H3C SecPath F100+双wan口配置+序列号219801A3EK923AQ00060
2024-04-09提问
  • 0收藏,131浏览
路由器接入2条公网,一条接入GE1/0/2,IP为39.164.83.144,网络正常。另一条接入GE1/0/8,IP为117.159.229.25,网络不通。以下为问题现象:
1、外网ping117.159.229.25不用
2、10.7.168.200:10443内网正常,外网117.159.229.25:10443映射不通。
以下是路由器的配置,请帮看看是哪里的配置问题:
 version 7.1.064, Release 8560P39
 sysname H3C
 clock protocol none
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dns server 8.8.8.8
 dns server 114.114.114.114
 password-recovery enable
vlan 1
interface NULL0
interface GigabitEthernet1/0/0
 port link-mode route
 ip address 192.168.10.1 255.255.255.0
 description GuideWan Interface
 ip address 39.164.83.144 255.255.255.128
 dns server 211.138.24.66
 dns server 211.138.30.66
 nat server protocol tcp global current-interface 76 inside 10.7.168.16 80 rule S1
 nat server protocol tcp global current-interface 78 inside 10.7.168.15 8888 rule ServerRule_8
 nat server protocol tcp global current-interface 81 inside 10.7.168.10 80 rule ServerRule_9
 nat server protocol tcp global current-interface 83 inside 10.7.168.14 83 rule ServerRule_10
 nat server protocol tcp global current-interface 84 inside 10.7.168.13 22 rule ServerRule_11
 nat server protocol tcp global current-interface 85 inside 10.7.168.14 55555 rule ServerRule_12
 nat server protocol tcp global current-interface 86 inside 10.7.168.12 22 rule ServerRule_13 disable
 nat server protocol tcp global current-interface 87 inside 10.5.168.1 22 rule ServerRule_57 disable
 nat server protocol tcp global current-interface 88 inside 10.10.168.1 22 rule ServerRule_58 disable
 nat server protocol tcp global current-interface 123 inside 10.7.168.14 123 rule ServerRule_14
 nat server protocol tcp global current-interface 443 inside 10.5.168.1 443 rule ServerRule_55
 nat server protocol tcp global current-interface 552 inside 10.7.168.15 555 rule ServerRule_15
 nat server protocol tcp global current-interface 553 inside 10.7.168.15 555 rule ServerRule_16
 nat server protocol tcp global current-interface 554 inside 10.7.168.14 554 rule ServerRule_17
 nat server protocol tcp global current-interface 559 inside 10.7.168.14 559 rule ServerRule_18
 nat server protocol tcp global current-interface 655 inside 10.7.168.14 655 rule ServerRule_19
 nat server protocol tcp global current-interface 1443 inside 10.7.168.14 443 rule ServerRule_20
 nat server protocol tcp global current-interface 1935 inside 10.7.168.14 1935 rule ServerRule_21
 nat server protocol tcp global current-interface 2330 inside 10.7.168.1 23 rule ServerRule_22 disable
 nat server protocol tcp global current-interface 5010 inside 10.7.168.14 5010 rule ServerRule_23
 nat server protocol tcp global current-interface 6009 inside 10.7.168.14 6009 rule ServerRule_24
 nat server protocol tcp global current-interface 6014 inside 10.7.168.14 6015 rule ServerRule_25
 nat server protocol tcp global current-interface 6201 inside 10.5.168.3 6201 rule SerRule1
 nat server protocol tcp global current-interface 6633 inside 192.168.2.1 6633 rule ServerRule_26
 nat server protocol tcp global current-interface 7010 inside 10.7.168.14 7010 rule ServerRule_27
 nat server protocol tcp global current-interface 7031 inside 10.7.168.14 7031 rule ServerRule_28
 nat server protocol tcp global current-interface 7033 inside 10.7.168.14 7033 rule ServerRule_29
 nat server protocol tcp global current-interface 7087 inside 10.7.168.14 7087 rule ServerRule_30
 nat server protocol tcp global current-interface 7099 inside 10.7.168.14 7199 rule ServerRule_31
 nat server protocol tcp global current-interface 7100 inside 10.7.168.14 7100 rule ServerRule_32
 nat server protocol tcp global current-interface 7302 inside 10.7.168.14 7303 rule ServerRule_33
 nat server protocol tcp global current-interface 7304 inside 10.7.168.14 7304 rule ServerRule_34
 nat server protocol tcp global current-interface 7307 inside 10.7.168.14 7307 rule ServerRule_35
 nat server protocol tcp global current-interface 7314 inside 10.7.168.14 7314 rule ServerRule_36
 nat server protocol tcp global current-interface 7660 inside 10.7.168.14 7660 rule ServerRule_37
 nat server protocol tcp global current-interface 8000 inside 10.7.168.10 8001 rule ServerRule_38
 nat server protocol tcp global current-interface 8001 inside 10.7.168.14 18001 rule ServerRule_39
 nat server protocol tcp global current-interface 8002 inside 10.7.168.16 8001 rule ServerRule_40
 nat server protocol tcp global current-interface 8003 inside 10.7.168.15 8001 rule ServerRule_41
 nat server protocol tcp global current-interface 8098 inside 10.5.168.1 443 rule ServerRule_42
 nat server protocol tcp global current-interface 8201 8202 inside 10.7.168.13 8201 8202 rule ServerRule_43
 nat server protocol tcp global current-interface 8204 inside 10.7.168.13 8204 rule ServerRule_44
 nat server protocol tcp global current-interface 8208 8220 inside 10.7.168.13 8208 8220 rule ServerRule_45
 nat server protocol tcp global current-interface 8222 8400 inside 10.7.168.13 8222 8400 rule ServerRule_46
 nat server protocol tcp global current-interface 8603 inside 10.7.168.14 10000 rule ServerRule_47
 nat server protocol tcp global current-interface 8800 8999 inside 10.7.168.14 8800 8999 rule ServerRule_48
 nat server protocol tcp global current-interface 9017 inside 10.7.168.14 10000 rule ServerRule_49
 nat server protocol tcp global current-interface 9018 inside 10.7.168.14 9017 rule ServerRule_50
 nat server protocol tcp global current-interface 15000 16999 inside 10.7.168.14 15000 16999 rule ServerRule_51
 nat server protocol tcp global current-interface 17000 inside 10.7.168.14 17000 rule ServerRule_52
 nat server protocol tcp global current-interface 55555 inside 10.7.168.14 55554 rule ServerRule_53
 nat server protocol udp global current-interface 53 inside 10.7.168.13 56666 rule ServerRule_54
 manage http inbound
 manage http outbound
 manage https inbound
 manage https outbound
 manage netconf-http inbound
 manage netconf-https inbound
 manage netconf-ssh inbound
 manage ping inbound
 manage ping outbound
 manage snmp inbound
 manage ssh inbound
 manage ssh outbound
 manage telnet inbound
 manage telnet outbound
 gateway 39.164.83.129
interface GigabitEthernet1/0/4
 description GuideLan Interface
 ip address 10.5.168.1 255.255.255.0
 manage http inbound
 manage ping inbound
 manage snmp inbound
 manage ssh inbound
 manage ssh outbound
 undo dhcp select server
interface GigabitEthernet1/0/6
 ip address 10.10.168.1 255.255.255.0
 manage http inbound
 manage ping inbound
 manage snmp inbound
 manage ssh inbound
 manage ssh outbound
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
 ip address 117.159.229.25 255.255.255.192
 nat server protocol tcp global 117.159.229.25 10443 inside 10.7.168.200 10443 rule other-1
 manage http inbound
 manage ping inbound
 manage snmp inbound
 manage ssh inbound
 manage ssh outbound
 gateway 117.159.229.1
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/5
 port link-mode bridge
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/4
 import interface GigabitEthernet1/0/6
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/2
 import interface GigabitEthernet1/0/8
security-zone name Management
 import interface GigabitEthernet1/0/0
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 authentication-mode scheme
 user-role network-admin
line class vty
line aux 0
 authentication-mode none
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/2 39.164.83.129 preference 59
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/8 117.159.229.1 preference 61
 ip route-static 10.0.0.0 8 GigabitEthernet1/0/4 10.5.168.2
performance-management
 ssh server enable
 undo password-control blacklist all-line
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$xc15w2Hq/cSxfUBl$75tYgHWaGc4pRoDFm9DLXXKcUbXsLljSuPZUoN0Ao4A7MTUvaTSbASw7qRF4K4SDjCb/ARHpaKqHfnR9/rc0qA==
 service-type ssh terminal https
 authorization-attribute user-role level-3
nat global-policy
 rule name GlobalPolicyRule_1
  description GuideNat
  source-zone Trust
  destination-zone Untrust
  action snat easy-ip
 ip https enable
 loadbalance isp file flash:/lbispinfo_v1.5.tp
security-policy ip
 rule 3 name GuideSecPolicy
  action pass
 cloud-management server domain opstunnel-seccloud.h3c.com
return
粉丝:43人 关注:1人
你配值了优先级,默认走上面那条哇,所以你访问 外网117.159.229.25:10443映射不通的呀
请问优先级我配置成一致吗?如果配置一致后,感觉之前对39.164.83.129的外网映射全部不通了
zhiliao_T3Abh 发表时间:2024-04-09
回复zhiliao_T3Abh:
开启保持上一跳功能,另外 如果是单机情况下推荐用接口nat 不用全局nat
zhiliao_h907dg 发表时间:2024-04-09
粉丝:158人 关注:8人
你这做主备了 啊
需要如何配置,变成主主,2个公网都能用
路由优先级一致,
zhiliao_sEUyB 发表时间:2024-04-09
粉丝:147人 关注:0人
您好,配置策略路由
需要如何配置,变成主主,2个公网都能用
