交换机S5560S
2022-05-01提问
  • 1收藏,714浏览
进进入端口输入 port Link-mode bridge 显示错误
5 个回答
粉丝:25人 关注:7人
报的是啥?
常规报错含义见图表:
其他报错建议先复制出来用百度翻译来翻成中文看看。
另外问一句你是不是5560S-SI或者EI?我怀疑是你的软件版本太低了。你dis version看看。我刚才查了命令手册,611x版本没这个命令但是63xx有。
<H3C>sy System View: return to User View with Ctrl+Z. [H3C]int g1/0/3 [H3C-GigabitEthernet1/0/3]de [H3C-GigabitEthernet1/0/3]def [H3C-GigabitEthernet1/0/3]default This command will restore the default settings. Continue? [Y/N]:y [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3]port [H3C-GigabitEthernet1/0/3]port l [H3C-GigabitEthernet1/0/3]port link-m [H3C-GigabitEthernet1/0/3]port link-mode bridge ^ % Unrecognized command found at '^' position. [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3]qu [H3C]dis version H3C Comware Software, Version 7.1.070, Release 6126P20 Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved. H3C S5560S-28P-SI uptime is 0 weeks, 0 days, 9 hours, 15 minutes Last reboot reason : Cold reboot Boot image: flash:/s5560s_si-cmw710-boot-r6126p20.bin Boot image version: 7.1.070, Release 6126P20 Compiled Apr 03 2018 11:00:00 System image: flash:/s5560s_si-cmw710-system-r6126p20.bin System image version: 7.1.070, Release 6126P20 Compiled Apr 03 2018 11:00:00 Slot 1: Uptime is 0 weeks,0 days,9 hours,15 minutes S5560S-28P-SI with 1 Processor BOARD TYPE: S5560S-28P-SI DRAM: 512M bytes FLASH: 256M bytes PCB 1 Version: VER.B Bootrom Version: 121 CPLD 1 Version: 001 Release Version: H3C S5560S-28P-SI-6126P20 Patch Version : None Reboot Cause : ColdReboot [SubSlot 0] 24GE+4SFP
zhiliao_t3bg4T 发表时间:2022-05-01
我的是5560S-28P-SI 的
破案了,版本问题,你是6126版本,612x也没这个命令,参考:https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Switches/00-Public/Command/Command_Manual/H3C_S5560S-EI_S5560S-SI-CR-R612x-6W102/99/?CHID=366294
奇怪的流量 发表时间:2022-05-01
你升级版本吧。
软件版本下载链接:https://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S5560/H3C_S5560S-SI/
合作伙伴公共账号:yx800/01230123 具体升级操作参看相关版本的附录。
好的谢谢。我升级版本试试
粉丝:3人 关注:0人
什么报错
zhiliao_t3bg4T 知了小白
命令错误,^指在l上面
你是在以太网视图(interface GigabitEthernet)下输入的命令吗?
是的。是进入端口后输入的这个命令。研究了一天了
zhiliao_t3bg4T 知了小白
对就是显示命令无法解析,^位置出错,是不是端口有什么功能需要开启,我在 H3C 3600上面使用是正常的
知了小白
粉丝: 关注:
先default 恢复接口默认配置,之后在配置
int g1/0/1
default
This command will restore the default settings. Continue? [Y/N]:Y
interface GigabitEthernet 1/0/1
恢复了接口默认配置也是不行,设备买了一年的都没用。拿出来用就不行
你把报错的信息截图或者复制出来
发表时间:2022-05-01
我去升级版本试试
看到了你给别人的回复,升级版本吧,按照他给你的连接。
发表时间:2022-05-01
你要是用二层口,你进入到这个接口 看他是不是二层口,如果是 你就不用升级了,dis this
发表时间:2022-05-01
我感觉他本身就是二层口。你直接配trunk 或者access 就行
发表时间:2022-05-01
老版本的那时候还不支持直接在接口上配置IP地址,所以不支持port link-mode 。所以我说如果没有别的功能需求,你不用升级
发表时间:2022-05-01
我要用到port link-mode route 三层路由
port link-type trunk port link-type access
发表时间:2022-05-01
那你不升级的情况,给vlan配置个ip地址,接口属于这个vlan也相当于配置了个ip,能升级的话可以升级试试
发表时间:2022-05-01
好的谢谢
别客气
发表时间:2022-05-01
