路由器接入2条公网,一条接入GE1/0/2,IP为39.164.83.144,网络正常。另一条接入GE1/0/8,IP为117.159.229.25,网络不通。以下为问题现象:
1、外网ping117.159.229.25不用
2、10.7.168.200:10443内网正常,外网117.159.229.25:10443映射不通。
以下是路由器的配置,请帮看看是哪里的配置问题:
version 7.1.064, Release 8560P39
sysname H3C
clock protocol none
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
dns server 8.8.8.8
dns server 114.114.114.114
password-recovery enable
vlan 1
interface NULL0
interface GigabitEthernet1/0/0
port link-mode route
ip address 192.168.10.1 255.255.255.0
description GuideWan Interface
ip address 39.164.83.144 255.255.255.128
dns server 211.138.24.66
dns server 211.138.30.66
nat server protocol tcp global current-interface 76 inside 10.7.168.16 80 rule S1
nat server protocol tcp global current-interface 78 inside 10.7.168.15 8888 rule ServerRule_8
nat server protocol tcp global current-interface 81 inside 10.7.168.10 80 rule ServerRule_9
nat server protocol tcp global current-interface 83 inside 10.7.168.14 83 rule ServerRule_10
nat server protocol tcp global current-interface 84 inside 10.7.168.13 22 rule ServerRule_11
nat server protocol tcp global current-interface 85 inside 10.7.168.14 55555 rule ServerRule_12
nat server protocol tcp global current-interface 86 inside 10.7.168.12 22 rule ServerRule_13 disable
nat server protocol tcp global current-interface 87 inside 10.5.168.1 22 rule ServerRule_57 disable
nat server protocol tcp global current-interface 88 inside 10.10.168.1 22 rule ServerRule_58 disable
nat server protocol tcp global current-interface 123 inside 10.7.168.14 123 rule ServerRule_14
nat server protocol tcp global current-interface 443 inside 10.5.168.1 443 rule ServerRule_55
nat server protocol tcp global current-interface 552 inside 10.7.168.15 555 rule ServerRule_15
nat server protocol tcp global current-interface 553 inside 10.7.168.15 555 rule ServerRule_16
nat server protocol tcp global current-interface 554 inside 10.7.168.14 554 rule ServerRule_17
nat server protocol tcp global current-interface 559 inside 10.7.168.14 559 rule ServerRule_18
nat server protocol tcp global current-interface 655 inside 10.7.168.14 655 rule ServerRule_19
nat server protocol tcp global current-interface 1443 inside 10.7.168.14 443 rule ServerRule_20
nat server protocol tcp global current-interface 1935 inside 10.7.168.14 1935 rule ServerRule_21
nat server protocol tcp global current-interface 2330 inside 10.7.168.1 23 rule ServerRule_22 disable
nat server protocol tcp global current-interface 5010 inside 10.7.168.14 5010 rule ServerRule_23
nat server protocol tcp global current-interface 6009 inside 10.7.168.14 6009 rule ServerRule_24
nat server protocol tcp global current-interface 6014 inside 10.7.168.14 6015 rule ServerRule_25
nat server protocol tcp global current-interface 6201 inside 10.5.168.3 6201 rule SerRule1
nat server protocol tcp global current-interface 6633 inside 192.168.2.1 6633 rule ServerRule_26
nat server protocol tcp global current-interface 7010 inside 10.7.168.14 7010 rule ServerRule_27
nat server protocol tcp global current-interface 7031 inside 10.7.168.14 7031 rule ServerRule_28
nat server protocol tcp global current-interface 7033 inside 10.7.168.14 7033 rule ServerRule_29
nat server protocol tcp global current-interface 7087 inside 10.7.168.14 7087 rule ServerRule_30
nat server protocol tcp global current-interface 7099 inside 10.7.168.14 7199 rule ServerRule_31
nat server protocol tcp global current-interface 7100 inside 10.7.168.14 7100 rule ServerRule_32
nat server protocol tcp global current-interface 7302 inside 10.7.168.14 7303 rule ServerRule_33
nat server protocol tcp global current-interface 7304 inside 10.7.168.14 7304 rule ServerRule_34
nat server protocol tcp global current-interface 7307 inside 10.7.168.14 7307 rule ServerRule_35
nat server protocol tcp global current-interface 7314 inside 10.7.168.14 7314 rule ServerRule_36
nat server protocol tcp global current-interface 7660 inside 10.7.168.14 7660 rule ServerRule_37
nat server protocol tcp global current-interface 8000 inside 10.7.168.10 8001 rule ServerRule_38
nat server protocol tcp global current-interface 8001 inside 10.7.168.14 18001 rule ServerRule_39
nat server protocol tcp global current-interface 8002 inside 10.7.168.16 8001 rule ServerRule_40
nat server protocol tcp global current-interface 8003 inside 10.7.168.15 8001 rule ServerRule_41
nat server protocol tcp global current-interface 8098 inside 10.5.168.1 443 rule ServerRule_42
nat server protocol tcp global current-interface 8201 8202 inside 10.7.168.13 8201 8202 rule ServerRule_43
nat server protocol tcp global current-interface 8204 inside 10.7.168.13 8204 rule ServerRule_44
nat server protocol tcp global current-interface 8208 8220 inside 10.7.168.13 8208 8220 rule ServerRule_45
nat server protocol tcp global current-interface 8222 8400 inside 10.7.168.13 8222 8400 rule ServerRule_46
nat server protocol tcp global current-interface 8603 inside 10.7.168.14 10000 rule ServerRule_47
nat server protocol tcp global current-interface 8800 8999 inside 10.7.168.14 8800 8999 rule ServerRule_48
nat server protocol tcp global current-interface 9017 inside 10.7.168.14 10000 rule ServerRule_49
nat server protocol tcp global current-interface 9018 inside 10.7.168.14 9017 rule ServerRule_50
nat server protocol tcp global current-interface 15000 16999 inside 10.7.168.14 15000 16999 rule ServerRule_51
nat server protocol tcp global current-interface 17000 inside 10.7.168.14 17000 rule ServerRule_52
nat server protocol tcp global current-interface 55555 inside 10.7.168.14 55554 rule ServerRule_53
nat server protocol udp global current-interface 53 inside 10.7.168.13 56666 rule ServerRule_54
manage http inbound
manage http outbound
manage https inbound
manage https outbound
manage netconf-http inbound
manage netconf-https inbound
manage netconf-ssh inbound
manage ping inbound
manage ping outbound
manage snmp inbound
manage ssh inbound
manage ssh outbound
manage telnet inbound
manage telnet outbound
gateway 39.164.83.129
interface GigabitEthernet1/0/4
description GuideLan Interface
ip address 10.5.168.1 255.255.255.0
manage http inbound
manage ping inbound
manage snmp inbound
manage ssh inbound
manage ssh outbound
undo dhcp select server
interface GigabitEthernet1/0/6
ip address 10.10.168.1 255.255.255.0
manage http inbound
manage ping inbound
manage snmp inbound
manage ssh inbound
manage ssh outbound
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
ip address 117.159.229.25 255.255.255.192
nat server protocol tcp global 117.159.229.25 10443 inside 10.7.168.200 10443 rule other-1
manage http inbound
manage ping inbound
manage snmp inbound
manage ssh inbound
manage ssh outbound
gateway 117.159.229.1
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/5
port link-mode bridge
security-zone name Local
security-zone name Trust
import interface GigabitEthernet1/0/4
import interface GigabitEthernet1/0/6
security-zone name DMZ
security-zone name Untrust
import interface GigabitEthernet1/0/2
import interface GigabitEthernet1/0/8
security-zone name Management
import interface GigabitEthernet1/0/0
scheduler logfile size 16
line class aux
user-role network-operator
line class console
authentication-mode scheme
user-role network-admin
line class vty
line aux 0
authentication-mode none
line con 0
line vty 0 63
ip route-static 0.0.0.0 0 GigabitEthernet1/0/2 39.164.83.129 preference 59
ip route-static 0.0.0.0 0 GigabitEthernet1/0/8 117.159.229.1 preference 61
ip route-static 10.0.0.0 8 GigabitEthernet1/0/4 10.5.168.2
performance-management
ssh server enable
undo password-control blacklist all-line
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$xc15w2Hq/cSxfUBl$75tYgHWaGc4pRoDFm9DLXXKcUbXsLljSuPZUoN0Ao4A7MTUvaTSbASw7qRF4K4SDjCb/ARHpaKqHfnR9/rc0qA==
service-type ssh terminal https
authorization-attribute user-role level-3
nat global-policy
rule name GlobalPolicyRule_1
description GuideNat
source-zone Trust
destination-zone Untrust
action snat easy-ip
ip https enable
loadbalance isp file flash:/lbispinfo_v1.5.tp
security-policy ip
rule 3 name GuideSecPolicy
action pass
cloud-management server domain opstunnel-seccloud.h3c.com
return
(0)
你这做主备了 啊
(0)
需要如何配置,变成主主,2个公网都能用
路由优先级一致,
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
请问优先级我配置成一致吗?如果配置一致后,感觉之前对39.164.83.129的外网映射全部不通了
开启保持上一跳功能,另外 如果是单机情况下推荐用接口nat 不用全局nat
