitEthernet1/0/9
interface Ten-GigabitEthernet1/0/10
interface Smartrate-Ethernet1/0/11
 port link-mode route
 ip address 10.76.2.254 255.255.240.0
 nat outbound
interface Smartrate-Ethernet1/0/12
 scheduler logfile size 16
line class console
 user-role network-admin
line class vty
 user-role network-operator
line con 0
line vty 0 31
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Smartrate-Ethernet1/0/11 10.76.0.1
知了小白
粉丝: 关注:
能平通外网的dns 说明你路由已经做通了,在AC上[]wlan tcp mss 1280 试试
不行
zhiliao_jYi5F 发表时间:2022-04-13
你终端获取的地址正常吗,包括dns ,后者手动配置地址
发表时间:2022-04-13
回复:
客户端地址就是vlan 1 网段,网关为vlan1,dns 手动设置114.114.114.114
我看你是本地转发,还使用的默认vlan,把业务地址换个地址段试试,本地转发,vlan1可能会有问题
发表时间:2022-04-13
粉丝:119人 关注:1人
我看你的NAT接口地址是内网地址,DNS是多少
这个内网地址是可以访问外网的,dns 设置为114
回复zhiliao_jYi5F:
出口有没有配置防私接?
叫我靓仔 发表时间:2022-04-13
