S6850 irf堆叠失败
2024-04-22提问
  • 0收藏,268浏览
HCL模拟器上的S6850交换机可以做irf堆叠吗,为什么一直堆叠不成功,命令没问题
6 个回答
粉丝:171人 关注:8人
可以
IRF需要严格根据官网文档步骤操作,配置步骤可以上来看下
#设备1 irf member 1 priority 32 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 shutdown irf-port 1/1 port group interface Ten-GigabitEthernet1/0/49 port group interface Ten-GigabitEthernet1/0/50 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 undo shutdown save irf-port-configuration active #设备2 irf member 1 renumber 2 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 shutdown irf-port 2/2 port group interface Ten-GigabitEthernet2/0/49 port group interface Ten-GigabitEthernet2/0/50 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 undo shutdown save irf-port-configuration active
zhiliao_9cc14G 发表时间:2024-04-22
把设备内存调整大一些试试
zhiliao_sEUyB 发表时间:2024-04-22
z6Kl9 九段
粉丝:67人 关注:2人
上配置看看
看配置没什么问题,改完设备member 之后重启了吗?
z6Kl9 发表时间:2024-04-22
回复z6Kl9:
重启了,然后完成配置设备2就卡死了,设备1有这个日志IRF port 1 went down because the heartbeat timed out.
模拟器?模拟器的话,就把内存调大一些
粉丝:8人 关注:0人
支持
检查下配置和相关输出进一步定位下吧
如下图
仔细检查下吧,太乱了,拓扑也没日志也没。无法判断
zhiliao_8h148y 发表时间:2024-04-22
你好,可以给下你的配置吗,想要参考一下
就标准配置呀,没啥特殊的
粉丝:147人 关注:0人
您好,支持的
粉丝:94人 关注:0人
支持的,配置问题
#设备1 irf member 1 priority 32 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 shutdown irf-port 1/1 port group interface Ten-GigabitEthernet1/0/49 port group interface Ten-GigabitEthernet1/0/50 int range Ten-GigabitEthernet 1/0/49 to Ten-GigabitEthernet 1/0/50 undo shutdown save irf-port-configuration active #设备2 irf member 1 renumber 2 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 shutdown irf-port 2/2 port group interface Ten-GigabitEthernet2/0/49 port group interface Ten-GigabitEthernet2/0/50 int range Ten-GigabitEthernet 2/0/49 to Ten-GigabitEthernet 2/0/50 undo shutdown save irf-port-configuration active 这有问题吗
粉丝:6人 关注:0人
那重装一下HCL模拟器看下  看看能不能解决
