MSR3600x1
2024-01-25提问
  • 0收藏,274浏览
设备版本:7.1.064P80, Release 6728P25
cpu 一直处于50以上的利用率,会不会影响转发?
  ===============display cpu===============
Unit CPU usage:
      59% in last 5 seconds
      54% in last 1 minute
      51% in last 5 minutes
以下内容只是截取部分
  ===============display process===============
       JID        PID %CPU %MEM STAT PRI THIRD     TTY HH:MM:SS COMMAND
         1          1  0.1  0.0   S  120   N        -  00:00:26 scmd
         2          2  0.0  0.0   S  115   N        -  00:00:00 [kthreadd]
         3          3  0.0  0.0   S   99   N        -  00:00:00 [migration/0]
         4          4  0.0  0.0   S  115   N        -  00:00:00 [ksoftirqd/0]
         5          5  0.0  0.0   S   99   N        -  00:00:00 [watchdog/0]
         6          6  0.0  0.0   S   99   N        -  00:00:00 [migration/1]
         7          7  0.0  0.0   S  115   N        -  00:00:00 [ksoftirqd/1]
         8          8  0.0  0.0   S   99   N        -  00:00:00 [watchdog/1]
         9          9  0.0  0.0   S  115   N        -  00:00:00 [events/0]
        10         10  0.0  0.0   S  115   N        -  00:00:00 [events/1]
        11         11  0.0  0.0   S  115   N        -  00:00:00 [khelper]
        12         12  0.0  0.0   S  115   N        -  00:00:00 [kblockd/0]
        13         13  0.0  0.0   S  115   N        -  00:00:00 [kblockd/1]
        14         14  0.0  0.0   S  115   N        -  00:00:00 [ata/0]
        15         15  0.0  0.0   S  115   N        -  00:00:00 [ata/1]
        16         16  0.0  0.0   S  115   N        -  00:00:00 [ata_aux]
        17         17  0.0  0.0   S  115   N        -  00:00:00 [khubd]
        18         18  0.0  0.0   S  115   N        -  00:00:00 [kseriod]
        19         19  0.0  0.0   S  120   N        -  00:00:00 [vzmond]
        20         20  0.0  0.0   S  120   N        -  00:00:00 [pdflush]
        21         21  0.0  0.0   S  120   N        -  00:00:00 [pdflush]
        22         22  0.0  0.0   S  115   N        -  00:00:00 [kswapd0]
        23         23  0.0  0.0   S  115   N        -  00:00:00 [aio/0]
        24         24  0.0  0.0   S  115   N        -  00:00:00 [aio/1]
        25         25  0.0  0.0   S  115   N        -  00:00:00 [mtdblockd]
        46         46  0.0  0.0   S  115   N        -  00:00:00 [BTTY_DT]
        47         47  0.0  0.0   S  115   N        -  00:00:00 [BTTY_CT]
        48         48  0.0  0.0   S  115   N        -  00:00:00 [BTTY_CTAct]
        49         49  0.0  0.0   S  115   N        -  00:00:00 [BTTY_TXT]
        61         61  0.0  0.0   S  115   N        -  00:00:03 [DRV_MboardInt]
        62         62  0.0  0.0   S  115   N        -  00:00:00 [commontask]
        63         63  0.0  0.0   D  115   N        -  00:00:01 [drv_txdone]
        64         64  0.0  0.0   S  115   N        -  00:00:00 [STTY_DT]
        65         65  0.0  0.0   S  115   N        -  00:00:00 [STTY_CT]
        66         66  0.0  0.0   S  115   N        -  00:00:00 [STTY_CTAct]
        67         67 52.5  0.0   R  115   N        -      549h [kdrvfwdd1]
kdrvfwdd1 这一个又是那一个模块,与转发有关系吗?谢谢
kdrvfwdd1 是转发进程,若cpu不持续增长,则无需关注,若cpu持续增长,需关注
检查下路由器是否有相应的logbuffer的日志反馈。
同时使用dis counter inbound interface和dis counter outbound interface命令查看端口的各类型的报文是否快速增长的现象。
检查下是否存在二层的物理环路或三层的路由环路。
请教下,就是CPU 在50--60之间,这款设备时正常现象?
zhiliao_urb28O 发表时间:2024-01-25
粉丝:12人 关注:1人
问题不大,50%不影响使用的,kdrvfwdd1 这个就是转发进程,不超过70%一般都没大问题
