进进入端口输入 port Link-mode bridge 显示错误
(1)
报的是啥?
常规报错含义见图表:
其他报错建议先复制出来用百度翻译来翻成中文看看。
另外问一句你是不是5560S-SI或者EI?我怀疑是你的软件版本太低了。你dis version看看。我刚才查了命令手册,611x版本没这个命令但是63xx有。
(1)
先default 恢复接口默认配置,之后在配置
int g1/0/1
default
This command will restore the default settings. Continue? [Y/N]:Y
interface GigabitEthernet 1/0/1
port link-mode bridge
(3)
恢复了接口默认配置也是不行,设备买了一年的都没用。拿出来用就不行
[H3C-GigabitEthernet1/0/3]port link-mode bridge ^ % Unrecognized command found at '^' position.
我去升级版本试试
我要用到port link-mode route 三层路由
好的谢谢
命令错误,^指在l上面
(0)
你是在以太网视图(interface GigabitEthernet)下输入的命令吗?
是的。是进入端口后输入的这个命令。研究了一天了
对就是显示命令无法解析,^位置出错,是不是端口有什么功能需要开启,我在 H3C 3600上面使用是正常的
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
<H3C>sy System View: return to User View with Ctrl+Z. [H3C]int g1/0/3 [H3C-GigabitEthernet1/0/3]de [H3C-GigabitEthernet1/0/3]def [H3C-GigabitEthernet1/0/3]default This command will restore the default settings. Continue? [Y/N]:y [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3]port [H3C-GigabitEthernet1/0/3]port l [H3C-GigabitEthernet1/0/3]port link-m [H3C-GigabitEthernet1/0/3]port link-mode bridge ^ % Unrecognized command found at '^' position. [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3] [H3C-GigabitEthernet1/0/3]qu [H3C]dis version H3C Comware Software, Version 7.1.070, Release 6126P20 Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved. H3C S5560S-28P-SI uptime is 0 weeks, 0 days, 9 hours, 15 minutes Last reboot reason : Cold reboot Boot image: flash:/s5560s_si-cmw710-boot-r6126p20.bin Boot image version: 7.1.070, Release 6126P20 Compiled Apr 03 2018 11:00:00 System image: flash:/s5560s_si-cmw710-system-r6126p20.bin System image version: 7.1.070, Release 6126P20 Compiled Apr 03 2018 11:00:00 Slot 1: Uptime is 0 weeks,0 days,9 hours,15 minutes S5560S-28P-SI with 1 Processor BOARD TYPE: S5560S-28P-SI DRAM: 512M bytes FLASH: 256M bytes PCB 1 Version: VER.B Bootrom Version: 121 CPLD 1 Version: 001 Release Version: H3C S5560S-28P-SI-6126P20 Patch Version : None Reboot Cause : ColdReboot [SubSlot 0] 24GE+4SFP
我的是5560S-28P-SI 的
破案了,版本问题,你是6126版本,612x也没这个命令,参考:https://www.h3c.com/cn/Service/Document_Software/Document_Center/Home/Switches/00-Public/Command/Command_Manual/H3C_S5560S-EI_S5560S-SI-CR-R612x-6W102/99/?CHID=366294
你升级版本吧。
软件版本下载链接:https://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S5560/H3C_S5560S-SI/
合作伙伴公共账号:yx800/01230123 具体升级操作参看相关版本的附录。
好的谢谢。我升级版本试试
