如题,
IMC做Radius与Portal服务器,旁挂核心5/0/16,IP为:192.168.50.6 vlan50
有线终端直连核心5/0/14 获取的地址为192.168.3.2 vlan3
核心是V5的S7506E-S 192.168.50.1vlan50, 192.168.3.1vlan3
192.168.3.1可ping通192.168.50.6,3.2也可通50.6
核心做如下配置:
portal server yxportal ip 192.168.50.6 key cipher $c$3$BtQEvJGyc2yoYKvtrwjF8ExoXuOSW8G6jsRY url http://192.168.50.6:8080/portal
portal free-rule 0 source ip any destination ip 192.168.3.0 mask 255.255.255.0
portal free-rule 1 source ip any destination ip 192.168.99.0 mask 255.255.255.0
portal free-rule 2 source ip any destination ip 192.168.200.0 mask 255.255.255.0
portal free-rule 3 source ip any destination ip 192.168.50.0 mask 255.255.255.0
portal free-rule 4 source ip any destination ip 211.136.192.0 mask 255.255.255.0 undo portal local-server https
radius scheme yxportal
primary authentication 192.168.50.6
primary accounting 192.168.50.6
key authentication cipher $c$3$nVOId33bjS4tyDc5J3EPJ3iiVHbF4QOZrTos
key accounting cipher $c$3$+kJYJboB+OZQAlh9KzTyqToS9nqOZL7PhxCG
domain yxportal
authentication portal radius-scheme yxportal
authorization portal none
accounting portal none
access-limit disable
state active
idle-cut disable
self-service-url disable
vlan 3
vlan 50
interface Vlan-interface3
ip address 192.168.3.1 255.255.255.0
portal server yxportal method direct
portal domain yxportal
portal nas-ip 192.168.3.1
interface GigabitEthernet5/0/14
port link-mode bridge
port access vlan 3
stp edged-port enable
interface GigabitEthernet5/0/16
port access vlan 50
speed 1000
duplex full
IMC配置如下
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
贴命令的时候少贴了,实际上配了,结果还是设备发送请求超时
用yyy@yxportal登录下呢
一样结果
