SecPath M9010频繁出现异常温度告警
  • 0收藏,740浏览
设备display log频繁出现以下的温度告警,一会温度高,一会温度低,一会正常,这个是什么原因。
%Oct 10 18:15:28:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:30:23:393 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_LOW: Temperature is less than the low-temperature threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:30:43:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:31:48:393 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:32:03:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:32:58:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:33:18:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:33:33:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:34:43:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:34:58:395 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:35:18:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:36:08:393 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 18:36:23:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 22:12:38:395 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 22:12:58:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 10 22:42:43:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_LOW: Temperature is less than the low-temperature threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 10 22:42:58:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 11:57:43:393 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 11:58:03:393 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 12:26:38:395 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 12:26:53:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:07:28:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:07:48:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:36:58:396 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:37:13:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:43:18:396 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 13:43:38:396 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 14:31:13:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_WARNING: Temperature is greater than the high-temperature warning threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 14:31:33:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 16:45:13:394 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_LOW: Temperature is less than the low-temperature threshold on chassis 1 slot 4 sensor inflow 1.
%Oct 11 16:45:33:394 2022 New_BSS_Core_FW_H3C_9000 DEV/5/TEMPERATURE_NORMAL: Temperature changed to normal on chassis 1 slot 4 sensor inflow 1.
%Oct 11 21:07:18:395 2022 New_BSS_Core_FW_H3C_9000 DEV/4/TEMPERATURE_ALARM: Temperature is greater than the high-temperature alarming threshold on chassis 1 slot 4 sensor inflow 1.
粉丝:148人 关注:1人
检查机房问题,如果实际温度低,可以看下告警阈值是不是设置的低了
粉丝:127人 关注:8人
查看下温度,检查一下风扇状态。
dis environment
dis fan
