H3C S5120V2交换机如何恢复出厂设置
2022-09-05提问
  • 0收藏,2057浏览
粉丝:1人 关注:1人
有之前的交换机,插上网线后,亮灯即灭。应该是之前的配置导致的。现在想做成傻瓜式交换机,请问该如何清空配置或者恢复出厂设置呢?
4 个回答
粉丝:230人 关注:0人
您好,参考
<H3C>reset saved-configuration   //清空交换机配置
The saved configuration file will be erased. Are you sure? [Y/N]:y   //设备提示保存的配置将会被删除,是否继续。
Configuration file in flash: is being cleared. Please wait ...
MainBoard:
 Configuration file is cleared.   //配置已被清空
<H3C>reboot   //重启交换机
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:n   //设备提示会在重启后丢失当前配置,是否保存当前配置,选择n
This command will reboot the device. Continue? [Y/N]:y   //设备提示设备将会重启,是否继续,选择Y
Now rebooting, please wait...
%Dec 14 20:48:39:352 2019 SW1 DEV/5/SYSTEM_REBOOT: System is rebooting now.
粉丝:112人 关注:8人
清空配置(恢复出厂)请参考:
<h3c>reset saved-configuration
Configuration file in flash: is being cleared. Please wait ... MainBoard: Configuration file is cleared.
 <h3c>reboot
Start to check configuration with next startup configuration file, please wait.........DONE! Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
Configuration file does not exist!
<H3C>reboot
粉丝:119人 关注:1人
删除.cfg 和mdb文件重启即可
