向设备发送请求失败
2023-03-08提问
  • 0收藏,757浏览
085 二段
如题,
IMC做Radius与Portal服务器,旁挂核心5/0/16,IP为:192.168.50.6 vlan50
有线终端直连核心5/0/14 获取的地址为192.168.3.2 vlan3
核心是V5的S7506E-S 192.168.50.1vlan50, 192.168.3.1vlan3
192.168.3.1可ping通192.168.50.6,3.2也可通50.6
核心做如下配置:
 portal server yxportal ip 192.168.50.6 key cipher $c$3$BtQEvJGyc2yoYKvtrwjF8ExoXuOSW8G6jsRY url http://192.168.50.6:8080/portal
 portal free-rule 0 source ip any destination ip 192.168.3.0 mask 255.255.255.0
 portal free-rule 1 source ip any destination ip 192.168.99.0 mask 255.255.255.0
 portal free-rule 2 source ip any destination ip 192.168.200.0 mask 255.255.255.0
 portal free-rule 3 source ip any destination ip 192.168.50.0 mask 255.255.255.0
 portal free-rule 4 source ip any destination ip 211.136.192.0 mask 255.255.255.0 undo portal local-server https
radius scheme yxportal
 primary authentication 192.168.50.6
 primary accounting 192.168.50.6
 key authentication cipher $c$3$nVOId33bjS4tyDc5J3EPJ3iiVHbF4QOZrTos
 key accounting cipher $c$3$+kJYJboB+OZQAlh9KzTyqToS9nqOZL7PhxCG
domain yxportal
 authentication portal radius-scheme yxportal
 authorization portal none
 accounting portal none
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
vlan 3
vlan 50
interface Vlan-interface3
 ip address 192.168.3.1 255.255.255.0
 portal server yxportal method direct
 portal domain yxportal
 portal nas-ip 192.168.3.1
interface GigabitEthernet5/0/14
 port link-mode bridge
 port access vlan 3
 stp edged-port enable
interface GigabitEthernet5/0/16
 port access vlan 50
 speed 1000
 duplex full
IMC配置如下
4 个回答
粉丝:2人 关注:0人
需要看portalserver和uam的debug日志,看报文的交互情况
看我最新评论
085 发表时间:2023-03-08
粉丝:3人 关注:7人
是不是有服务后缀,设备上配置withdomain了嘛,用户名@domain
贴命令的时候少贴了,实际上配了,结果还是设备发送请求超时
085 发表时间:2023-03-08
用yyy@yxportal登录下呢
小熊猫没有熊猫眼 发表时间:2023-03-08
一样结果
085 发表时间:2023-03-08
085 二段
对客户端接口G5/0/14的portal packet debug信息
小建 二段
如何解决的,求分享呀
