AC提示该条报错(Reason Code:5025)
2024-04-11提问
  • 0收藏,139浏览
Rare~ 零段
已经更新至最新的驱动,房间内其他设备正常上网认证,报错电脑连接其他楼宇的AP可正常认证
粉丝:137人 关注:8人
Received deauthentication frame in Run state(Reason Code:5025) 在运行状态下收到解除身份验证帧
看下终端有没有开节电模式啥的
粉丝:144人 关注:0人
您好,Received deauthentication frame in Run state(Reason Code:5025) 在运行状态下收到解除身份验证帧
这种情况是客户端主动要求断线,更新下客户端网卡驱动
看下空口利用率
无线协议规定的802.11 Deauth报文的Reason Code
CodeReason
0Reserved
1Unspecific Reason
2Previous authentication no longer valid
3Deauthenticated because sending STA is leaving (or has left) IBSS or ESS
4Disassociated due to inactivity
5Disassociated because AP is unable to handle all currently associated STAs
6Class 2 frame received from nonauthenticated STA
7Class 3 frame received from nonassociated STA
8Disassociated because sending STA is leaving (or has left) BSS
9STA requesting (re)association is not authenticated with responding STA
10Disassociated because the information in the Power Capability element is unacceptable
11Disassociated because the information in the Supported Channels element is unacceptable
12Reserved
13Invalid information element.
14Message integrity code (MIC) failure
154-Way Handshake timeout
16Group Key Handshake timeout
17Information element in 4-Way Handshake different from (Re)Association Request/Probe Response/Beacon frame
18Invalid group cipher or Association denied due to requesting STA not supporting all of the data rates in the BSSBasicRateSet parameter
19Invalid pairwise cipher
20Invalid AKMP
21Unsupported RSN information element version
22Invalid RSN information element capabilities
23IEEE 802.1X authentication failed
24Cipher suite rejected because of the security policy
25-31Reserved
32Disassociated for unspecified, QoS-related reason
33Disassociated because QoS AP lacks sufficient bandwidth for this QoS STA
34Disassociated because excessive number of frames need to be acknowledged, but are not acknowledged due to AP transmissions and/or poor channel conditions
35Disassociated because STA is transmitting outside the limits of its TXOPs
36Requested from peer STA as the STA is leaving the BSS (or resetting)
37Requested from peer STA as it does not want to use the mechanism
38Requested from peer STA as the STA received frames using the mechanism for which a setup is required
39Requested from peer STA due to timeout
45Peer STA does not support the requested cipher suite
45-65Reserved
535Reserved
粉丝:119人 关注:1人
关于H3C AC报错信息“Received deauthentication frame in Run state (Reason Code:5025)”,这个错误通常表示客户端主动要求断开连接。这可能是由于客户端网卡驱动需要更新,或者是因为空口利用率较高导致的问题。无线协议802.11中的Deauth报文的Reason Code 5025并不在标准的理由代码列表中,因此这可能是一个特定于厂商的代码。
解决这个问题的建议步骤包括:
  1. 更新客户端网卡驱动,确保使用的是最新版本。
  2. 检查无线网络的空口利用率,如果过高,可能需要调整网络设置以减少拥塞。
  3. 如果问题持续存在,可能需要联系H3C的技术支持以获取更具体的诊断和解决方案1
此外,如果您的网络环境中存在其他设备干扰或反制无线SSID,这也可能导致类似的错误。在这种情况下,您可能需要进行更深入的网络环境分析和排查潜在的干扰源2
希望这些信息能帮助您解决问题!
