电信和移动双线接入,有些网站电信能访问,移动无法访问,怎么弄?
2017-08-27提问
  • 1收藏,6538浏览
内网有5个网段,10段是服务器网段,20、30、40、50是办公网络网段。电信和移动双线接入,设置了策略路由:默认路由走电信,10段走电信,其余走移动。现在遇到的情况是有些网站电信线路能打得开,移动线路打不开,要如何弄?
出口防火墙配置:
 dns resolve
 dns proxy enable
 dns server 208.67.222.222
 dns server 192.168.60.251
acl number 3001
 description connect-to-China Telecom
 rule 25 permit ip source 192.168.10.0 0.0.0.255
acl number 3002
 description connect-to-China Mobile
 rule 31 permit ip source 192.168.20.0 0.0.0.255
 rule 32 permit ip source 192.168.30.0 0.0.0.255
 rule 33 permit ip source 192.168.40.0 0.0.0.255
 rule 34 permit ip source 192.168.50.0 0.0.0.255
acl number 3003
 description lan to internet
 rule 20 permit ip
nqa entry admin dianxin
 type icmp-echo
  destination ip x.x.x.x
  frequency 3000
  next-hop x.x.x.x
  probe count 3
  probe timeout 1000
  reaction 1 checked-element probe-fail threshold-type consecutive 8 action-type trigger-only
  source interface GigabitEthernet0/1
nqa entry admin yidong
 type icmp-echo
  frequency 3000
  next-hop x.x.x.x
  probe count 3
  probe timeout 1000
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
  source interface GigabitEthernet0/3
policy-based-route aaa permit node 3
   if-match acl 3002
   apply ip-precedence immediate
   apply ip-address next-hop 移动外网IP track 2
   apply ip-address default next-hop 电信外网网关 track 1
policy-based-route aaa permit node 5
   if-match acl 3001
   apply ip-precedence flash
   apply ip-address next-hop 电信外网网关track 1
 ip route-static 0.0.0.0 0.0.0.0 电信外网网关 track 1
 ip route-static 0.0.0.0 0.0.0.0 移动外网网关 track 2 preference 70
 ip route-static 1.51.64.0 255.255.192.0 移动外网网关 track 2
N条静态路由到移动网关
 track 1 nqa entry admin dianxin reaction 1
 track 2 nqa entry admin yidong reaction 2
 nqa schedule admin yidong start-time now lifetime forever
 nqa schedule admin dianxin start-time now lifetime forever
电信和移动接到U200-M防火墙上,防火墙下面接7506E,三次核心下面接S5120交换机,办公网段接在S5120上,服务器网段接在75上
粉丝:20人 关注:3人
策略路由走移动就打不开,换到电信就可以了?
以上情况可以尝试修改下mtu值和tcp mss尝试下
是修改g0/3的MTU和TCP MSS麽,修改成多少
zhiliao_64770 发表时间:2017-08-27
回复zhiliao_64770:
移动的tcp 800 mtu 改成1000尝试下 这些值只能是尝试,如果域名ping都是正常就是无法打开网页就要尝试修改这2个参数
笃行之 发表时间:2017-08-27
HCNP 五段
有的时候移动的出口会有问题,本子接在光猫上直连看看能打开么
可以的,试验过了,经过防火墙后出问题,应该是哪里设置的问题
zhiliao_64770 发表时间:2017-08-28
ping域名的时候能解析出网站的地址来么
HCNP 发表时间:2017-08-29
