S7503X对接ET924-H-POE端口反复震荡
2024-03-28提问
  • 0收藏,180浏览
S7503X一个OLT接口同时对接EGT358-POTS/A和ET924-H-POE,开启自动上线和全局配置所有 ONU 上行最大带宽为上行总带宽的 100%
ET924-H-POE所在ONU接口反复UP和DOWN
日志情况:
%Mar 28 09:51:20:834 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Onu3/0/1:1 changed to up.
%Mar 28 09:51:20:836 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Onu3/0/1:1 changed to up.
%Mar 28 09:51:20:837 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Vlan-interface301 changed to up.
%Mar 28 09:51:20:838 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Vlan-interface301 changed to up.
%Mar 28 09:51:22:124 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Onu3/0/1:1 changed to down.
%Mar 28 09:51:22:126 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Onu3/0/1:1 changed to down.
%Mar 28 09:51:22:128 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Vlan-interface301 changed to down.
%Mar 28 09:51:22:128 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Vlan-interface301 changed to down.
%Mar 28 09:51:36:621 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Onu3/0/1:1 changed to up.
%Mar 28 09:51:36:621 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Onu3/0/1:1 changed to up.
%Mar 28 09:51:36:625 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Vlan-interface301 changed to up.
%Mar 28 09:51:36:625 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Vlan-interface301 changed to up.
%Mar 28 09:51:37:820 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Onu3/0/1:1 changed to down.
%Mar 28 09:51:37:823 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Onu3/0/1:1 changed to down.
%Mar 28 09:51:37:823 2024 LHXX-WIRELESS-OLT-SW IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Vlan-interface301 changed to down.
%Mar 28 09:51:37:826 2024 LHXX-WIRELESS-OLT-SW IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Vlan-interface301 changed to down.
OLT通过1:8分光器对接ONU
