H3C 36-10配置,PING 不通192.168.1.1
2023-11-20提问
  • 0收藏,388浏览
黄生 一段
粉丝:1人 关注:1人
我配置端口G0/0为WAN口,IP地址192.168.1.199/24,G0/1为内网端口,地址为192.168.3.1/24,开启DHCP,地址池192.168.3.2-254/24
电脑接在G0/1口后,获取了IP :192.168.3.2/24,
下面是配置文件
 version 7.1.042, Release 0007P02
 sysname H3C
 telnet server enable
 dhcp enable
 dhcp server always-broadcast
 system-working-mode
 password-recovery enable
vlan 1
dhcp server ip-pool vlan1
 network 192.168.2.0 mask 255.255.255.0
 forbidden-ip 192.168.2.1
 forbidden-ip 192.168.2.254
 gateway-list 192.168.2.1
dhcp server ip-pool www
 network 192.168.3.0 mask 255.255.255.0
 address range 192.168.3.2 192.168.3.254
 expired day 10
 gateway-list 192.168.3.1
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 192.168.1.199 255.255.255.0
 nat outbound 2000
interface GigabitEthernet0/1
 ip address 192.168.3.1 255.255.255.0
 dhcp server apply ip-pool www
interface GigabitEthernet0/2
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 192.168.1.1
acl number 2000
 rule 1000 permit source 0.0.0.0 255.255.255.0
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit http 16
 aaa session-limit ssh 16
 aaa session-limit https 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$TBC/kwP6u5AUmzHz$Lw8GqQiBy7Ws9s9qfNJhB5WjmVuT/4xeMfix8vWsGLqHjT8Xb/MW4UZrfAkiFps5VLW1umewwMgdv2mv06jYYw==
 service-type http https
 authorization-attribute user-role 15
nat address-group 1
 address 192.168.3.2 192.168.3.254
return
ACL 2000配置的有问题,
改成 rule 1000 permit source 192.168.3.0 0.0.0.255
搞定了,感谢
黄生 发表时间:2023-11-20
粉丝:171人 关注:8人
192.168.1.1在哪?
192.168.1.1就是路由器r1的lan口地址
黄生 发表时间:2023-11-20
接口是up的么,能看到相应的arp信息么
zhiliao_sEUyB 发表时间:2023-11-20
ACL写错了,直接允许所有就好了
粉丝:17人 关注:9人
从反馈的信息来看,有ACL的配置。
可以先把ACL给去掉,然后看看能不能通,如果可以,那就是ACL的问题,具体检查ACL的配置是否满足需求了,根据需要修改ACL的配置。
