设备版本:7.1.064P80, Release 6728P25
cpu 一直处于50以上的利用率,会不会影响转发?
===============display cpu===============
Unit CPU usage:
59% in last 5 seconds
54% in last 1 minute
51% in last 5 minutes
以下内容只是截取部分
===============display process===============
JID PID %CPU %MEM STAT PRI THIRD TTY HH:MM:SS COMMAND
1 1 0.1 0.0 S 120 N - 00:00:26 scmd
2 2 0.0 0.0 S 115 N - 00:00:00 [kthreadd]
3 3 0.0 0.0 S 99 N - 00:00:00 [migration/0]
4 4 0.0 0.0 S 115 N - 00:00:00 [ksoftirqd/0]
5 5 0.0 0.0 S 99 N - 00:00:00 [watchdog/0]
6 6 0.0 0.0 S 99 N - 00:00:00 [migration/1]
7 7 0.0 0.0 S 115 N - 00:00:00 [ksoftirqd/1]
8 8 0.0 0.0 S 99 N - 00:00:00 [watchdog/1]
9 9 0.0 0.0 S 115 N - 00:00:00 [events/0]
10 10 0.0 0.0 S 115 N - 00:00:00 [events/1]
11 11 0.0 0.0 S 115 N - 00:00:00 [khelper]
12 12 0.0 0.0 S 115 N - 00:00:00 [kblockd/0]
13 13 0.0 0.0 S 115 N - 00:00:00 [kblockd/1]
14 14 0.0 0.0 S 115 N - 00:00:00 [ata/0]
15 15 0.0 0.0 S 115 N - 00:00:00 [ata/1]
16 16 0.0 0.0 S 115 N - 00:00:00 [ata_aux]
17 17 0.0 0.0 S 115 N - 00:00:00 [khubd]
18 18 0.0 0.0 S 115 N - 00:00:00 [kseriod]
19 19 0.0 0.0 S 120 N - 00:00:00 [vzmond]
20 20 0.0 0.0 S 120 N - 00:00:00 [pdflush]
21 21 0.0 0.0 S 120 N - 00:00:00 [pdflush]
22 22 0.0 0.0 S 115 N - 00:00:00 [kswapd0]
23 23 0.0 0.0 S 115 N - 00:00:00 [aio/0]
24 24 0.0 0.0 S 115 N - 00:00:00 [aio/1]
25 25 0.0 0.0 S 115 N - 00:00:00 [mtdblockd]
46 46 0.0 0.0 S 115 N - 00:00:00 [BTTY_DT]
47 47 0.0 0.0 S 115 N - 00:00:00 [BTTY_CT]
48 48 0.0 0.0 S 115 N - 00:00:00 [BTTY_CTAct]
49 49 0.0 0.0 S 115 N - 00:00:00 [BTTY_TXT]
61 61 0.0 0.0 S 115 N - 00:00:03 [DRV_MboardInt]
62 62 0.0 0.0 S 115 N - 00:00:00 [commontask]
63 63 0.0 0.0 D 115 N - 00:00:01 [drv_txdone]
64 64 0.0 0.0 S 115 N - 00:00:00 [STTY_DT]
65 65 0.0 0.0 S 115 N - 00:00:00 [STTY_CT]
66 66 0.0 0.0 S 115 N - 00:00:00 [STTY_CTAct]
67 67 52.5 0.0 R 115 N - 549h [kdrvfwdd1]
kdrvfwdd1 这一个又是那一个模块,与转发有关系吗?谢谢
(0)
kdrvfwdd1 是转发进程,若cpu不持续增长,则无需关注,若cpu持续增长,需关注
检查下路由器是否有相应的logbuffer的日志反馈。
同时使用dis counter inbound interface和dis counter outbound interface命令查看端口的各类型的报文是否快速增长的现象。
检查下是否存在二层的物理环路或三层的路由环路。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
请教下,就是CPU 在50--60之间,这款设备时正常现象?
