l2tp可以连,但是l2tp over ipsec vpn提示IKE协商失败
2017-08-27提问
  • 1收藏,5052浏览
外面电脑安装inode,设置好后可以连上l2tp vpn,但是结合ipsec 就提示IKE协商失败
防火墙配置: ike local-name huizhou
                      domain default enable system
                    domain system
                    authentication ppp local
                    access-limit disable
                    state active
                    idle-cut disable
                    self-service-url disable
                   ip pool 1 10.10.111.100 10.10.111.150
                  ike peer inode
                  exchange-mode aggressive
                  pre-shared-key cipher xz8n+yXxN+I=
                 id-type name
                 remote-name szkbpcb01
                 nat traversal
                 dpd 1
                ipsec policy-template for_inode 1
                ike-peer inode
                proposal 1
               ipsec policy inode 1 isakmp template for_inode
              local-user l2tp
              password cipher R7-C#Y\M+=OQ=^Q`MAF4<1!!
              service-type ppp
             l2tp-group 1
             mandatory-chap
             undo tunnel authentication
             mandatory-lcp
             allow l2tp virtual-template 1
           interface Virtual-Template1
           ppp authentication-mode chap domain system
          ppp ipcp dns 8.8.8.8
          remote address pool 1
          ip address 10.10.111.1 255.255.255.0
         interface GigabitEthernet0/3
         port link-mode route
         description this port is link to China Mobile's Fiber Converter
         nat outbound 3003
         ipsec policy inode
客户端inode拨号设置查看附加5个截图
出口防火墙U200-M担任LNS,外面PC用inode通过l2tp拨入
粉丝:20人 关注:3人
设备上dis ike sa的状态是什么 inode的报错
nat的acl先把1701的流量拒绝掉
[U200-M]dis ike sa total phase-1 SAs: 2 connection-id peer flag phase doi ---------------------------------------------------------- 43938 <unnamed> NONE 1 IPSEC
zhiliao_64770 发表时间:2017-08-27
nat的acl先把1701的流量拒绝掉;ike的配置参数看着都正常
笃行之 发表时间:2017-08-27
粉丝:12人 关注:7人
把iNode上的ike和ipsec参数看看吧,设备全部采用默认的,建议手工配置确保一致。
