分部26-00 V5版本 对接总部天融信的设备
2023-12-23提问
  • 0收藏,288浏览
粉丝:1人 关注:9人
总部与分布二阶段起不来,怎么看debugging信息有问题吗,debugging信息在哪里能翻译,能看具体什么意思。采用主模式,3des,MD5,dh1
*Dec 22 15:28:43:241 2023 H3C IPSEC/7/DBG:
 ipsec nat bypass is not enable.
*Dec 22 15:28:43:341 2023 H3C IKE/7/DEBUG: received message:
*Dec 22 15:28:43:392 2023 H3C IKE/7/DEBUG:   ICOOKIE: 0x1d8da5014431721e
*Dec 22 15:28:43:392 2023 H3C IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Dec 22 15:28:43:492 2023 H3C IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Dec 22 15:28:43:592 2023 H3C IKE/7/DEBUG:   VERSION: 16
*Dec 22 15:28:43:642 2023 H3C IKE/7/DEBUG:   EXCH_TYPE: MAIN
*Dec 22 15:28:43:743 2023 H3C IKE/7/DEBUG:   FLAGS: [ ]
*Dec 22 15:28:43:843 2023 H3C IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Dec 22 15:28:43:893 2023 H3C IKE/7/DEBUG:   LENGTH: 284
*Dec 22 15:28:43:993 2023 H3C IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 1d8da5014431721e
*Dec 22 15:28:44:044 2023 H3C IKE/7/DEBUG: parse payloads: payload SA
*Dec 22 15:28:44:144 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
*Dec 22 15:28:44:194 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
*Dec 22 15:28:44:244 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
%Dec 22 15:28:44:344 2023 H3C IKE/4/IKE_PACKET_DROPPED: -Src addr=*.*.*.*-Dst addr=*.*.*.*-I_COOKIE=d9b4c92fa1613e71-R_COOKIE=0000000000000000-Cause=No proposal is chosen-Payload=PROPOSAL; IKE packet dropped.
*Dec 22 15:28:44:395 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
*Dec 22 15:28:44:445 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
*Dec 22 15:28:44:495 2023 H3C IKE/7/DEBUG: parse payloads: payload VENDOR
*Dec 22 15:28:44:646 2023 H3C IKE/7/DEBUG: validate payload SA
*Dec 22 15:28:44:696 2023 H3C IKE/7/DEBUG:   DOI: 1
*Dec 22 15:28:44:796 2023 H3C IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Dec 22 15:28:44:846 2023 H3C IKE/7/DEBUG: 4f454578 616c467b 5f6f606d 0d000014
*Dec 22 15:28:44:946 2023 H3C IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Dec 22 15:28:45:147 2023 H3C IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Dec 22 15:28:45:247 2023 H3C IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-03 Protocol Vendor ID
*Dec 22 15:28:45:297 2023 H3C IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Dec 22 15:28:45:397 2023 H3C IKE/7/DEBUG: cd604643 35df21f8 7cfdb2fc 68b6a448
*Dec 22 15:28:45:447 2023 H3C IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-01 Protocol Vendor ID
*Dec 22 15:28:45:498 2023 H3C IKE/7/DEBUG: Find IKE peer by address.
  IfIndex:0x00100005.
  local addr:*.*.*.*, remote addr:*.*.*.*.
*Dec 22 15:28:45:598 2023 H3C IKE/7/DEBUG: P1 responder exchange setup Main mode: IKE peer name:1
*Dec 22 15:28:45:698 2023 H3C IKE/7/DEBUG: P1 responder exchange setup: Connection name is *.*.*.*,*.*.*.*,500,,0,0,0
*Dec 22 15:28:45:748 2023 H3C IKE/7/DEBUG: exchange setup(R): 9ee2c00
*Dec 22 15:28:45:849 2023 H3C IKE/7/DEBUG: parse payloads: payload PROPOSAL
*Dec 22 15:28:45:949 2023 H3C IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Dec 22 15:28:46:049 2023 H3C IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Dec 22 15:28:46:099 2023 H3C IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Dec 22 15:28:46:250 2023 H3C IKE/7/DEBUG: validate payload PROPOSAL
*Dec 22 15:28:46:400 2023 H3C IKE/7/DEBUG:   NO: 0
*Dec 22 15:28:46:500 2023 H3C IKE/7/DEBUG:   PROTO: ISAKMP
*Dec 22 15:28:46:600 2023 H3C IKE/7/DEBUG:   SPI_SZ: 0
*Dec 22 15:28:46:701 2023 H3C IKE/7/DEBUG:   NTRANSFORMS: 3
*Dec 22 15:28:46:751 2023 H3C IKE/7/DEBUG: validate payload TRANSFORM
*Dec 22 15:28:46:851 2023 H3C IKE/7/DEBUG:   NO: 0
*Dec 22 15:28:46:951 2023 H3C IKE/7/DEBUG:   ID: 1
*Dec 22 15:28:47:001 2023 H3C IKE/7/DEBUG:   Transform 0's attributes
*Dec 22 15:28:47:102 2023 H3C IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Dec 22 15:28:47:152 2023 H3C IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Dec 22 15:28:47:202 2023 H3C IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Dec 22 15:28:47:252 2023 H3C IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Dec 22 15:28:47:352 2023 H3C IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Dec 22 15:28:47:403 2023 H3C IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1536
*Dec 22 15:28:47:453 2023 H3C IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Dec 22 15:28:47:503 2023 H3C IKE/7/DEBUG: validate payload TRANSFORM
*Dec 22 15:28:47:603 2023 H3C IKE/7/DEBUG:   NO: 1
*Dec 22 15:28:47:654 2023 H3C IKE/7/DEBUG:   ID: 1o
*Dec 22 15:28:47:854 2023 H3C IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Dec 22 15:28:47:904 2023 H3C IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Dec 22 15:28:48:006 2023 H3C IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Dec 22 15:28:48:106 2023 H3C IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Dec 22 15:28:48:207 2023 H3C IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Dec 22 15:28:48:257 2023 H3C IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Dec 22 15:28:48:307 2023 H3C IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Dec 22 15:28:48:357 2023 H3C IKE/7/DEBUG: validate payload TRANSFORM
*Dec 22 15:28:48:357 2023 H3C IKE/7/DEBUG:   NO: 2
*Dec 22 15:28:48:458 2023 H3C IKE/7/DEBUG:   ID: 1
*Dec 22 15:28:48:508 2023 H3C IKE/7/DEBUG:   Transform 2's attributes
*Dec 22 15:28:48:608 2023 H3C IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Dec 22 15:28:48:708 2023 H3C IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Dec 22 15:28:48:809 2023 H3C IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Dec 22 15:28:48:909 2023 H3C IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Dec 22 15:28:48:959 2023 H3C IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Dec 22 15:28:49:059 2023 H3C IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_768
*Dec 22 15:28:49:110 2023 H3C IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Dec 22 15:28:49:160 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:49:210 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:49:310 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:49:411 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:49:461 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:49:561 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:49:662 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:49:762 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:49:813 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:49:914 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:49:964 2023 H3C IKE/7/DEBUG: validate payload VENDOR
*Dec 22 15:28:50:014 2023 H3C IKE/7/DEBUG:   vendor ID seen
*Dec 22 15:28:50:115 2023 H3C IKE/7/DEBUG: exchange check: checking for required SA
*Dec 22 15:28:50:165 2023 H3C IKE/7/DEBUG: negotiate sa: transform 0 proto 1 proposal 0 compatible
*Dec 22 15:28:50:215 2023 H3C IKE/7/DEBUG: negotiate sa: proposal 0 failed
*Dec 22 15:28:50:315 2023 H3C IKE/7/DEBUG: negotiate sa: transform 1 proto 1 proposal 0 compatible
*Dec 22 15:28:50:366 2023 H3C IKE/7/DEBUG: negotiate sa: proposal 0 failed
*Dec 22 15:28:50:416 2023 H3C IKE/7/DEBUG: negotiate sa: transform 2 proto 1 proposal 0 compatible
*Dec 22 15:28:50:516 2023 H3C IKE/7/DEBUG: negotiate sa: proposal 0 failed
*Dec 22 15:28:50:566 2023 H3C IKE/7/DEBUG: dropped message from *.*.*.* due to notification type NO_PROPOSAL_CHOSEN
*Dec 22 15:28:50:616 2023 H3C IKE/7/DEBUG: exchange setup(I): 9ee4140
*Dec 22 15:28:50:717 2023 H3C IKE/7/DEBUG: add payload to message: NOTIFY
*Dec 22 15:28:50:817 2023 H3C IKE/7/DEBUG:   DOI: IPSEC
*Dec 22 15:28:50:918 2023 H3C IKE/7/DEBUG:   PROTO: ISAKMP
*Dec 22 15:28:51:018 2023 H3C IKE/7/DEBUG:   SPI_SZ: 0
*Dec 22 15:28:51:068 2023 H3C IKE/7/DEBUG:   MSG_TYPE: NO_PROPOSAL_CHOSEN
*Dec 22 15:28:51:169 2023 H3C IKE/7/DEBUG: exchange check: checking for required INFO
*Dec 22 15:28:51:269 2023 H3C IKE/7/DEBUG: send message:
*Dec 22 15:28:51:419 2023 H3C IKE/7/DEBUG:   ICOOKIE: 0x1d8da5014431721e
*Dec 22 15:28:51:469 2023 H3C IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Dec 22 15:28:51:569 2023 H3C IKE/7/DEBUG:   NEXT_PAYLOAD: NOTIFY
*Dec 22 15:28:51:620 2023 H3C IKE/7/DEBUG:   VERSION: 16
*Dec 22 15:28:51:670 2023 H3C IKE/7/DEBUG:   EXCH_TYPE: INFO
*Dec 22 15:28:51:720 2023 H3C IKE/7/DEBUG:   FLAGS: [ ]
*Dec 22 15:28:51:820 2023 H3C IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Dec 22 15:28:51:921 2023 H3C IKE/7/DEBUG:   LENGTH: 44
*Dec 22 15:28:51:971 2023 H3C IKE/7/DEBUG: exchange state machine(I): finished step 0, advancing...
*Dec 22 15:28:52:021 2023 H3C IKE/7/DEBUG: exchange state machine: Failed to handle received message.
*Dec 22 15:28:52:121 2023 H3C IKE/7/DEBUG: exchange release: freeing exchange 9ee2c00
*Dec 22 15:28:52:171 2023 H3C IPSEC/7/DBG:
%Dec 22 15:28:53:877 2023 H3C IKE/4/IKE_PACKET_DROPPED: -Src addr=*.*.*.*-Dst addr=*.*.*.*-I_COOKIE=d9b4c92fa1613e71-R_COOKIE=0000000000000000-Cause=No proposal is chosen-Payload=PROPOSAL; IKE packet dropped.
粉丝:44人 关注:2人
你nat 是怎么配置的?
  ipsec nat bypass is not enable. 这个提示应该是nat 配置有问题,导致的
出接口没做nat啊
正在重新连接0 发表时间:2023-12-23
粉丝:17人 关注:9人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
