c3510E WEB控制台无法显示客户端IP地址,显示0.0.0.0
  • 1收藏,2669浏览
粉丝:0人 关注:2人
<WHH_XS_WX_C3510E>dis cur
 version 5.20, Release 3709P61
 sysname WHH_XS_WX_C3510E
 clock timezone Beijing add 08:00:00
 domain default enable system
 telnet server enable
 port-security enable
 dot1x authentication-method eap
 portal server whh ip 192.200.37.19 url http://192.200.37.19/portal/logon.htm server-type imc
 portal free-rule 1 source interface GigabitEthernet1/0/1 destination any
 portal free-rule 2 source ip any destination ip 61.153.6.58 mask 255.255.255.255
 portal free-rule 3 source ip 61.153.6.58 mask 255.255.255.255 destination ip any
 portal free-rule 4 source ip any destination ip 192.200.10.8 mask 255.255.255.255
 portal free-rule 5 source ip 192.200.10.8 mask 255.255.255.255 destination ip any
 portal local-server http
 password-recovery enable
vlan 1
vlan 88
radius scheme system
 primary authentication 192.200.10.8
 primary accounting 192.200.10.8
 key authentication cipher $c$3$nYcyd8k2vXIFc9NyzUqmuskiQcyRJffZc+8J9aI=
 key accounting cipher $c$3$DSy1PFAC6IBLV4jLxWW3m79/yoNbGtJAjsQ1uSg=
 user-name-format without-domain
 nas-ip 192.200.37.19
radius scheme imc
domain 802.1x
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain system
 authentication lan-access radius-scheme system
 authorization lan-access radius-scheme system
 accounting lan-access radius-scheme system
 authentication portal radius-scheme system
 authorization portal radius-scheme system
 accounting portal radius-scheme system
 state active
 idle-cut disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$5bHyuuXF3Sch8R01GK0y684VbjhsjtAlfqpnITU=
 authorization-attribute level 3
 service-type portal
 service-type web
local-user h3c
 password cipher $c$3$dnKSSZqpSpDwUkCtcyWRpWqvxqC6zQ==
 service-type portal
local-user xh
 password cipher $c$3$teSvJJLjhTmR+GDd/1TmRH0mVKZZk3KMnt46rUA=
 service-type telnet terminal
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid itcitc_QS
 bind WLAN-ESS 0
 cipher-suite tkip
 security-ie rsn
wlan service-template 2 clear
 ssid itcitc_qiaosi
 bind WLAN-ESS 1
 service-template enable
wlan service-template 3 crypto
 ssid itcitc_802.1X
 bind WLAN-ESS 3
 cipher-suite ccmp
 security-ie rsn
wlan ap-group default_group
 ap itc_1
 ap itc_2
 ap itc_3
 ap itc_4
 ap itc_5
 ap itc_6
 ap itc_7
 dot11a radio enable
 dot11bg radio enable
interface NULL0
interface Vlan-interface1
 ip address 192.200.37.19 255.255.254.0
 portal server whh method direct
interface Vlan-interface88
 description AP_MGT
 ip address 172.18.1.10 255.255.255.0
 port link-type trunk
 port trunk permit vlan 1 88
interface GigabitEthernet1/0/4
interface Ten-GigabitEthernet1/0/5
interface WLAN-ESS0
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$dorxF2jV5SLr6na3PDj3+FdXM81kxM0OmwCxF2c=
interface WLAN-ESS1
 port link-type hybrid
 port hybrid vlan 1 untagged
interface WLAN-ESS3
 port-security port-mode userlogin-secure-ext
wlan ap itc_1 model WA2620i-AGN id 1
 serial-id 219801A0CMC13B001375
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_2 model WA2620i-AGN id 2
 serial-id 219801A0CMC13B001367
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_3 model WA2620i-AGN id 3
 serial-id 219801A0CMC13B001368
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_4 model WA2620i-AGN id 4
 serial-id 219801A0CMC13B001397
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_5 model WA2620i-AGN id 5
 serial-id 219801A0CMC13B001392
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_6 model WA2620i-AGN id 6
 serial-id 219801A0CMC13B001005
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ap itc_7 model WA2620i-AGN id 7
 serial-id 219801A0CMC13B001383
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ips
 malformed-detect-policy default
 signature deauth_flood signature-id 1
 signature broadcast_deauth_flood signature-id 2
 signature disassoc_flood signature-id 3
 signature broadcast_disassoc_flood signature-id 4
 signature eapol_logoff_flood signature-id 5
 signature eap_success_flood signature-id 6
 signature eap_failure_flood signature-id 7
 signature pspoll_flood signature-id 8
 signature cts_flood signature-id 9
 signature rts_flood signature-id 10
 signature addba_req_flood signature-id 11
 signature-policy default
 countermeasure-policy default
 attack-detect-policy default
 virtual-security-domain default
 ip route-static 0.0.0.0 0.0.0.0 192.200.37.2
 undo info-center logfile enable
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 set authentication password cipher $c$3$n2klKvgoY78uUw3+0j0ZcYxX/P8WYsaomkcJvoU=
return
<WHH_XS_WX_C3510E>
钉钉 八段
粉丝:29人 关注:0人
如果是集中转发,由于客户端的arp报文和dhcp报文经过了ac,所以在ac上开启arp-snooping enable和dhcp-snooping (注意配置trust端口)就可以获取到客户端ip。如果是本地转发,则需要在ac上开启wlan  client  learn-ipaddr enable 则也会获取到ip。
怎么判断是本地转发还是集中转发啊?
zhiliao_39360 发表时间:2017-09-06
按你说的做还是不行啊
回复zhiliao_39360:
看你的配置应该是集中转发,那把三条命令都配置上。然后display wlan client 看看会不会显示终端的ip地址,看你说的和我说的是不是一个意思。
钉钉 发表时间:2017-09-06
wlan client learn-ipaddr enable敲这个命令解决了!!!!!!!!!!!!!
sunny 八段
粉丝:9人 关注:0人
arp-snooping enable 开启试试呢
还是不行
zhiliao_39360 知了小白
粉丝:0人 关注:2人
Username:admin
Password:
vlan 1
vlan 88
radius scheme imc
domain 802.1x
 state active
 idle-cut disable
domain system
 state active
 idle-cut disable
user-group system
local-user admin
 service-type portal
 service-type web
local-user h3c
 service-type portal
local-user xh
 service-type web
wlan rrm
 ssid itcitc_QS
 bind WLAN-ESS 0
 cipher-suite tkip
 security-ie rsn
 ssid itcitc_qiaosi
 bind WLAN-ESS 1
 ssid itcitc_802.1X
 bind WLAN-ESS 3
 cipher-suite ccmp
 security-ie rsn
 ap itc_1
 ap itc_2
 ap itc_3
 ap itc_4
 ap itc_5
 ap itc_6
 ap itc_7
 dot11a radio enable
interface NULL0
 description AP_MGT
 dhcp-snooping trust
interface WLAN-ESS0
 dhcp-snooping trust
interface WLAN-ESS1
 dhcp-snooping trust
interface WLAN-ESS3
 dhcp-snooping trust
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
 radio 1
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 3
  radio enable
wlan ips
 dhcp-snooping
 arp-snooping enable
return
<WHH_XS_WX_C3510E>
帮忙看看配置还有哪里有问题吗?谢谢!
