诚恳发问wx2540h配置设备作为RADIUS服务器认证不通过
2022-05-03提问
  • 1收藏,1241浏览
swliin 零段
设备端显示正在连接后失败,认证不通过。
请各位大佬指点一下错误的地方,已知问题时返回错误8 ,以下为debug信息,请各位大佬指点一下错误的地方,已知问题时返回错误8
*May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Processing RADIUS authentication.
*May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: Processing AAA request data.
 *May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: Got request data successfully, primitive: authentication.
 *May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: Getting RADIUS server info.
*May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: Got RADIUS server info successfully.
*May 3 10:09:43:812 2022 H3C RADIUS/7/EVENT: Created request context successfully.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Created request packet successfully, dstIP: 10.10.20.1, dstPort: 1812, VPN instance: --(public), socketFd: 203, pktID: 172.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Added packet socketfd to epoll successfully, socketFd: 203.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Mapped PAM item to RADIUS attribute successfully.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Got RADIUS username format successfully, format: 0.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Added attribute user-name successfully, user-name: sulin.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Filled RADIUS attributes in packet successfully.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Composed request packet successfully.
*May 3 10:09:43:813 2022 H3C RADIUS/7/EVENT: Created response timeout timer successfully.
*May 3 10:09:43:814 2022 H3C RADIUS/7/PACKET: User-Name="sulin" Service-Type=Framed-User Framed-Protocol=PPP NAS-Identifier="H3C" NAS-Port=16777416 NAS-Port-Type=Wireless-802.11 NAS-Port- Calling-Station- Called-Station- H3c-Nas-Startup-Timestamp=1293840020 Acct-Session- H3c-User-Vlan-Id=200 EAP-Message=0x0201000a0173756c696e Message-Authenticator=0x00000000000000000000000000000000 Framed-MTU=1450 H3c-Ip-Host-Addr="0.0.0.0 c8:f3:19:49:e6:7c" H3C-MAC-Proxy-Authenticator=****** NAS-IP-Address=10.10.20.1 H3c-Product-
 *May 3 10:09:43:814 2022 H3C RADIUS/7/EVENT: Sent request packet successfully.
 *May 3 10:09:43:814 2022 H3C RADIUS/7/PACKET: 01 ac 01 32 a1 81 71 cd ea 22 0e 77 75 1f 2d 5d 60 c5 e9 f5 01 07 73 75 6c 69 6e 06 06 00 00 00 02 07 06 00 00 00 01 20 05 48 33 43 05 06 01 00 00 c8 3d 06 00 00 00 13 57 12 30 31 30 30 30 30 30 30 30 30 30 30 30 32 30 30 1f 13 43 38 2d 46 33 2d 31 39 2d 34 39 2d 45 36 2d 37 43 1e 1f 46 34 2d 37 34 2d 38 38 2d 43 42 2d 36 38 2d 32 30 3a 64 6f 74 31 78 2d 6c 6f 63 61 6c 1a 0c 00 00 63 a2 3b 06 4d 1e 6e 94 2c 28 30 30 30 30 30 30 30 34 32 30 32 32 30 35 30 33 31 30 30 39 34 33 30 30 30 30 30 30 30 36 30 38 31 30 30 31 38 36 1a 0c 00 00 63 a2 85 06 00 00 00 c8 4f 0c 02 01 00 0a 01 73 75 6c 69 6e 50 12 23 dc c5 a1 39 07 db c2 af 73 fe 07 27 c7 5d f6 0c 06 00 00 05 aa 1a 21 00 00 63 a2 3c 1b 30 2e 30 2e 30 2e 30 20
*May 3 10:09:43:814 2022 H3C RADIUS/7/PACKET: 63 38 3a 66 33 3a 31 39 3a 34 39 3a 65 36 3a 37 63 1a 18 00 00 63 a2 96 12 f5 75 6a 3a 59 a7 d9 32 24 d2 95 4b 1d 63 cf 0b 04 06 0a 0a 14 01 1a 13 00 00 63 a2 ff 0d 48 33 43 20 57 58 32 35 34 30 48
*May 3 10:09:43:815 2022 H3C RADIUS/7/EVENT: Sent request packet and create request context successfully.
*May 3 10:09:43:818 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Sent authentication request successfully.
*May 3 10:09:43:818 2022 H3C RADIUS/7/EVENT: Added request context to global table successfully.
*May 3 10:09:43:818 2022 H3C RADIUS/7/EVENT: Processing AAA request data.
*May 3 10:09:43:819 2022 H3C RADIUS/7/EVENT: Processing AAA request data.
*May 3 10:09:47:537 2022 H3C RADIUS/7/EVENT: Response timed out.
*May 3 10:09:47:537 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:172.
*May 3 10:09:47:538 2022 H3C RADIUS/7/EVENT: Retransmitting request packet, currentTries: 2, maxTries: 3.
*May 3 10:09:50:537 2022 H3C RADIUS/7/EVENT: Response timed out.
*May 3 10:09:50:537 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:172. *May 3 10:09:50:538 2022 H3C RADIUS/7/EVENT: Retransmitting request packet, currentTries: 3, maxTries: 3. *May 3 10:09:53:538 2022 H3C RADIUS/7/EVENT: Response timed out.
%May 3 10:09:53:539 2022 H3C DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=sulin-UserMAC=c8f3-1949-e67c-BSSID=f474-88cb-6820-SSID=dot1x-local-APName=1-1-RadioID=1-VLANID=200; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 8.
*May 3 10:09:53:538 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:172.
*May 3 10:09:53:538 2022 H3C RADIUS/7/EVENT: Reached the maximum retries.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: Set status of server to block successfully. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: Got next server failed.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: Sent reply error message to PAM.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: Sent reply message successfully.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Processing RADIUS authentication.
*May 3 10:09:53:539 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Fetched authentication reply-data successfully, resultCode: 3
*May 3 10:09:53:542 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:09:55:365 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Processing RADIUS authentication.
*May 3 10:09:55:365 2022 H3C RADIUS/7/EVENT: PAM_RADIUS: Sent authentication request successfully.
*May 3 10:09:55:365 2022 H3C RADIUS/7/EVENT: Processing AAA request data.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Got request data successfully, primitive: authentication.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Getting RADIUS server info.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Got RADIUS server info successfully.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Created request context successfully.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Created request packet successfully, dstIP: 10.10.20.1, dstPort: 1812, VPN instance: --(public), socketFd: 203, pktID: 248.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Added packet socketfd to epoll successfully, socketFd: 203.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Mapped PAM item to RADIUS attribute successfully.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Got RADIUS username format successfully, format: 0.
*May 3 10:09:55:366 2022 H3C RADIUS/7/EVENT: Added attribute user-name successfully, user-name: sulin.
*May 3 10:09:55:367 2022 H3C RADIUS/7/EVENT: Filled RADIUS attributes in packet successfully.
*May 3 10:09:55:367 2022 H3C RADIUS/7/EVENT: Composed request packet successfully.
*May 3 10:09:55:367 2022 H3C RADIUS/7/EVENT: Created response timeout timer successfully.
*May 3 10:09:55:367 2022 H3C RADIUS/7/PACKET: User-Name="sulin" Service-Type=Framed-User Framed-Protocol=PPP NAS-Identifier="H3C" NAS-Port=16777416 NAS-Port-Type=Wireless-802.11 NAS-Port- Calling-Station- Called-Station- H3c-Nas-Startup-Timestamp=1293840020 Acct-Session- H3c-User-Vlan-Id=200 EAP-Message=0x0201000a0173756c696e Message-Authenticator=0x00000000000000000000000000000000 Framed-MTU=1450 H3c-Ip-Host-Addr="0.0.0.0 c8:f3:19:49:e6:7c" H3C-MAC-Proxy-Authenticator=****** NAS-IP-Address=10.10.20.1 H3c-Product-
*May 3 10:09:55:367 2022 H3C RADIUS/7/EVENT: Sent request packet successfully.
*May 3 10:09:55:368 2022 H3C RADIUS/7/PACKET: 01 f8 01 32 79 e2 64 14 be 1d b4 8a ae 52 e4 d3 db 0f d1 9e 01 07 73 75 6c 69 6e 06 06 00 00 00 02 07 06 00 00 00 01 20 05 48 33 43 05 06 01 00 00 c8 3d 06 00 00 00 13 57 12 30 31 30 30 30 30 30 30 30 30 30 30 30 32 30 30 1f 13 43 38 2d 46 33 2d 31 39 2d 34 39 2d 45 36 2d 37 43 1e 1f 46 34 2d 37 34 2d 38 38 2d 43 42 2d 36 38 2d 32 30 3a 64 6f 74 31 78 2d 6c 6f 63 61 6c 1a 0c 00 00 63 a2 3b 06 4d 1e 6e 94 2c 28 30 30 30 30 30 30 30 34 32 30 32 32 30 35 30 33 31 30 30 39 35 35 30 30 30 30 30 30 30 37 30 38 31 30 30 31 38 36 1a 0c 00 00 63 a2 85 06 00 00 00 c8 4f 0c 02 01 00 0a 01 73 75 6c 69 6e 50 12 8e 5d 56 59 da f0 8a 9e 8e f2 4b ef d2 af 27 74 0c 06 00 00 05 aa 1a 21 00 00 63 a2 3c 1b 30 2e 30 2e 30 2e 30 20
*May 3 10:09:55:369 2022 H3C RADIUS/7/PACKET: 63 38 3a 66 33 3a 31 39 3a 34 39 3a 65 36 3a 37 63 1a 18 00 00 63 a2 96 12 a5 07 3f df 95 50 0e 29 52 30 f2 e8 a5 73 d6 da 04 06 0a 0a 14 01 1a 13 00 00 63 a2 ff 0d 48 33 43 20 57 58 32 35 34 30 48
*May 3 10:09:55:369 2022 H3C RADIUS/7/EVENT: Sent request packet and create request context successfully.
*May 3 10:09:55:369 2022 H3C RADIUS/7/EVENT: Added request context to global table successfully.
*May 3 10:09:55:369 2022 H3C RADIUS/7/EVENT: Processing AAA request data.
%May 3 10:09:56:414 2022 H3C DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=sulin-UserMAC=c8f3-1949-e67c-BSSID=f474-88cb-6820-SSID=dot1x-local-APName=1-1-RadioID=1-VLANID=200; A user failed 802.1X authentication.Reason:Received deauthentication packet with reason code 3 in Userauth state.
*May 3 10:09:58:538 2022 H3C RADIUS/7/EVENT: Response timed out.
*May 3 10:09:58:538 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:248. *May 3 10:09:58:538 2022 H3C RADIUS/7/EVENT: Retransmitting request packet, currentTries: 2, maxTries: 3.
*May 3 10:10:01:538 2022 H3C RADIUS/7/EVENT: Response timed out. *May 3 10:10:01:538 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:248.
*May 3 10:10:01:538 2022 H3C RADIUS/7/EVENT: Retransmitting request packet, currentTries: 3, maxTries: 3.
*May 3 10:10:04:538 2022 H3C RADIUS/7/EVENT: Response timed out.
*May 3 10:10:04:538 2022 H3C RADIUS/7/EVENT: Found request context, dstIP: 10.10.20.1; dstPort: 1812; VPN instance: --(public); socketfd: 203; pktID:248.
*May 3 10:10:04:538 2022 H3C RADIUS/7/EVENT: Reached the maximum retries.
*May 3 10:10:04:538 2022 H3C RADIUS/7/EVENT: Set status of server to block successfully. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:04:539 2022 H3C RADIUS/7/EVENT: Got next server failed.
*May 3 10:10:04:539 2022 H3C RADIUS/7/EVENT: Sent reply error message to PAM.
*May 3 10:10:04:539 2022 H3C RADIUS/7/EVENT: Sent reply message successfully.
*May 3 10:10:04:540 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:49:695 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:49:696 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:49:697 2022 H3C RADIUS/7/EVENT: Aaad sent notification about the change of server status to application process successfully. Server state: active.
*May 3 10:10:49:697 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:49:702 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:49:702 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:49:702 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:49:997 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:49:998 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:49:998 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:50:157 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:50:158 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:50:158 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:50:433 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:50:434 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:50:500 2022 H3C RADIUS/7/EVENT: Set server to active state. serverIP: 10.10.20.1, serverPort: 1812.
*May 3 10:10:50:501 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:50:501 2022 H3C RADIUS/7/EVENT: Received status of server changing event.
*May 3 10:10:50:518 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:50:538 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
*May 3 10:10:50:695 2022 H3C RADIUS/7/EVENT: Application process received the notification about the change of server status from aaad process. Server state: active.
联系 400分析下日志呢
粉丝:42人 关注:1人
看你都问好多回这个问题了,如果可以把你所有的配置发上来吧 ,有大佬们看到的话,能给你找出哪里配置错误了,如果有些信息不方便的话,咨询一下400售后吧
发出了
swliin 发表时间:2022-05-03
swliin 知了小白
AC
vlan100 ip 10.10.10.1
vlan200 ip 10.10.20.1
radius server IP 10.10.20.1 1812 共享密钥 12345678 作为本地认证服务器的IP地址
radius client ip 10.10.20.1 共享密钥 12345678
dot1x eap peap-mschapv2
导入相应ca.pem server.pem 域名10.10.20.1 私钥密钥123456
ISP lan接入AAA radius认证、授权 不计费
user class network lan-access
无线服务模板 使用ISP域
