路由器36 40 授权激活不能配MPLS
2023-11-29提问
  • 0收藏,323浏览
设备激活重启过。设备上查授权显示设备是激活的。是不是要授权有问题?
粉丝:1人 关注:1人
(1)      检查软件包是否加载
  <H3C>display install active    //发现这里没有加载数据软件包
Active packages on the device:
cfa0:/msr36-cmw710-boot-R0106.bin
cfa0:/msr36-cmw710-system-R0106.bin
cfa0:/msr36-cmw710-data-R0106.bin
(2)      在设备没有激活license时,对应的软件包不会加载,在激活license后需要手动加载软件包
<H3C>install activate feature cfa0:/msr36-cmw710-data-r0106.bin
Running Version New Version
None Release 0106
Upgrade Way: Service Upgrade
This operation maybe take several minutes, please wait.Done.
3)退出命令行并再次通过命令行登录
zhiliao_eTLMO0 知了小白
[ZH-CB-PingW-RenJiaBa110kV-AR]qu
<ZH-CB-PingW-RenJiaBa110kV-AR>dis in
<ZH-CB-PingW-RenJiaBa110kV-AR>dis info-center
<ZH-CB-PingW-RenJiaBa110kV-AR>dis inspect
<ZH-CB-PingW-RenJiaBa110kV-AR>dis install ac
<ZH-CB-PingW-RenJiaBa110kV-AR>dis install active
cfa0:/msr36-cmw710-boot-r0821p13.bin
cfa0:/msr36-cmw710-system-r0821p13.bin
<ZH-CB-PingW-RenJiaBa110kV-AR>display license
cfa0:/license/210235A0W8P21700007H2023112918282126879.ak
Feature: pkg_license
没有这个
Product Description: H3C MSR 36 Data Software License
Registered at: 2023-11-29 18:10:18
License Type: Permanent
Current State: In use
<ZH-CB-PingW-RenJiaBa110kV-AR>sy
[ZH-CB-PingW-RenJiaBa110kV-AR]mp
[ZH-CB-PingW-RenJiaBa110kV-AR]mpls l
[ZH-CB-PingW-RenJiaBa110kV-AR]mpls l?
% Wrong parameter found at '^' position.
