F100-C-G 的VLAN 70 掩码从 24 改为 23后,网络全部VLAN网络很慢
2018-09-18提问
  • 1收藏,1213浏览
粉丝:1人 关注:1人
问题: 我这边的一个 VLAN  需要接入 超过 254 个无线终端,10个 AP由同一个 AC管理。于是我昨天把原来的VLAN VLAN 60 删除了,把 70 的掩码 由24改为 23,修改后的配置如下,今天的所有VLAN网络异常卡顿,常用的百度、京东甚至打不开,求解,我的
 version 5.20, Release 5142P02
 sysname ds_F100
 clock timezone UTC add 00:00:00
 l2tp enable
 undo voice vlan mac-address 00e0-bb00-0000
 interzone policy default by-priority
 ip pool 1 172.18.10.2 172.18.10.254
 domain default enable system
 dns resolve
 dns proxy enable
 telnet server enable
 qos carl 5 destination-ip-address subnet 172.18.5.0 24 per-address
 qos carl 6 destination-ip-address subnet 172.18.6.0 24 per-address
 qos carl 7 destination-ip-address subnet 172.18.7.0 24 per-address
 qos carl 8 destination-ip-address subnet 172.18.8.0 24 per-address
 qos carl 12 destination-ip-address subnet 172.18.12.0 24 per-address
 qos carl 13 destination-ip-address subnet 172.18.13.0 24 per-address
 qos carl 20 destination-ip-address range 172.18.5.209 to 172.18.5.210 per-address
 qos carl 21 destination-ip-address range 172.18.5.211 to 172.18.5.212 per-address
 qos carl 22 destination-ip-address range 172.18.5.213 to 172.18.5.254 per-address
 qos carl 51 destination-ip-address range 172.18.5.2 to 172.18.5.206 per-address
 qos carl 52 destination-ip-address range 172.18.5.207 to 172.18.5.208 per-address
 qos carl 103 destination-ip-address range 172.18.5.2 to 172.18.5.103 per-address
 qos carl 104 destination-ip-address range 172.18.5.104 to 172.18.5.105
 qos carl 106 destination-ip-address range 172.18.5.106 to 172.18.5.206 per-address
 port-security enable
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg gtp
session synchronization enable
 password-recovery enable
acl number 2000 match-order auto
 rule 2 permit source 172.18.4.0 0.0.0.255
 rule 3 permit source 172.18.5.0 0.0.0.255
 rule 4 permit source 172.18.6.0 0.0.0.255
 rule 5 permit source 172.18.7.0 0.0.0.255
 rule 6 permit source 172.18.8.0 0.0.0.255
 rule 7 permit source 172.18.11.0 0.0.0.255
 rule 8 permit source 172.18.12.0 0.0.0.255
 rule 9 permit source 172.18.13.0 0.0.0.255
 rule 10 permit source 172.18.14.0 0.0.0.255
 rule 11 permit source 172.18.3.0 0.0.0.255
 rule 15 permit source 172.18.18.0 0.0.0.255
vlan 1
pki domain datastory
  ca identifier CA Server
  certificate request from ca
  certificate request entity datastory
pki domain datastoryca
  certificate request from ra
  root-certificate fingerprint sha1 4DC243
pki domain default
  crl check disable
qos policy ceshi003
dhcp server ip-pool vlan120
 network 172.18.12.0 mask 255.255.255.0
 gateway-list 172.18.12.1
 dns-list 192.168.1.2
 expired day 0 hour 4
dhcp server ip-pool vlan130
 network 172.18.13.0 mask 255.255.255.0
 gateway-list 172.18.13.1
 expired day 0 hour 3
dhcp server ip-pool vlan180
 network 172.18.18.0 mask 255.255.255.0
 gateway-list 172.18.18.1
 expired day 0 hour 1
dhcp server ip-pool vlan50
 network 172.18.5.0 mask 255.255.255.0
 gateway-list 172.18.5.1
dhcp server ip-pool vlan70
 network 172.18.6.0 mask 255.255.254.0
 gateway-list 172.18.7.1
 expired day 0 hour 1 minute 30
dhcp server ip-pool vlan80
 network 172.18.8.0 mask 255.255.255.0
 gateway-list 172.18.8.1
policy-based-route 2000 permit node 10
 if-match acl 2000
 apply ip-address next-hop 192.168.1.3
user-group system
 group-attribute allow-guest
local-user admin
 password ci
 authorization-attribute level 3
 service-type telnet
 service-type web
local-user u8user
 password cipher $
 service-type ppp
local-user vpnuser
 password cipher $
 service-type ppp
 stp max-hops 30
 stp bpdu-protection
 stp enable
ssl server-policy access-policy
 pki-domain datastory
cwmp
 undo cwmp enable
interface NULL0
interface Vlan-interface1
 ip policy-based-route 2000
interface GigabitEthernet0/1
 port link-mode route
 nat outbound 2000
 ip address 192.168.1.3 255.255.255.0
 qos car inbound carl 13 cir 30000 cbs 64000 ebs 0 green pass red discard
 qos car inbound carl 14 cir 10000 cbs 64000 ebs 0 green pass red discard
 qos car inbound carl 52 cir 20000 cbs 64000 ebs 0 green pass red discard
 qos car inbound carl 8 cir 60000 cbs 64000 ebs 0 green pass red discard
 qos car inbound carl 103 cir 10000 cbs 625000 ebs 0 green pass red discard
 qos car inbound carl 104 cir 40000 cbs 2500000 ebs 0 green pass red discard
 qos car inbound carl 106 cir 10000 cbs 625000 ebs 0 green pass red discard
 qos car inbound carl 21 cir 40000 cbs 2500000 ebs 0 green pass red discard
 qos car inbound carl 6 cir 40000 cbs 3750000 ebs 0 green pass red discard
 qos car inbound carl 12 cir 40000 cbs 625000 ebs 0 green pass red discard
interface GigabitEthernet0/2
 ip address XXXXXXXXXXX
interface GigabitEthernet0/3
interface GigabitEthernet0/3.1
 vlan-type dot1q vid 140
 ip address 172.18.14.1 255.255.255.0
interface GigabitEthernet0/4
interface GigabitEthernet0/4.3
 vlan-type dot1q vid 50
 ip address 172.18.5.1 255.255.255.0
interface GigabitEthernet0/4.5
 vlan-type dot1q vid 70
 ip address 172.18.7.1 255.255.254.0
interface GigabitEthernet0/4.6
 vlan-type dot1q vid 80
 ip address 172.18.8.1 255.255.255.0
interface GigabitEthernet0/4.8
 vlan-type dot1q vid 120
 ip address 172.18.12.1 255.255.255.0
interface GigabitEthernet0/4.9
 vlan-type dot1q vid 130
 ip address 172.18.13.1 255.255.255.0
interface GigabitEthernet0/4.15
 vlan-type dot1q vid 180
 ip address 172.18.18.1 255.255.255.0
vd Root id 1
zone name Management id 0
 priority 100
 import interface GigabitEthernet0/0
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface GigabitEthernet0/3
 import interface GigabitEthernet0/3.1
 import interface GigabitEthernet0/4
 import interface GigabitEthernet0/4.3
 import interface GigabitEthernet0/4.5
 import interface GigabitEthernet0/4.6
 import interface GigabitEthernet0/4.8
 import interface GigabitEthernet0/4.9
 import interface GigabitEthernet0/4.15
 import interface Virtual-Template0
zone name DMZ id 3
 priority 50
zone name Untrust id 4
 priority 5
 import interface GigabitEthernet0/1
 import interface GigabitEthernet0/2
switchto vd Root
 object service wannacry01
  description 阻止比特币病毒
  service tcp destination-port 445
 object service wannacry02
  service tcp destination-port 135
 object service wannacry03
  service tcp destination-port 137
 object service wannacry04
  service tcp destination-port 139
 ip virtual-reassembly
 zone name DMZ id 3
 interzone source Trust destination Trust
  rule 0 permit logging
   source-ip any_address
   destination-ip any_address
   service any_service
   rule enable
 interzone source Untrust destination Trust
  rule 2 deny
   service wannacry01
   service wannacry02
   service wannacry03
   service wannacry04
   rule enable
   service any_service
   rule enable
 ssl-vpn server-policy access-policy
 ssl-vpn enable
 ip route-static 0.0.0.0 0.0.0.0 192.168.1.2
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:13人 关注:4人
把qos去掉试试?cpu高吗?不排除是性能不够了。ping丢包吗?丢包估计性能问题问400吧,如果只有网页卡可以修改下tcp mss试试
CPU 1% ,内存 29% ,温度 47 度,没有满负载的吧,之前都好好的,就是昨天我把 VLAN60删除了,把VLAN70的掩码由 24改为 23后,原来V少部分的 VLAN 60 的打印机、台式机都连接到 VLAN 70上。今天中午开始,就很卡了,全公司的台式机、笔记本都上网很慢,网页经常打不开。首先想请教一下,我这样设置的VLAN 70 ,得到的500个IP ,有没有问题
烟花里的尘埃 发表时间:2018-09-18
粉丝:8人 关注:0人
能否做下流统看下 是不是有丢包,有可能是被策略给丢了
