imc 自动备份失败
2022-12-23提问
  • 0收藏,668浏览
Client::connect_to_server] errno: 111, strerror: Connection refused
这个要如何排查
2022-12-23 17:52:35 [INFO] [Main] Version: 7.3
2022-12-23 17:52:35 [INFO] [Main] Global directory: /opt/iMC/dbman
2022-12-23 17:52:35 [INFO] [Main] Listenning on port: 2810
2022-12-23 17:52:35 [DEBUG] [Main] arv count 1
2022-12-23 17:52:35 [DEBUG] [Main] arv 1: ./dbman
2022-12-23 17:52:35 [INFO] [Client::connect_to_server] Starting connect to 127.0.0.1: 2810
2022-12-23 17:52:35 [DEBUG] [Client::connect_to_server] errno: 111, strerror: Connection refused
2022-12-23 17:52:35 [ERROR] [Client::connect_to_server] Connection failed
2022-12-23 17:52:35 [ERROR] [Client::send_echo_msg] Connect to server fail
2022-12-23 17:52:35 [DEBUG] [CreateCommandThread] Succeed to create command process thread .
2022-12-23 17:52:35 [DEBUG] [CommandMain] Start CommandMain()
2022-12-23 17:52:37 [INFO] [DBMAN] Startup successfully!
2022-12-23 17:52:37 [DEBUG] [NormalRun] Begin excute NormalRun
2022-12-23 17:52:37 [INFO] [NormalRun] MaxLogSize = 10485760
2022-12-23 17:52:37 [INFO] [NormalRun] ServerCount = 1
2022-12-23 17:52:37 [INFO] [NormalRun] Local ip address: 127.0.0.1
2022-12-23 17:52:37 [INFO] [NormalRun] Local ip address: 192.168.20.17
2022-12-23 17:52:37 [INFO] [NormalRun] Local ip address: ::1
2022-12-23 17:52:37 [INFO] [NormalRun] Local ip address: fe80::10bd:38a4:148f:9f03%2
2022-12-23 17:52:37 [INFO] [RemoveReservedFile] Begin Remove Reserved File
2022-12-23 17:52:37 [INFO] [ClearFile] ClearFile 2022-12-23 17:52:37 [INFO] [ClearFile] ClearFile
粉丝:14人 关注:4人
检查一下2810端口占用情况
粉丝:4人 关注:0人
检查2810端口进程占用情况、dbman进程状态、系统防火墙是否关闭等。可参考这个案例排查:https://zhiliao.h3c.com/Theme/details/127128
粉丝:35人 关注:7人
检查TCP 2810端口是否被占用或者服务器系统防火墙拦截。
其次检查IMC的dbman进程的状态是否已启用。
